ebinmaine 67,596 #1 Posted December 17, 2021 I have a c-160 gas tank that has no gasket inside the cap. As you can imagine considering there's a hole in the center of the cap that leaks quite a fair amount. What can I make a vented gasket from and where do I put the vent hole in the gasket itself? Share this post Link to post Share on other sites
Achto 27,601 #2 Posted December 17, 2021 Most of those have a rubber or cork gasket ring, with nothing over the vent hole. Share this post Link to post Share on other sites
8ntruck 7,016 #3 Posted December 17, 2021 (edited) Probably make the gasket like a baffle - put vents in the gasket not in line with the vent in the cap. Material? Depends on the geometry of the cap. If you can manage a round, flat gasket, maybe some sort of high durometer fuel resistant gasket material? I can't imagine why you are having apparent fuel sloshing issues, given the golf green like property that you operate on..... Edited December 17, 2021 by 8ntruck 1 Share this post Link to post Share on other sites
ebinmaine 67,596 #4 Posted December 17, 2021 5 minutes ago, Achto said: Most of those have a rubber or cork gasket ring, with nothing over the vent hole. 3 minutes ago, 8ntruck said: baffle This is what I've got guys Share this post Link to post Share on other sites
pfrederi 17,741 #5 Posted December 17, 2021 These are from a red tank and a black plastic tank on Chargers but should be very similar. Two piece operation with internal tubes.. offset 2 1 1 Share this post Link to post Share on other sites
pfrederi 17,741 #6 Posted December 17, 2021 You cap looks just like my plastic one on the left. 2 Share this post Link to post Share on other sites
ebinmaine 67,596 #7 Posted December 17, 2021 2 minutes ago, pfrederi said: You cap looks just like my plastic one on the left. Agreed. Maybe I could make up a double layered gasket with the middle hollow and then punch a couple holes in the other layer so they won't line up with the cap orifice. 1 Share this post Link to post Share on other sites
8ntruck 7,016 #8 Posted December 17, 2021 Gas cans used to come with 'seal discs', a block off plate to go under the pour spout. Got one of those lying about? Poke a couple of #50 size drill holes off center & sandwich it between the cap bad tank. 1 Share this post Link to post Share on other sites
ebinmaine 67,596 #9 Posted December 17, 2021 12 minutes ago, 8ntruck said: Gas cans used to come with 'seal discs', a block off plate to go under the pour spout. Got one of those lying about? Poke a couple of #50 size drill holes off center & sandwich it between the cap bad tank. I like the idea quite a lot but I don't think I have anything like that hanging out Share this post Link to post Share on other sites
wallfish 17,011 #10 Posted December 17, 2021 3 hours ago, ebinmaine said: I don't think I have anything like that hanging out Scissors and an empty plastic oil jug? Offset the hole and you can use a small piece of foam under the hole in the cap pinched in between. 2 1 Share this post Link to post Share on other sites
ebinmaine 67,596 #11 Posted December 18, 2021 1 hour ago, wallfish said: Scissors and an empty plastic oil jug? Offset the hole and you can use a small piece of foam under the hole in the cap pinched in between. Foam from BBT's favorite pillow ok? Share this post Link to post Share on other sites
Handy Don 12,235 #12 Posted December 18, 2021 3 minutes ago, ebinmaine said: Foam from BBT's favorite pillow ok? = wishing for extreme discomfort 1 Share this post Link to post Share on other sites
pfrederi 17,741 #13 Posted December 18, 2021 15 hours ago, wallfish said: Scissors and an empty plastic oil jug? Offset the hole and you can use a small piece of foam under the hole in the cap pinched in between. Most foam will not hold up to gasoline. You need to experiment with pieces first... 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,046 #14 Posted December 18, 2021 A small amount of stainless steel pulled from a pot scrubber may work. 2 Share this post Link to post Share on other sites
wallfish 17,011 #15 Posted December 18, 2021 3 hours ago, pfrederi said: Most foam will not hold up to gasoline. You need to experiment with pieces first... The foam from an air filter cover or the foam used for an air cleaner It only needs to be a small piece. One of the caps I have is set up like that 2 Share this post Link to post Share on other sites
Lee1977 6,666 #16 Posted December 19, 2021 (edited) I haven't had a gasket in mine for years as long as you keep it an inch or so down It don't leak enough to hurt anything Cut a disk out of a plastic oil bottle and drill a small hole off center. Edited December 19, 2021 by Lee1977 1 Share this post Link to post Share on other sites
