ilovemy1974b80
What torque should I torque my wheel for my 1974 b80
ilovemy1974b80
What should I torque my wheel for a 1974 b80
ebinmaine
Standard bolt torque spec off charts shows 37 lb or so for a grade 5 7/16 is fine.
I usually go ahead more than that...
ilovemy1974b80
I’ll just play it safe and go with what you said
thank you
8ntruck
37 ftlb for 7/16 grade 5 bolts sounds about right.  You should go back and re check the torque after a couple hours of operation.
If you have grade 8 bolts/studs, you could go to 80 ftlb.
ebinmaine
Oh good call.
I do that and forgot to mention it.
Retired Wrencher
thank you
I have a battery powered impact [not very strong] when, it makes good contact done. Double check with a breaker bar. Use the crisscross method = top bottom left right and so on.
Edited by Retierd Wrencher
Pullstart
Crank it ‘til it snaps, then back off half a turn :handgestures-thumbupright:
In all honesty, we’re going 7 mph or less in most instances.  Tight is tight… I just have that “feel” for tight.  I’ve never torqued a wheel stud on a garden tractor and don’t ever plan to.
  • Heart 1
lynnmor
Many people develop a feel for correct tightness, others strip threads and snap bolts.  A torque specification can be very helpful in preventing failures.
Edited by lynnmor
ebinmaine
28 minutes ago, lynnmor said:
Many people develop a fell for correct tightness, others strip threads and snap bolts.  A torque specification can be very helpful in preventing failures.
I am most certainly guilty of over tightening fasteners of many types on many occasions.
Trina assures me there is a difference between Regular Tight and Bear Tight..... that is why I use a torque wrench.
:lol:
Jeff-C175
There's a joint in my wrist that 'snaps' at 30 foot pounds.  I wish it was adjustable!
  • Haha 3
Retired Wrencher
Regular Tight and Bear Tight.   I hear you on that. But as we get older, I think you have a better feel because we have less muscle. When I was young, I had the Bear tight to many times.  :ranting::angry-banghead:
rjg854
Agree whole heartily!  These aren't HP vehicles, I tighten my lugs with A 1/4" impact driver. I try to make sure I don't over tighten them, but have yet to lose any. And highly doubt I ever will.
RED-Z06
I use a Porter Cable 1/2 impact on rear lugs, 1/4 impact on front bolts.
Rear 3 ugga duggas
Front 3 iggy diggys
  • Haha 1
ebinmaine
Rear 3 ugga duggas
Front 3 iggy diggys
I believe @Pullstartapproves of this method.
Pullstart
Rear 3 ugga duggas
Front 3 iggy diggys
absolutely acceptable, except I highly recommend 4 of each unless you’re running an M18 Milwaukee.  Then 2 of each is sufficient.  :teasing-poke:
RED-Z06
With how Milwaukee ripped me off id never own another one.
  • Sad 2
RED-Z06
I bought their super fancy high end 5" grinder, 11amps, digital speed governor, cut-off guard and grinder guard.  It was like 225 bucks in a time when you could getca Dewalt for 55.  So...i used it to sharpen a couple blades...worked great.  Next day..wouldn't come on.  Took it apart, armature tested good, had 120vac coming into the printed circuit board, no power out.
Contacted Milwaukee...they said if your power input is over 120vac it will burn up the board...mine tested at 124vac in my shop.  They said I could buy the part for 105 shipped or ship it to them on my dime and pay for the part and it would be $145 to fix.
I put it in the trash.. bought my porter cable grinder, plugged it into the same outlet and ive sharpened easily 1200 blades with it...not one issue.  Cousin bought an M18 Fuel drill and the thing broke the gearbox wirh a 1" paddle bit in wood, he hammers in pipes to move around logs.  Milwaukee told him it must be abuse...no warranty...so he bought a Makita, same bit...hundreds of holes, no problems.
I know people swear by Milwaukee tools but...
  • Sad 1
rjg854
I swear by mine, they've never failed me.  :teasing-neener:
  • Haha 1
Jeff-C175
TOTAL BS from them. No question about it.  Probably over half the US has a nominal AC voltage above 120 VAC.  Mine is typically above 125.
They would not, and could not, have gotten agency certification (like UL or Underwriters) if it burns out above120 VAC.
You were being fed a line of crap.
RED-Z06
Oh i know..heck i used to goose up my generator to 130vac for more zing on my old power tools and never had any electrical problems.  124 should be well within parameters
Snoopy11
<_< HellHorse -_-
:auto-layrubber:     :-D
Don
Snoopy11
As is mine... except for when the power goes out... then it is like .1... :ychain:
:laughing-rolling:
Don
Pullstart
I believe electrical standard of testing is operation between 80% and 120% of rated power.  :handgestures-thumbupright:
  • Heart 1
Roger R
Used Milwaukee power tools for over 50 years, with no problems. Incidentally I have one of the last all metal drill motors they ever made, before plastic frames.  The problem is there is no variable speed control, and no reverse.  I bought it new when they were closing them out, Needless to say it has seen very little use, but it's a nice old relic.
Jeff-C175
I've got an old Milwaukee Sawzall that has seen LOTS of service over the past 40 some odd years.  About ten years ago the variable speed circuit gave up and only had full or none.  I called MW and they sent me a new trigger assembly for FREE!
