Brockport Bill
C175 snow plow model?
Brockport Bill
the chart shows a 42 inch snow plow frame/blade for a C175 - model 06-42bc01 - Is there any reason a 48 inch plow of the 1980's and 90s era would not fit  - snow plow model # 0648bc03 or # 79350 - I believe they are also referred to as a 300 series plow????? thanks
gwest_ca
Here is the order they were produced
Dozer DNA of long tractor frame dozer blades
1966-1967 model BD-426 - Fits LONG frame tractors - Mounts ahead of the rear axle - replaced by
1968 model 6-1111 - Fits LONG frame tractors - Mounts ahead of the rear axle
1968 model 6-4111 - First to fit LONG & SHORT frame tractors and first to mount under the rear axle - replaced by
1969 model [6-4112 + 6-9621]
1970-73 model [6-4113 + 6-9622]
1973-74 model [6-4113 + 6-9623]
1974 model [6-4114 + 6-9624]
1974 model 6-2131
1975 model 6-2132
1976 model 6-2133
1976 model 66-42BC01
1977 model 76-42BC01
1978 model 86-42BC01
1979 model 96-42BC01
1980 model 06-42BC01
1981-1984 model 06-42BC02 (Up to here they are 42" wide)
1984-1989 model 06-48BC01 (They are now 48" wide)
1990 model 06-48BC02 (Last blade to have 3 angle positions)
1991-1993 model 06-48BC03 (First blade to have 5 angle positions)
1993-2001 model 79350 - (105-1502 kit adapts 2001 and older GT Classic-Series blades to fit 2002 and later tractors
2002 2004-2009 2012 model 79364 - (105-1501 kit adapts 79364 blade to fit 2001 and older GT Classic-Series)
Any blade after the original model should fit perfect. The 48" width is better suited to your tractor.
Brockport Bill
1974 model 6-2131
1975 model 6-2132
1976 model 6-2133
so just to be sure??? a 06- 48bc 01 or 02 or 03 should fit a C175 as well as a 79350? Thanks for clarifying
gwest_ca
That is correct
gwest_ca
That is correct
Brockport Bill
thanks very much!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
peter lena
@Brockport Bill   glad you got the detailing you want , if you spend some time on the  STEERING QUADRANT  , on that set up , lubricating its function and detail its spring loaded lock pin , slide area ,that blade will rotate / swing with little effort , set up mine on 2 milk crates , one on frame end , other just behind steering area  , letting you easily roller stool around it and verify its set up ease.  best thing about doing it this way , is that it will move the same way on your horse. , also detail in your lever swing handle , lubricate as you go . just an idea , pete
Brockport Bill
thanks for that perspective Peter - I have had a 48 for a 312-8 - and took pretty good care of it, but we can always do better with our maintenance and a few good tips from others experience is always helpful - so now I was planning a 48 plow with a C175 hoping to save my L4-5 lower back leaning forward from the manual arm on a 312-8 -- and start to use a power lift from a C175 -- so needed the confirmation from the brain trust here for what plow properly fits a C175 -- thanks again - Bill - As an after thought, i have just in recent years learned the benefit of anti seize as well as white lithium lubricants
