Jrain 276 #1 Posted December 9, 2021 Howdy all ,Well I Stopped by my scrap buddy place and low and behold had to rescue another one from his cutting torch , Seems to be a 1973 Automatic 16 , everything seems solid even the steering is nice and tight , the mule is there but no deck ,engine spins free . tires are pretty good also , fluids do not look bad , all hydraulic parts are in tack, missing the fuel tank but other then that seems like a nice solid unmolested WH . Have not had the chance to finish the Hydraulics on my C120 so need to get to that first before I start reviving this one , my plan was to finish the C120 test my home made gravel road grader with it , then break down the c120 for paint ,but I will hold of on the break down and paint, get this Auto 16 up and running then tear them both down and paint them at the same time . 6 16 1 Share this post Link to post Share on other sites
roadapples 6,983 #2 Posted December 9, 2021 Great tractor. And if it's going to be stored inside you can keep the patina. Paint is over rated..... 4 1 Share this post Link to post Share on other sites
ebinmaine 67,594 #3 Posted December 9, 2021 Excellent save! Very highly desirable model for those that know what they're looking for... 4 Share this post Link to post Share on other sites
D_Mac 8,620 #4 Posted December 9, 2021 I agree about holding off on painting it. Power wash it and break out the elbow grease. That paint will clean up nicely. 4 Share this post Link to post Share on other sites
Skwerl58 704 #5 Posted December 9, 2021 Nice save! I see that it has the clevis hitch and with hydro lift that is a plus! I would love to have a lift one on my 414-8 when I am using the garden equipment. 5 Share this post Link to post Share on other sites
Sodaking27 777 #6 Posted December 9, 2021 Great save. Looks to be in really good shape. 3 Share this post Link to post Share on other sites
Jrain 276 #7 Posted December 9, 2021 2 minutes ago, sodaking27 said: Great save. Looks to be in really good shape. It is in nice shape ,but we shall see how the engine and drivetrain are after I go through it ,seem to be all there but will be on the hunt for a fuel tank 4 Share this post Link to post Share on other sites
ebinmaine 67,594 #8 Posted December 9, 2021 2 minutes ago, Jrain said: fuel tank Horses used the same tank from around 1968 up to 1977. Only difference is early ones were red and the rest were black. I like the look of the older metal tanks so I'll likely have a plastic one for sale sometime fairly soon. 4 Share this post Link to post Share on other sites
chip61 658 #9 Posted December 9, 2021 Nice!! That looks better than the C160 that I use all the time. Great machine, glad you were able to save it. 3 Share this post Link to post Share on other sites
Jrain 276 #10 Posted December 9, 2021 12 minutes ago, ebinmaine said: Horses used the same tank from around 1968 up to 1977. Only difference is early ones were red and the rest were black. I like the look of the older metal tanks so I'll likely have a plastic one for sale sometime fairly soon. Yes I assumed that because it has the same hold down bracket as my C120 But yes keep me in mind if you put one up for sale . Cheers 2 Share this post Link to post Share on other sites
Moparfanforever 851 #11 Posted December 9, 2021 It is great you saved another WH , what a powerhouse!! 5 Share this post Link to post Share on other sites
pfrederi 17,741 #12 Posted December 9, 2021 36 minutes ago, ebinmaine said: Horses used the same tank from around 1968 up to 1977. Only difference is early ones were red and the rest were black. I like the look of the older metal tanks so I'll likely have a plastic one for sale sometime fairly soon. Actually Eric they used at least 3 different tanks these are all 68/69 Chargers The steel tank is small and since she now has a k-341 and a blower it doesn't last long. Can't swap tanks as the hood stand is different the shelfi s too short... 3 1 Share this post Link to post Share on other sites
kpinnc 12,085 #13 Posted December 9, 2021 I'm always looking for a C-160, and you find one in a scrap heap? You did well! 4 2 Share this post Link to post Share on other sites
ebinmaine 67,594 #14 Posted December 9, 2021 20 minutes ago, pfrederi said: 68/69 Chargers That plastic tank with the sideways strap. That's how my 70 Charger was set up when I got it. I was looking at that tank and that strap the other day in the shed wondering how that worked. Pretty cool to see the differences there. Thanks for posting those pics. 3 Share this post Link to post Share on other sites
sparkie333 265 #15 Posted December 9, 2021 (edited) 3 hours ago, Jrain said: Howdy all ,Well I Stopped by my scrap buddy place and low and behold had to rescue another one from his cutting torch , Seems to be a 1973 Automatic 16 , everything seems solid even the steering is nice and tight , the mule is there but no deck ,engine spins free . tires are pretty good also , fluids do not look bad , all hydraulic parts are in tack, missing the fuel tank but other then that seems like a nice solid unmolested WH . Have not had the chance to finish the Hydraulics on my C120 so need to get to that first before I start reviving this one , my plan was to finish the C120 test my home made gravel road grader with it , then break down the c120 for paint ,but I will hold of on the break down and paint, get this Auto 16 up and running then tear them both down and paint them at the same time . Great save---I'm looking for a muffler and set up just like yours. ---Can you show how the automatic works as to where to go forward and reverse Thanks My 76 C160 automatic has a leaver right by my right leg --I can grab on to it and rest my hand on my knee so I can go forward or reverse as quick as a rabbit. I kinda like these tractors. Edited December 9, 2021 by sparkie333 my othe left 2 Share this post Link to post Share on other sites
953 nut 55,298 #16 Posted December 10, 2021 4 hours ago, Jrain said: will be on the hunt for a fuel tank Wouldn't be to hard to come by. Perhaps @Pullstart, @Ed Kennell or @daveoman1966 may have one. 2 Share this post Link to post Share on other sites
ohiofarmer 3,276 #17 Posted December 10, 2021 On the paint it not to paint issue, there is a middle ground of sorts.. Paint the wheels. Not white, but linen white. If the inside of the wheels are oily or black on the rear, replace the oil seals. Patina tractors look well ordered with nice wheels Stage two paint for me would be wheels plus the tins. Then paint the cast iron and frame rails with a brush. Rust-Oleum red primer will forgive a bit of oil and still cover. For me it's just not worth it to paint between the spaces under the tractor. Unless it produces satisfaction knowing that everything is perfect. 4 Share this post Link to post Share on other sites
Pullstart 62,905 #18 Posted December 10, 2021 I believe I do have a plastic tank recently pulled from a C-160 Auto. 4 Share this post Link to post Share on other sites
ZXT 2,401 #19 Posted December 10, 2021 11 minutes ago, Pullstart said: I believe I do have a plastic tank recently pulled from a C-160 Auto. Whats it gonna have for a tank if you get rid of it? Also, Jrain, super find... Hydro lift, clevis hitch, and an electric PTO. That my friend is a very useful tractor. 2 Share this post Link to post Share on other sites
Retired Wrencher 5,465 #20 Posted December 10, 2021 (edited) 17 hours ago, roadapples said: Great tractor. And if it's going to be stored inside you can keep the patina. Paint is over rated..... Agreed! Only original one time plus it is a hassle. I think just use it and enjoy it. I only rub in Marvel on all Wheel Horse equipment. Edited December 10, 2021 by Retierd Wrencher 2 Share this post Link to post Share on other sites
Jrain 276 #21 Posted December 10, 2021 (edited) 20 hours ago, kpinnc said: I'm always looking for a C-160, and you find one in a scrap heap? You did well! So this is my second save about 6 montha ago I saved a c120 witch I kept , and a B-80 witch I got running and sold , My long time friend does scrap for a living and over the years I watch him cut up so much good stuff then off to the scrapers , he only sees type of metals and weight in his words IT ALL JUNK , I have rescued over the year everything from ford 2n , 8n , 9 n tractors to cars trucks motorcycle ATVs ,old drill presses ,old band saws all kinds of tools, people throw away good stuff , most stuff I fix and sell other stuff I keep like, I kept a 10k generac Generators 67 hrs on it cleaned the carb runs like a dream , I can not tell you how many garden tractors I have seen cut up by him over the years hundreds maybe a thousand , I never though about saving garden tractors till I took a recent interest in them because I wanted something to maintain my gravel road and driveway , I7 years prior I grabbed a Toro wheel horse 212-5 mower from him got it running and been cutting my grass with it ever since ,So Wheel horse was what I wanted since I new they were good tractors . He know now to call me when he gets a WH . a few pics of WH I saved so far Edited December 10, 2021 by Jrain add pictures 3 4 Share this post Link to post Share on other sites
kpinnc 12,085 #22 Posted December 10, 2021 I sometimes have to remind myself that the majority of people just have no mechanical aptitude whatsoever, and don't know the difference between a garden tractor that can't be replaced and a Murray mower with shiny paint. Big box stores have made billions off these folks. Not saying these people are stupid or anything, but they are kinda stupid! 5 1 Share this post Link to post Share on other sites
Handy Don 12,235 #23 Posted December 10, 2021 (edited) 1 hour ago, kpinnc said: I sometimes have to remind myself that the majority of people just have no mechanical aptitude whatsoever, and don't know the difference between a garden tractor that can't be replaced and a Murray mower with shiny paint. Big box stores have made billions off these folks. Not saying these people are stupid or anything, but they are kinda stupid! I'm often tempted to think along these lines until I realize that I have no aptitude whatsoever for so many things--chemistry, office politics, understanding "illogical (as defined by me)" people, and choosing color schemes come to mind but there are many others. I'm very rudimentary at cooking or planning meals, as another example, but I love to eat food prepared by others and am happy to clean up the kitchen. One of my closest friends is now bedridden at home and I went to do some cleaning to lighten the load on his caregiving spouse. I discovered their vacuum cleaner has a broken beater bar belt. The spouse said "Ah, that hasn't worked well for a while. Should I buy a new one?" She has a flip phone and carries an address book because adding speed dial numbers to the phone is beyond her. She is an artist and has created some amazing pieces but in her mind a broken vacuum is simply something to replace and a phone is to dial and receive calls. Pretty sure pretty much any RS member could replace the belt for about $10 and that's what I'll do. I do agree though, that the "mechanical" gene is not widespread. Edited December 10, 2021 by Handy Don 6 Share this post Link to post Share on other sites
Jrain 276 #24 Posted December 11, 2021 2 hours ago, Handy Don said: I'm often tempted to think along these lines until I realize that I have no aptitude whatsoever for so many things--chemistry, office politics, understanding "illogical (as defined by me)" people, and choosing color schemes come to mind but there are many others. I'm very rudimentary at cooking or planning meals, as another example, but I love to eat food prepared by others and am happy to clean up the kitchen. One of my closest friends is now bedridden at home and I went to do some cleaning to lighten the load on his caregiving spouse. I discovered their vacuum cleaner has a broken beater bar belt. The spouse said "Ah, that hasn't worked well for a while. Should I buy a new one?" She has a flip phone and carries an address book because adding speed dial numbers to the phone is beyond her. She is an artist and has created some amazing pieces but in her mind a broken vacuum is simply something to replace and a phone is to dial and receive calls. Pretty sure pretty much any RS member could replace the belt for about $10 and that's what I'll do. I do agree though, that the "mechanical" gene is not widespread. So agree ,I do not want o get on my soap box here but here I go, in short we do not produce hardly anything here anymore , So no manufacturing , No wood shops ,metal shops In the schools today. so a young person never even get the chance to see if they have Mechanical aptitude . Most people have no clue about anything if something stops working 90 percent of the time they throw it out , Most people today do not even have a clue how the world works , they do not even know where there food they buy in the store comes from .I had a apprentice one that did not even know where milk comes from seriously had no clue he thought it just appeared in the store, Life has been made to easy for people today , I saw a video recently of a father who set up a old rotary phone in his living room then called his 20 yr old Son and his sons friend in to the room and he asked them to make a call from the phone neither of them could not figure out how to dial a phone number and make a call , I remember when your TV stopped working my dad would take the Tubes out we would go to the drug store to test them if one of the tubes were bad they would unlock the bottom of the tube testing unit and sell you a new tube. 7 Share this post Link to post Share on other sites
Handy Don 12,235 #25 Posted December 11, 2021 Soapboxes are useful. I appreciate the reply! I'm struggling with many of the concerns you raised. I worked with and taught my children, as did my Dad during visits. They each took a small, well-equipped toolbox with them to college. (The art major was hanging an exhibit and pulled out her level--the other students were astounded. "You have your own level?!") What I haven't figured out is how to reach and guide the kids that would be great candidates to learn, and earn a good living from, a manual trade. 2 2 Share this post Link to post Share on other sites
