RED-Z06
Bolts that mount the fender pan on a 312-8
RED-Z06
Mine had no hardware, it looks like 5/16-18 x 3/4 on the seat bracket (4) and the others 5/16-18 x 1/2?
The gas tank is like right there in back...
kpinnc
Can't be 100% sure on the lengths, but you're correct on the thread size.
RED-Z06
I guess if it's too close to the tank I can trim them some.
kpinnc
I've never hit the tank, even with 3/4 lengths. And I always use washers too, but that doesn't take much length off.
RED-Z06
I've never hit the tank, even with 3/4 lengths. And I always use washers too, but that doesn't take much off
You know thinking back there were reliefs on the tank i saw while power washing the inside...wonder if those happen to line up under the mounts?..
Jeff-C175
Yes, they do.  I just did mine and stuck my caliper down the hole to measure.  I don't recall the exact depth but it was at least an inch.  I used 1" bolts with a flat and a lock on all of them.
RED-Z06
Ah that makes sense.
pacer
A little bit OT, but have you guys ever tried "flange head" bolts/nuts? I picked up a Massey garden tractor and apparently they used ALL flange heads thru out and I have fallen in love with them. I even went over to my bolt place and bought a bucketful of assorted sizes. Eliminates need for lock washers....
92323A558P2-c01a-digitall@1x_637171787673000923.png?ver=ImageNotFound
  • Like 4
pfrederi
  I use them a lot on my Horses  Like fender bolts asked about here.  The are really good for sheet metal.  Especially when the holes are slots or just wallowed out from age...
RED-Z06
I use flanged bolts alot but not the serrated style, they bite well but after a few uses they begin to erode the sheemetal a bit.
Jeff-C175
Yeah, something that gets frequently taken apart should probably not use them.  I consider them for something that goes together and stays together.
And they sure will mess up some paint too.  Much more so than a flat washer with a lock washer would!
Edited by Jeff-C175
pfrederi
  Conversely they make better grounds....
pacer
Like many things, the serrated bolts have a place among all the other hardware. On the Massey I mentioned there was a mix of different bolt types. While I was aware of them, I just had never used them other than occasionally and when I took the MF apart and reassembled it I became impressed with them.
Jeff-C175
Yes they do!
However, you don't want to use them for mounting a ring lug!  They'll chew those up and spit them out!  For that application a toothed washer is 'on call'.
Edited by Jeff-C175
