elcamino/wheelhorse 9,360 #26 Posted December 5, 2021 3 hours ago, squonk said: That's "easy' for you to say! You still haven't answered the question. 1 Share this post Link to post Share on other sites
slim67 2,744 #27 Posted December 5, 2021 I was rearranging my garage for more floor space these last few days. While working out there today , I took a break and looked over the 1054. My curiosity got the best of me so I grabbed a battery out of one of my other tractors and put it in the 1054. Usually “ running when parked” can be a bad thing. The kill switch has some two prong key which I don’t have. I jumped an alligator clip from the hot side to the coil and added some fresh gas. After a little bit , it started running rough then cleared out. I even took it for a little drive but the kingpins badly need replaced so back to the garage. In the coming weeks I will give it a thorough going over. 2 4 Share this post Link to post Share on other sites
squonk 42,584 #28 Posted December 5, 2021 It doesn't hit if I take the steering wheel off. 4 Share this post Link to post Share on other sites
ebinmaine 70,802 #29 Posted December 5, 2021 12 minutes ago, squonk said: It doesn't hit if I take the steering wheel off. I promise I'm laughing with you, not at you. You've seen my me. Share this post Link to post Share on other sites
953 nut 57,998 #30 Posted December 6, 2021 55 minutes ago, slim67 said: even took it for a little drive Glad you got them and they are better than expected. The 1054 may actually be a 1054A based on the wider rims. If the serial number on your 1054 is in the high 049XXX to low 050XXX range it is probably the 1054A. Same tractor except for the wider front and rear tires and wheels. Kainer Boats used a white steering wheel that was a twin to the , could it be? Take a picture of it so some eagle eyed member can ID it for you. 1 Share this post Link to post Share on other sites
slim67 2,744 #31 Posted December 6, 2021 49 minutes ago, 953 nut said: Glad you got them and they are better than expected. The 1054 may actually be a 1054A based on the wider rims. If the serial number on your 1054 is in the high 049XXX to low 050XXX range it is probably the 1054A. Same tractor except for the wider front and rear tires and wheels. Kainer Boats used a white steering wheel that was a twin to the , could it be? Take a picture of it so some eagle eyed member can ID it for you. Thanks Richard, the serial tag is gone on the 1054. How rare were the As? Share this post Link to post Share on other sites
WHX?? 50,778 #32 Posted December 6, 2021 Nice score Slim . Never ceases to amaze me what with a bit of tickling one can get these girls to run and even drive. I picked up two 953' a couple of years ago and hope to get one out of them someday They do make for just an awesome plow mule you get her set up tuned proper. Hosen @Pullstart and Tom @Shynon can attest to that. Kev set his daughter on Tom's one year and couldn't get her off! Next year Hosen showed up with a couple of 953/1054's. That didn't turn out so hot. Well actually it did turn out hot! Wiring short ended the fun real quick. 2 2 1 Share this post Link to post Share on other sites
slim67 2,744 #33 Posted December 6, 2021 10 hours ago, WHX?? said: Nice score Slim . Never ceases to amaze me what with a bit of tickling one can get these girls to run and even drive. I picked up two 953' a couple of years ago and hope to get one out of them someday They do make for just an awesome plow mule you get her set up tuned proper. Hosen @Pullstart and Tom @Shynon can attest to that. Kev set his daughter on Tom's one year and couldn't get her off! Next year Hosen showed up with a couple of 953/1054's. That didn't turn out so hot. Well actually it did turn out hot! Wiring short ended the fun real quick. I saw the video of Kevin’s daughter motoring along like it was nothing. I was wondering what all the smoke was in the pic of the Kevin’s ride out in the field. I’ve noticed a lack of wheel weight holes so I’m going to inquire with some of the local tire companies on getting two filled. 1 Share this post Link to post Share on other sites
Pullstart 64,620 #34 Posted December 6, 2021 10 hours ago, WHX?? said: That didn't turn out so hot. Well actually it did turn out hot! Wiring short ended the fun real quick. That’s all about to change hopefully sooner than later! We have a good selection of running long blocks and 6/8 speed transmissions. And a blank slate for wiring! and fuses! 1 1 Share this post Link to post Share on other sites
WHX?? 50,778 #35 Posted December 6, 2021 (edited) 36 minutes ago, slim67 said: I’ve noticed a lack of wheel weight holes so I’m going to inquire with some of the local tire companies on getting two filled. Yes weights were specific to 953/1054 and rare as hens teeth. Tire loading is a good option and very easy to DIY. Lots of threads here on doing it. Edited December 6, 2021 by WHX?? 1 Share this post Link to post Share on other sites
953 nut 57,998 #36 Posted December 6, 2021 11 hours ago, slim67 said: Thanks Richard, the serial tag is gone on the 1054. How rare were the As? The 1045-A was just a continuation of the 1964 1054 run. We have no production numbers and the decal on the hood sides was 1054 so it is hard to say how many were produced. The only difference I am aware of is the wider rims and tires. If the established Wheel Horse numbering system had been used on this model it would have been a 1055 but that number was used on the new square hood ten horse power tractor being introduced. Garry @gwest_ca has compiled serial numbers for various models but we can't be sure that all numbers in a sequence were used exclusively for that model. if they were then there were 1,000 first generation 953s, 850 second generation 953s, 600 third generation 953s, 7,000 1054s and 1,000 1054-As This is total speculation and we have no factory production figures to back it up. 1 3 Share this post Link to post Share on other sites
slim67 2,744 #37 Posted December 6, 2021 1 hour ago, 953 nut said: The 1045-A was just a continuation of the 1964 1054 run. We have no production numbers and the decal on the hood sides was 1054 so it is hard to say how many were produced. The only difference I am aware of is the wider rims and tires. If the established Wheel Horse numbering system had been used on this model it would have been a 1055 but that number was used on the new square hood ten horse power tractor being introduced. Garry @gwest_ca has compiled serial numbers for various models but we can't be sure that all numbers in a sequence were used exclusively for that model. if they were then there were 1,000 first generation 953s, 850 second generation 953s, 600 third generation 953s, 7,000 1054s and 1,000 1054-As This is total speculation and we have no factory production figures to back it up. Thanks for sharing the info Richard 3 Share this post Link to post Share on other sites
Retired Wrencher 5,651 #38 Posted December 8, 2021 On 12/5/2021 at 8:39 AM, ebinmaine said: Seems by the pics I've seen @19richie66 is a member of the "not short" club too. Perhaps he can lend advice. Have to agree with you two on this. I guess that is why I never owned a round hood. Too small for me. 1 Share this post Link to post Share on other sites
ebinmaine 70,802 #39 Posted December 8, 2021 3 minutes ago, Retierd Wrencher said: Have to agree with you two on this. I guess that is why I never owned a round hood. Too small for me. I've sat on one. Imagine what THAT looks like... Share this post Link to post Share on other sites
Retired Wrencher 5,651 #40 Posted December 8, 2021 Just now, ebinmaine said: I've sat on one. Imagine what THAT looks like... I am not knocking them Eric they have a cool look all their own and a place in history of tractors. But just not for us. 1 Share this post Link to post Share on other sites
ebinmaine 70,802 #41 Posted December 8, 2021 Just now, Retierd Wrencher said: I am not knocking them Eric they have a cool look all their own and a place in history of tractors. But just not for us. Absolutely agreed 1 Share this post Link to post Share on other sites
slim67 2,744 #42 Posted December 8, 2021 33 minutes ago, Retierd Wrencher said: Have to agree with you two on this. I guess that is why I never owned a round hood. Too small for me. You should see me on an RJ 59! Beleive it or not , that little tractor actually did wheelies pulling a bottom plow. I could probably use the front axle as a footrest. 2 Share this post Link to post Share on other sites
ebinmaine 70,802 #43 Posted December 8, 2021 10 minutes ago, slim67 said: You should see me on an RJ 59! Beleive it or not , that little tractor actually did wheelies pulling a bottom plow. I could probably use the front axle as a footrest. I didn't try it but I think I'd be pretty close. On my big tractor build there is a 7" extension between the frame and transmission. Still, I can easily put my feet on the foot pegs. Share this post Link to post Share on other sites
Pullstart 64,620 #44 Posted December 8, 2021 1 hour ago, Retierd Wrencher said: Have to agree with you two on this. I guess that is why I never owned a round hood. Too small for me. 1 hour ago, ebinmaine said: I've sat on one. Imagine what THAT looks like... Just a guess… something like this? 1 3 Share this post Link to post Share on other sites
ebinmaine 70,802 #45 Posted December 8, 2021 7 minutes ago, Pullstart said: this You're headed the right way 1 Share this post Link to post Share on other sites
953 nut 57,998 #46 Posted December 8, 2021 6 minutes ago, Pullstart said: something like this? No, actually it would be more like this. 1 1 1 5 3 Share this post Link to post Share on other sites
ebinmaine 70,802 #47 Posted December 8, 2021 28 minutes ago, 953 nut said: No, actually it would be more like this. YA NAILED IT !! 1 1 Share this post Link to post Share on other sites
19richie66 17,581 #48 Posted December 8, 2021 You should try one of these Yeah I know it’s the wrong color. That will be fixed later. I have 3 of these things. 1 6 Share this post Link to post Share on other sites
slim67 2,744 #49 Posted December 8, 2021 (edited) 1 hour ago, 19richie66 said: You should try one of these Yeah I know it’s the wrong color. That will be fixed later. I have 3 of these things. Cool. Is that a Huffy? You may have been better off with the motor cycle powered golf cart! Edited December 8, 2021 by slim67 Share this post Link to post Share on other sites
ebinmaine 70,802 #50 Posted December 8, 2021 2 hours ago, 19richie66 said: You should try one of these Yeah I know it’s the wrong color. That will be fixed later. I have 3 of these things. Man of STEEL right there ladies and gentlemen. 1 1 Share this post Link to post Share on other sites
