Gregor 4,847 #1 Posted December 18, 2021 A few days ago I said I was going to take a wheel outside and blast it with some coarser media, with my HF blaster. I can't seem to find that post now. I finally got I bought some coarser media and a face mask, (which I strongly recommend) and blasted a while. This was 5 lbs of media, and 15 minutes. Stopping 3 times to let the compressors catch up. That took a couple minutes each time. I think I could have trapped at least some of the media if I had a large box, and the wind would slow down to at least a gale. Before and after pics. I have a friend with a LARGE compressor in his shop. If it were warmer outside, I would take everything there, and try it out with an adequate compressor, but it snot. I think I could use coarser media if I could find it. I don't know if this would be better or not. It says large Grade. What does that mean? At this rate, the way I am doing it, I am sure it would take more than 50lbs. of media. That's not economically feasible. I need a box! Share this post Link to post Share on other sites
oliver2-44 10,265 #2 Posted December 18, 2021 The soda blast media is softer (less that aggressive) that the glass. I suggest you go to Tractor Supply or Northern Tool and buy a 50lb bag of Black Beauty coal slag. it cost a lot less and will do a better job. https://www.tractorsupply.com/tsc/product/black-diamond-medium-blasting-abrasives-3905403?store=561&cm_mmc=organic_feed-_-GoogleShopping-_-Product-_-3905403&utm_source=Shopping&utm_medium=ECOMM&utm_content=Feed&utm_campaign=Core&cid=Shopping-ECOMM-Core--33&gclid=Cj0KCQiAqvaNBhDLARIsAH1Pq52gwOHj9MsY9s8O2gcdzktSGYwdBckP3Ls-q57VGdOFC4mxZxT5F68aAuwPEALw_wcB 2 1 Share this post Link to post Share on other sites
AMC RULES 37,144 #3 Posted December 18, 2021 Should add a needle scaler to your aresonal. Serves to make short work of them rusted up rims too. 1 1 1 Share this post Link to post Share on other sites
Gregor 4,847 #4 Posted December 18, 2021 1 minute ago, AMC RULES said: Should add a needle scaler to your aresonal. Serves to make short work of them rusted up rims too. I use to have one of those. I need another me thinks. 2 Share this post Link to post Share on other sites
AMC RULES 37,144 #5 Posted December 18, 2021 Shirley... you do! 2 Share this post Link to post Share on other sites
lynnmor 7,545 #6 Posted December 18, 2021 I would try some paint stripper and see how that works. If you can scrape away a large percentage of the paint, the blasting will be less of a chore. 1 Share this post Link to post Share on other sites
8ntruck 7,332 #7 Posted December 18, 2021 I'm cleaning bricks for my porch project. The little voice in the back of my head keeps asking if a needle scaler would be a good tool to blow the old mortar off of the bricks. Sorry, I'm off subject here. 1 Share this post Link to post Share on other sites
pacer 3,175 #8 Posted December 18, 2021 @oliver2-44 definitely has it --- Black Beauty, last I bought (4-5mos ago) was $10 for 50lbs. But (theres that but) You will need the need the fine grade (red trimmed bag - color designates grit) The siphon feed guns and my blast cabinet will clog coarser grit. I tried a bag of coarser grit (black trimmed bag) because they were out of fine -- just wouldnt feed, kept clogging. Would prolly make for faster removal if could use the coarse..... @AMC RULES needle scaler is good also, especially in the heavier /thicker coats of paint - which seem to be the case on rims. Obviously the cabinet wont handle larger items - hoods, seat pans,etc - so I go out in the grass next to the shop and set up couple saw horses with a piece of plywood laid across to do these using one of those cheap $20-25 siphon guns with a 5 gallon bucket and Black Beauty (use the ceramic nozzles, the metal ones wont last). Heh, I bet I've raised the level of that area a couple inches over the years, probably 75-80 bags on media. I also have a REAL blast hood I found in a pawn shop, and I use a full face filter with - definitely! gloves - these are a must outside. I tried glass bead and it was .... meh, not impressive and more expensive than the coal slag Lastly, as you found out, you gotta have a LOT of air, a compressor capable of, minimum, 15+ CFM (cubic feet minute) 1 Share this post Link to post Share on other sites
ebinmaine 70,365 #9 Posted December 19, 2021 Been thinking about getting a small blaster for a few years. S'pose it's about time. Would an appliance box help to catch the media for reuse? 1 Share this post Link to post Share on other sites
lynnmor 7,545 #10 Posted December 19, 2021 36 minutes ago, ebinmaine said: Been thinking about getting a small blaster for a few years. S'pose it's about time. Would an appliance box help to catch the media for reuse? Sure, anything would be a help. I'm sure with your resourcefulness, that building a cabinet would be easy. Think plastic or steel drums for the easy way, or watch some YouTube videos on the subject. 1 Share this post Link to post Share on other sites
ebinmaine 70,365 #11 Posted December 19, 2021 5 minutes ago, lynnmor said: Sure, anything would be a help. I'm sure with your resourcefulness, that building a cabinet would be easy. Think plastic or steel drums for the easy way, or watch some YouTube videos on the subject. Hadn't thought of using a drum/barrel. That's a neat idea. 1 Share this post Link to post Share on other sites
lynnmor 7,545 #12 Posted December 19, 2021 Just now, ebinmaine said: Hadn't thought of using a drum/barrel. That's a neat idea. If you cut a window in the side of a barrel and turn it on its side, then the media can then settle to the bottom for the suction hose to pick it up. 1 Share this post Link to post Share on other sites
ebinmaine 70,365 #13 Posted December 19, 2021 5 minutes ago, lynnmor said: window What's the window material? Lexan? Plexiglass? Share this post Link to post Share on other sites
lynnmor 7,545 #14 Posted December 19, 2021 Just now, ebinmaine said: What's the window material? Lexan? Plexiglass? It can be anything, just don't use a fragile glass, safety glass is best. If you use a plastic, it will become hazy in minutes. Here is one place to buy, or at least get ideas for parts. Note the protectors for windows. 1 Share this post Link to post Share on other sites
squonk 42,343 #15 Posted December 19, 2021 lynnmor beat me too it TP tools for cabinet parts. Carbide nozzles if you do a lot of blasting. https://www.tptools.com/Sandblast-Cabinet-Parts-and-Supplies.html 1 Share this post Link to post Share on other sites
pacer 3,175 #16 Posted December 19, 2021 Honestly fellas, before you put a LOT of effort, and, a fair amount of $ into a home made cabinet, take a long look at HF's version --- at $200 that is gonna be hard to beat. With all the neat (inexpensive) ideas for improving it on you tube, that thing can be transformed into a really great tool. See that steep angled part under it, that is really critical to let the media continually drop into there so the siphon tube can readily pick it up, plus you already have the viewing window and air conx, gun etc. Then as I mentioned, a couple of the neat refinements on you tube.... Share this post Link to post Share on other sites
Gregor 4,847 #17 Posted December 19, 2021 1 minute ago, pacer said: take a long look at HF's version --- at $200 that is gonna be hard to beat. Is that large enough for rear wheel? With tires still on? If only I had the room. I may have to figure out a way to make room. Share this post Link to post Share on other sites
pacer 3,175 #18 Posted December 19, 2021 1 minute ago, Gregor said: rear wheel? With tires still on? No, but a 12" rim like one that you were working on will fit..... I find myself wiggling pieces in there that I wouldnt think would fit but with a little fiddling I can many time figure it out. Heh!, thinking back, kinda reminds me of some of the old cars/trucks I've had - I just keep tinkering with it finding more and more ways to make it better -- it has to rank in the top 5 tools in my shop! I guess I oughta mention that you WILL ABSOUTLY need a vacuum dust recovery system of some type, but here you can pretty easily rig up something 'home made' again you tube, After a few years I went ahead and got a dedicated recovery from HF.... Guess I oughta take a few pics of my set-up and post them 1 Share this post Link to post Share on other sites
ebinmaine 70,365 #19 Posted December 19, 2021 12 minutes ago, pacer said: Guess I oughta take a few pics of my set-up and post them I'd be very interested in that. 1 Share this post Link to post Share on other sites
Elliot Garfinkel 166 #20 Posted June 30, 2022 Hi I know I'm late to the party but I've seen a media blaster that hooks up to a pressure washer so the hi cfm compressor is not an issue ,from the U tube vids it looks like it works OK I plan on getting one their only about 25-35 dollars.just another tool Share this post Link to post Share on other sites
