rnphila 5 #1 Posted January 2, 2022 Hi, I bought an old wheel horse about a year ago, used it to mow the lawn and it worked fine. The owner gave me bunch of manual and spare parts. I'm trying to attach snow plow, however it doesn't look like standard ones with a supporting frame. Could you help with identifying what kind of plow it is? Can it be attached at all to this tractor? I also have a blower like on the second image. I'm changing attachments first time, thought the plow would be easier to attach... Maybe I should attach blower and use it. 1 Share this post Link to post Share on other sites
rjg854 11,354 #2 Posted January 2, 2022 That's not a wheel horse plow, but if the snow blower is looks like what's in the picture that should work fine. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,036 #5 Posted January 3, 2022 Here is a list of the dozers that fit your tractor. They are almost all the same with subtle improvements over the years. Should be easy to find a used one. Look up a parts list to the one you find to make sure you get all the loose pieces. 1968 model 6-4111 - First to fit LONG & SHORT frame tractors and first to mount under the rear axle with a loose A-frame crossbar - replaced by 1969 model [6-4112 + 6-9621] 1970-73 model [6-4113 + 6-9622] 1973-74 model [6-4113 + 6-9623] 1974 model [6-4114 + 6-9624] 1974 model 6-2131 1975 model 6-2132 1976 model 6-2133 1976 model 66-42BC01 1977 model 76-42BC01 1978 model 86-42BC01 1979 model 96-42BC01 1980 model 06-42BC01 - (Last blade to have a loose A-frame crossbar #7701) 1981-1984 model 06-42BC02 (Up to here including this one they are 42" wide) and (First blade to have a welded-in rear A-frame crossbar) 1984-1989 model 06-48BC01 (They are now 48" wide) - replaced by the following 1990 model 06-48BC02 (Last blade to have 3 angle positions) 1991-1993 model 06-48BC03 (First blade to have 5 angle positions) 1993-2001 model 79350 - (105-1502 kit adapts 2001 and older GT Classic-Series blades to fit 2002 and later tractors 2002 2004-2009 2012 model 79364 - (105-1501 kit adapts 79364 blade to fit 2001 and older GT Classic-Series) 1 1 Share this post Link to post Share on other sites
rjg854 11,354 #6 Posted January 3, 2022 I'm not saying it won't work mind you. It's just that it's not factory-made. I don't see how you raise the blade off the ground, unless it works like the snowblower does with a bar under the tractor hooked to the rock shaft. And you have to get off the tractor to change the angle of the blade. If it works the way it is, fine for you 2 Share this post Link to post Share on other sites
rnphila 5 #7 Posted January 3, 2022 Thanks! I've installed the snowblower instead, everything fitted. One questions though. 5 hours ago, rjg854 said: snowblower does with a bar under the tractor hooked to the rock shaft Does snowblower require this bar? I have a pipe that connects with a pin to the lower part of snowblower. But I'm not sure where's the other end goes - it's just open pipe (or bar?). Share this post Link to post Share on other sites
wallfish 16,987 #8 Posted January 3, 2022 To lift it, yes but you also need this part to connect to the tractor https://wheelhorsepartsandmore.com/product/snow-blower-lift-flag-101461-with-spring-4629-and-eye-bolt/ 1 Share this post Link to post Share on other sites
rnphila 5 #9 Posted January 3, 2022 does that flag part 1 connects with the pipe 2? I might have this flag part somewhere… I definitely have this bar/pipe #27 Share this post Link to post Share on other sites
rnphila 5 #10 Posted January 3, 2022 Found all parts, woo hoo! figuring out how there’s last pieces connect Share this post Link to post Share on other sites
