RED-Z06 2,390 #1 Posted January 2, 2022 And made a video. Holds 266 mowing at 77* ambient..its amazing how quickly the engine heat soaks on shutdown 3 1 1 Share this post Link to post Share on other sites
Maxwell-8 4,366 #2 Posted January 2, 2022 intresting! head temps can tell a lot about fuel ratios as well. 1 1 Share this post Link to post Share on other sites
RED-Z06 2,390 #3 Posted January 2, 2022 19 minutes ago, Maxwell-8 said: intresting! head temps can tell a lot about fuel ratios as well. Yes it can, get too lean and you'll see a big spike in temp. I had grass accumulate on the chaff screen and saw temps rise pretty fast...hit 285 in no time. 2 Share this post Link to post Share on other sites
ebinmaine 69,730 #4 Posted January 2, 2022 Interesting stuff. What's the thermometer you used? Share this post Link to post Share on other sites
RED-Z06 2,390 #5 Posted January 2, 2022 57 minutes ago, ebinmaine said: Interesting stuff. What's the thermometer you used? Its off ebay, the ring lead goes under the plug, 2 wires to the battery or 12v for the light and 12v readout. 1 Share this post Link to post Share on other sites
Greentored 3,217 #6 Posted January 5, 2022 Super interesting! I did a pretty 'warmed up' K321 last year, and installed an oil temp gauge to monitor one from the bottom. Was surprised to see the gauge barely tickle 150, and that was on a 80 degree day, jerking a plow around the garden. Keep updates going, interesting stuff! Share this post Link to post Share on other sites
RED-Z06 2,390 #7 Posted January 5, 2022 1 minute ago, Greentored said: Super interesting! I did a pretty 'warmed up' K321 last year, and installed an oil temp gauge to monitor one from the bottom. Was surprised to see the gauge barely tickle 150, and that was on a 80 degree day, jerking a plow around the garden. Keep updates going, interesting stuff! Splash lubed engines tend to run cooler oil, I put a gauge on a 25hp kohler command twin and saw 190 at the filter adapter but my M10s running at 50% duty cycle barely hit 140 1 Share this post Link to post Share on other sites
Greentored 3,217 #8 Posted January 5, 2022 2 minutes ago, RED-Z06 said: Splash lubed engines tend to run cooler oil, I put a gauge on a 25hp kohler command twin and saw 190 at the filter adapter but my M10s running at 50% duty cycle barely hit 140 Sounds about right! I was expecting to see much higher temps for a big ol hunk of cast iron. Betting the rod journal is a lot more than 150 though haha Share this post Link to post Share on other sites
