Brockport Bill
Belt numbers cross reference?
Brockport Bill
I am guessing this has happened to others and likely been asked before??????? I have some stray belts - many have numbers, but not all - is there a cross reference guide, or web site, if I enter the WH belt number tells the model WH it fits and where/how its used? and if its not a WH belt - then tells the corresponding WH/toro belt number ? EG: the model tractor and if pto, drive belt, deck belt, blower, etc?? OR, if belt did not have identifier number but if I measured dimensions that I could locate a cross reference of a measurment to a belt number... then cross reference that number? Trying not to throw away these good belts and obviously trying to NOT order belts i do not need if in fact i have belts that would match various applications -- but want to avoid labor intensive and frustrating work of trying belts on various tractors to see if they fit - thanks
gwest_ca
Go to the search box at the top right and click on the box.
A drop down menu will come up. Select Files.
Enter Wheel Horse/Toro part number in box and search. See what comes up.
Brockport Bill
well, yikes !!!!!!!!!!!!! thats interesting and will keep me occupied for awhile -  thanks  -- that'll help with 3 orphan belts i have - now, if i can find a way to cross reference NON wh belt numbers to learn the corresponding WH belt number............ then i can use this search engine to make the final step -- great start, thanks again - anyone else that has tips are welcome to send along???
Brockport Bill
Brockport Bill
does the term drive belt refer to the belt from the p.t.o. to the mower deck  -- and the term spindle belt refer to the belt on the mower deck that circulate around the spindle pulleys?
gwest_ca
That is correct.
Try the Gates site with others. Getting them to a Gates number will give the size.
https://ww2.gates.com/if/automotive/partslookup/Interchange/index.cfm
In the back of the belt manuals we have there is a Wheel Horse/Toro part number list and a belt size list. May help.
There is a way to find where a Wheel Horse part number was used but it is complicated. If you have a number post it and will try to walk you through the process using that number. Once you do it it is simple.
Brockport Bill
this is like going to Disney -- thanks again -- already found some items - plus lots of other resource info !!!!!!!!!!!!!!!!
Brockport Bill
4 minutes ago, gwest_ca said:
That is correct.
then whats the belt from pto to the rear end tranny called............. if the belt from pto to mower is called drive belt??
gwest_ca
Transmission drive belt
Snowthrower drive belt
Tiller drive belt
