tractorbeast
C-125 snow blade mods for easier lifting
tractorbeast
has anyone did mods to their C series, or any other for that matter, for an idea to make a snow blade easier to lift for an older guy with a rotten left shoulder. Its a 48" blade which is heavy on its own. I have a 42" but I wouldn't think 6" less steel is really going to help enough. (I could be wrong about that though) The right side angle adjustment is not a problem for me. No hydro on my snow plow tractor
ebinmaine
A linear actuator motor would be a home built version of the electric lift.
Could be mounted at the front of the tractor.
Jeff-C175
I've been thinking about the same thing since mounting my plow (the 42" is just as heavy) on my C-125.
I used to run it on my 175 which has hydro lift which the 125 lacks.
I was actually shocked at how much effort is required to manually lift that thing!
I'm thinking of a lift assist spring like on the snow throwers, but not sure if lightening the plow is a good idea.
rjg854
Do you have a lift assist spring for your blade?
Moparfanforever
Is there such a thing as a spring to help lift the blade??
Jeff-C175
Where would that be installed?
rjg854
It attaches to the flag, and the rod that holds the foot pedals
tractorbeast
That I'm not sure about. Not sure where it would be.
rjg854
Wheel horse parts and more sells them
Jeff-C175
On a blade?  You're not thinking of the BLOWER, are you?
tractorbeast
rjg854 - thank you for your answers
rjg854
I was thinking snowblower, never mind :laughing-rolling:
Jeff-C175
But there must be a way to engineer and install a spring I think, just not sure how badly it would affect operation of the plow.
Can't make the plow too light!
tractorbeast
I have a few actuator's from lift chairs. Has anyone seen this type system installed and have a picture possibly.
Jeff-C175
I would really like a foot pedal control for raising and lowering the blade.
ebinmaine
@KrazeyOlDave and I were shooting the breeze about this at one point.
I can try to contact him if he doesn't answer here.
A bracket could be made at the front to hold the actuator.
Neat idea.
  • Like 3
tractorbeast
Now that would be nice!!!
roadapples
Hydrostatic with lift are so much nicer as we get older....:twocents-twocents:
  • Like 4
Gregor
How much weight are we talking about lifting for the actuator? Not the weight if the entire plow, but how much to actually lift.
ebinmaine
The setup I'm considering lifts the entire plow.
ebinmaine
No real info in this thread but it shows a pic.
Edited by ebinmaine
  • Thanks 1
elcamino/wheelhorse
@KrazeyOlDave Sold me his actuator lift unit , I have not installed due to many life problems. He probably still has pictures. I will try to photo parts this weekend.
  • Thanks 1
peter lena
@tractorbeast  some  pictures of the added springs on my  horse, easy to add eye bolts and springs on front end, just some of the things i use , pete
rjg854
Peter you're making the same mistake I made, he's taking about his snow plow.
peter lena
 @rig854, notice the eye bolts on the bottom of the hood  mount ? have those on my horses , always a place to add a spring to , add a matching eye bolt  to the frame mount , with turnbuckle , dial in what you want , this is not difficult , pete
