peter lena
flat ground straps
Handy Don
1 minute ago, formariz said:
LOL. A little unorthodox right?
I always liked the idea of filling the uncrimped plug first making it easy for solder to totally cover penetrate through wires. Then crimp and apply heat shrink cover.
I have however many times just soldered and not crimp. Inactualky like that better and never had one fail.
Wouldn't the cold wire entering the hot solder cause cold joints? Or do you re-heat after the "plunge"?
formariz
I actually first fill all lugs . Then reheat and keep heating while I plunge it in. Flux also.
Edited by formariz
Jeff-C175
15 minutes ago, formariz said:
never had one fail
Most of the industry 'standards and practices' frown on crimping and soldering.  I've heard all kinds of explanations as to why vs. why not and IMO most of them are just baloney.
I've never had a crimp that I made fail.  I've never had a solder connection that I made fail.  I've never had a crimp and solder connection that I made fail.
I HAVE seen all three done by OTHERS fail though.
Jeff-C175
12 minutes ago, formariz said:
Flux also.
I know that you use the correct electronic flux!  I'm absolutely certain that you know NOT to use PLUMBING flux... or any ACID based flux.  (this post for the benefit of future readers...)
formariz
Personally I rather not crimp and lately have not done it. I like the look of the uncrimped lug better although it gets covered with the heat shrink .
  • Excellent 1
formariz
Yes I do use electronics flux. I am not a great expert at these things but learned a bit long ago assembling Dynakits.
squonk
They actually make the lugs prefilled with solder and flux.
  • Like 3
Jeff-C175
44 minutes ago, formariz said:
assembling Dynakits
OMG!  I sure wish I had never sold my Stereo 70 !  and the preamp... forget the model number of that one.  Had the FM tuner also.  I bought those with money from my paper route!  I had a HUGE paper route but it still took a LONG time to save for those.   I was all of what, maybe 14 years old!
Edited by Jeff-C175
Jeff-C175
48 minutes ago, formariz said:
heat shrink
I've been using the stuff filled with hot glue the past few years.
Handy Don
I have both kinds and keep them in separate places in the shop! Both are essential and good at their respective purposes!
formariz
If tubed it was a PAS3. Otherwise it would have been a PAT4 or 5. Had a few ST70s. Today not working it is a $700.00 amp.
Jeff-C175
3 hours ago, formariz said:
tubed it was a PAS3
Yep, 12AX7's, four of them.  DC on the heaters.
peter lena
@formariz  we always had , a tubing bender  and a  wire crimper  in separate vises  in the weld area . once you regularly used them , you could really speed up and simplify related work.  the instrument  techs , would bend up the tubing run they were going to make up with light wire , as a guide for tubing bends, then fit it to a panel board , pete
RED-Z06
These straps are nice...got rid of my headlight flicker by grounding the hood, added another chassis ground.
Snoopy11
I don't know why I didn't mention this before... but the best pre-made cables and lug sets I have found is from Spartan Power...
I used those when I re-wired the Ranger after the crate motor... and haven't had an issue with any positive or negative wiring...
The Spartan power ones are made in the USA... :USA:
Don
  • Excellent 1
  • Thanks 1
