Coadster32 793 #1 Posted June 23, 2009 Is there an 8-speed tranny that would bolt right up to a 854 without hardly any mods in getting it to work. I have been seeing alot of 310-8s and 312-8s. I didn't know if perhaps an older 8speed tranny would be better for the task, like a B or C-series. If it won't be too bad, I'd be interested in it. Any other insights would greatly be appreciated. I don't really plan on working it, but you never know. Share this post Link to post Share on other sites
WHC-125 4 #2 Posted June 23, 2009 You should make a puller :thumbs: Share this post Link to post Share on other sites
bell 11 #3 Posted June 23, 2009 It is possible... I've seen one done. I think the early 6/ 8 speeds transmission pulley would be the one to use... It's smaller and uses a 1/2" belt. I've got a spare 8-speed under the bench, waiting to go in the 633 dually... :thumbs2: Share this post Link to post Share on other sites
Dave85zxt 0 #4 Posted June 23, 2009 I just put an 8 speed in my 856. The transaxle I used was from a c series and it bolted right into the frame. I had to get a different drive pulley to keep the ratio the same. I also had to modify the 4 spd brake band to make it fit. The brake band needed a new hole drilled in it and it need to be bent in a vice slightly. Last, I had to make a custom brake band linkage out of some 3/8" rod. It was all pretty easy an only required a vice, drill and 3/8" die. I am sure glad I did it though. I can't imagine trying to cut some of the tall grass I just tackled without the low range. Share this post Link to post Share on other sites
Coadster32 793 #5 Posted June 23, 2009 Hey Dave, that's exactly the type on install I'm looking for. Thanks for posting this. I know a bunch of members are going to dissapear for the rest of the week, but any others done this? Share this post Link to post Share on other sites
Kelly 1,029 #6 Posted June 23, 2009 I've never done it but the 1045 I just bought has a early 6 speed in it and has the 1/2" belt pulley that is for the small engine drive pulley, and the brake band was fliped and the rod modified, basicly just like Dave said. oh and a hole near your shifter for the high low. Share this post Link to post Share on other sites
Coadster32 793 #7 Posted June 23, 2009 Pardon the green rookie question, but is there a difference between the 6 speed and the 8 speed tranny, or is it just counting reverse? :thumbs2: Share this post Link to post Share on other sites
Kelly 1,029 #8 Posted June 24, 2009 Nope basicly the same, just till around 72 I think, they called them 6 speeds Share this post Link to post Share on other sites
wheel horse 1045 2 #9 Posted June 24, 2009 the drivebelt pulley and the shaft its on was smaller on the the 6 speeds if im not mistaken Share this post Link to post Share on other sites
Coadster32 793 #10 Posted June 24, 2009 Would it be correct to say that the 6 speeds have a 1inch axle, and the 8 speeds have the 1.125 axle? Also, is there a physical size difference, and bolt pattern difference? I hate to seem like a pain, but just when I start looking, I want it to be exactly what I'm looking for. I'd hate to get a 310-8, and have to reinvent the wheel. A few mods are expected, but within reason would be preferred. Share this post Link to post Share on other sites
wheel horse 1045 2 #11 Posted June 24, 2009 no the axles are the same size, the workhorse axles with the 8 speeds have the 1 inch axle if im not mistaken . Share this post Link to post Share on other sites
Kelly 1,029 #12 Posted June 24, 2009 Not just the work horse's have 1" axles many C/B's, and 300 series have 1" axles, and yes the 67 6 speeds used a smaller input shaft and the drive pulley was smaller because the engine that year still had the small drive pulley. Share this post Link to post Share on other sites
Coadster32 793 #13 Posted June 25, 2009 The way the castings look, I should be able to open them up without buying new pullys, brake drum, or hubs. Watch for the shifter to clear, and modify the brake linkage. Should I stay away from the 310/312 lines on this one, and shoot for a C/B, or older 6 speed? Share this post Link to post Share on other sites
wheel horse 1045 2 #14 Posted June 25, 2009 thats what i would do Share this post Link to post Share on other sites
Coadster32 793 #15 Posted June 25, 2009 Thanks for the help to all. Chris. Share this post Link to post Share on other sites
