OutdoorEnvy
20hp single cylinder Kohler K engine - What do you know?
OutdoorEnvy
So someone near me is selling a 20hp single cylinder kohler engine dirt cheap.  Looks good shape and the price would be right for a possible project and taking a risk on.  I haven't ever seen one before and didn't know they existed until I saw this one.  It came off a large generator.  Wanted to see if any of you know about these and would this be feasible to put on a Wheel Horse?
Achto
Never heard of such a thing in K or M model Kohler. Do you have the model & spec number off from the engine. Just wondering if it is actually a 16hp?
I've had a run in with the newer aluminum block 20hp, single cylinder, Kohler. That engine ain't worth it's weight in scrap. :handgestures-thumbdown: Thin wall block prone to cracking, oil leaks out, rod breaks, then you have an extra vent hole in the block.
Edited by Achto
  • Like 4
ebinmaine
I hadn't heard of one either...
Overhead valve? Could it be an 18 horse?
Definitely going to want to get some numbers from the tag off of that engine.
RED-Z06
K series went to 18hp K361
M singles went to 16hp M16
Commands went to 18hp vertical and 16hp horizontal.
Twins came in at 18hp.
Its either not 20hp or its not a single.
Hey i bought a K3500 dually Sierra that a guy owned for 7 years and never knew it was 4x4 until i showed him...
  • Like 5
  • Sad 1
Maxwell-8
Must be quite a big engine.
I know Lombardini  made 20hp single cylinder air-cooled diesels, but never heard of a Kohler.
WHX??
Got pics?
pfrederi
Guess they didn't make too many K361.  Only 12 spec numbers and no parts listings at the Kohler site....
pfrederi
It was an overhead valve
Maxwell-8
:text-yeahthat: with the sardines can on top
RED-Z06
Yes.. and plagued with head issues, if they didnt blow the head gasket they dropped a valve seat, iron K series block modified to accept external push rog tubes and accept an aluminum ohv head.
Edited by RED-Z06
Gregor
ereplacementparts shows limited parts still available.
pfrederi
Most of the items related to the OHV are NLA
