sjoemie himself
Murray to IH 1568
Oldskool
5 minutes ago, sjoemie himself said:
Thoughts, yes or no?
Oh yes. YES. Did I already say yes? Yes lol.
That would be kick a$$.
Hydraulic? I hope....
  • Haha 1
ebinmaine
Yeah. I'm with Mike @Oldskool
Absolutely yes.
Achto
Three point would be an extremely nice touch. :handgestures-thumbupright:
Handy Don
Very cool if you have something you want to attach. Otherwise just eye candy.
If you go ahead, you're gonna be attaching to sheet metal so think through where the forces will be handled, not just lift but also drag, and lateral stuff on turns.
953 nut
:text-coolphotos:
Those rear fenders make it look like the IH big brother for sure.  :woohoo:   Love the three point if only for show. I put together a light duty three point a while back and will probably make a box to fit it for flea market find hauling.
  • Haha 1
sjoemie himself
Thanks guys! I guess the verdict is pretty clear:mrgreen:
16 hours ago, Oldskool said:
Hydraulic
Hydraulic is the goal. Will be a challenge to mix and match all the components so i'll be needing all the help I can get on that one.
I have gathered a few pumps and hydraulic cilinders already and a nice little tank which was previously used for filling helium balloons which could be turned into an oil tank.
Plan is to drive the pump directly from the engine, and I would like to be able to engage and disengage the pump to prevent overheating.
Also i'm wondering if I would need a oil-cooler and how many hydraulic external connections I should install? :confusion-confused:
sjoemie himself
1 hour ago, 953 nut said:
:text-coolphotos:
Thank you! :notworthy: also thanks for posting the link to your topic. Very interesting and useful topic.
WHX??
I don't think you would need a oil cooler if it's a dedicated three point or other attachment use. There are none on a wood splitter or FEL. The oil does get warm but not overly hot.  Just use the proper open center spool valve. The clutch wouldn't be absolutely necessary but would help to be able to disengage the HY pump for cold starts. Very cold oil can be like molasses in winter and will bog a motor down till the oil warms up.  All kinda depends on how well the Briggs does.
Edited by WHX??
Oldskool
X2 what @WHX?? said
If you are installing external ports I would think front and rear quick connects should do.
Pullstart
Excellent craftsmanship!  The VW steering box was brilliant and the fab work is top notch!  The scored radius around the dash is great.  :handgestures-thumbupright:
sjoemie himself
All very good tips. Probably going to skip the oil cooler for now then.
External ports in my mind should be at least one single acting one on the back for a tipping trailer of some sorts. And maybe a double or single one to power a hydraulic motor for implements like a tiller. Ideas are running crazy in my head.. oh well maybe better to get the three point working first and then expand from that.
In other news my dad sent me some pics of the sheetmetal for the hood of the tractor. Since I have no break to bend sheetmetal and my dad works at a company where they do that kind of stuff daily I asked him if he could help me out.
As soon as I get the part i'll mock it up and post some pictures. Pretty excited to see what it will look like :woohoo:
  • Excellent 5
Handy Don
Assuming you have the pump capacity (volume and pressure) to drive hydro motor implements, be sure to pay attention to the tubing/hose sizing over the distances it takes to plumb it all. You'll probably need M14 or M16 to carry the needed flow.
  • Like 4
sjoemie himself
Since the previous post i've been tinkering away.. I think the three point is a go!
  • Excellent 5
ebinmaine
What kind of weight capacity are you looking for?
Will the stamped steel frame hold that amount or are you adding reinforcement?
Oldskool
That's looking real good. I like it.
Oldskool
I bet you would be surprised
ebinmaine
Quite strong, that?
sjoemie himself
1 hour ago, ebinmaine said:
weight capacity
Good question.. i'm not really sure. Probably going to end up overbuilding everything and never lifting more than 200lbs :confusion-shrug:
About the frame. I'm going to strengthen it as much as possible, or well, at least until i'm satisfied. I think i'll double up the thickness of the frame where the 'l-brackets' mount to prevent tearing. I'll also connect the two l-brackets with a brace to prevent side to side flexing.
  • Excellent 5
Oldskool
Quite strong, that?
I'm sure it could lift the frontend without any issue
sjoemie himself
1 hour ago, Oldskool said:
lift the frontend
Have you not seen my grille and frontweights?? :confusion-confused::P
  • Haha 4
JPWH
Looking good.
Handy Don
Not gonna be much "Murray" left by the time you're finished. You sure do nice work!
Oldskool
I have.
I'm just saying I bet the frame will hold up to the point of the front lifting up from 3pt use in extreme circumstances.
Or do you think it will fold?
sjoemie himself
8 hours ago, Handy Don said:
Not much "Murray" left
Thanks! No not really.. if I ever attempt something like this again i'll probably just use the components I need, transmission and engine, and build the rest from scrap. That being said, this whole project kinda snowballed a little bit :blink:
I certainly hope not! Like I said most of the time I tend to overbuild things so I'm guessing it will be allright.
Wouldn't wanna find out by trail and error though :hide: so i'll just add a little more bracing 😁
  • Excellent 2
JPWH
I tend to overbuild as well but the added weight helps for ground engaging implements. Win win.
Jay
  • Haha 1
  • Similar Content
    • T-Mo
      By T-Mo-(Moderator)
      Sorry for the late notice, but if anyone is near Fredricktown, Missouri, the 17th annual Cubarama is being held this weekend, starting Thursday, the 27th,  (set up day), Friday September 28, and Saturday September 29.  It's held the last weekend of September each year in Fredricktown and is for the Farmball Cub and Cub Cadet, but basically anything IH related.
      Fredricktown is about 80 to 90 miles south of St. Louis.
