sparkys toy 76 #1 Posted December 4, 2021 (edited) Just acquired a k301 powered by natural gas and want to change it to l.p. is there a different orfice in the carb to change or just carb adjustments required Edited December 4, 2021 by sparkys toy Added picture 1 Share this post Link to post Share on other sites
8ntruck 7,016 #2 Posted December 4, 2021 Might be a different head, too. The ideal compression ratio for natural gas is probably different than for gasoline. Share this post Link to post Share on other sites
Handy Don 12,235 #3 Posted December 4, 2021 I've helped one friend convert a B&S generator to natural gas using a kit from this company. Went very smoothly and no changes to head needed. 2 Share this post Link to post Share on other sites
Jeff-C175 7,202 #4 Posted December 4, 2021 Pretty sure just an orifice change. Not sure how to determine the correct size, but the orifices should be readily available. 2 Share this post Link to post Share on other sites
sparkie333 265 #5 Posted December 4, 2021 Hay --that thing don't look like a K301 that I ever seen.--- O I was looking first at your air compressor--- You do mean the red one? 1 2 Share this post Link to post Share on other sites
Pullstart 62,906 #6 Posted December 4, 2021 2 hours ago, Jeff-C175 said: Pretty sure just an orifice change. Not sure how to determine the correct size, but the orifices should be readily available. heating value of natural gas I believe is 1050 or so and LP is 2500. LP Runs 10” of water column generally and natural is about 4 or 4.5”. That should be enough to figure orifice size, shouldn’t it? 1 Share this post Link to post Share on other sites
sparkie333 265 #7 Posted December 4, 2021 45 minutes ago, Pullstart said: heating value of natural gas I believe is 1050 or so and LP is 2500. LP Runs 10” of water column generally and natural is about 4 or 4.5”. That should be enough to figure orifice size, shouldn’t it? Well u going to let us know what size it would take? I Just didn't get that far in school---Just saying--- 2+2 = for sure not a 2x4 3 Share this post Link to post Share on other sites
Pullstart 62,906 #8 Posted December 4, 2021 That’s about all I remember on the topic @sparkie333… sorry! Share this post Link to post Share on other sites
Handy Don 12,235 #9 Posted December 4, 2021 You'll also have to figure in the regulator which might be different for the two gases and probably results in having similar pressure going into the carb oriface. In the kit there was a gadget that required the engine turning and pulling air through the carb before it would hold the gas valve open. It had a manual override for starting. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,046 #10 Posted December 4, 2021 LP fuel starts on page 6-23 1 1 1 Share this post Link to post Share on other sites
sparkys toy 76 #11 Posted December 5, 2021 Thanks for all the input hadn't thought about the regulator differents this one does have a prime button and a watercolum gauge on it as well, it should be fun having a l.p. powered wheel horse will be interesting how fast it will run through a 1 lb can of lp 1 Share this post Link to post Share on other sites
Jeff-C175 7,202 #12 Posted December 5, 2021 18 minutes ago, sparkys toy said: 1 lb can Ya mean the little tanks for propane torch? Ten, fifteen minutes? If yer lucky. 1 Share this post Link to post Share on other sites
sparkys toy 76 #13 Posted December 5, 2021 6 hours ago, Jeff-C175 said: Ya mean the little tanks for propane torch? Ten, fifteen minutes? If yer lucky. At idle I suppose,lol 1 Share this post Link to post Share on other sites
kpinnc 12,087 #14 Posted December 6, 2021 (edited) Well, you could fab up some axles and a hitch on a 100lb bottle. The good thing about our tractors (should you use the engine for one) is that they have the gearing to pull a huge tank behind them! And the internals of an LP or NG engine will be very, very clean! Edited December 6, 2021 by kpinnc Share this post Link to post Share on other sites
Handy Don 12,235 #15 Posted December 6, 2021 11 hours ago, kpinnc said: Well, you could fab up some axles and a hitch on a 100lb bottle. The good thing about our tractors (should you use the engine for one) is that they have the gearing to pull a huge tank behind them! And the internals of an LP or NG engine will be very, very clean! @ebinmaine, what size are the gas bottles on the forklifts you tool around on? How long do they last? Propane, right? 1 Share this post Link to post Share on other sites
ebinmaine 67,596 #16 Posted December 6, 2021 1 hour ago, Handy Don said: @ebinmaine, what size are the gas bottles on the forklifts you tool around on? How long do they last? Propane, right? We have two types of fuel for two different types of forklifts here. The ones I run on a daily basis are diesel powered and they are for outside use ONLY. The other ones are propane, yes. I believe the tanks on those are around 30 lb capacity. I don't know how long they last because I don't change them out. I'm not certified by the company to do so. They are the same size and shape as the larger of the two tanks that I commonly see on an RV. Share this post Link to post Share on other sites
Jeff-C175 7,202 #17 Posted December 6, 2021 22 minutes ago, ebinmaine said: larger of the two tanks that I commonly see on an RV. I think that may be 50 lbs. The small ones for the gas grills are 30 lb. Then there's the taller ones at 100 lb. As I recall the FL that I drove for a few years back in the late 1900s had 50 pounders. They would last for a few days of two shifts a day. 1 Share this post Link to post Share on other sites
ebinmaine 67,596 #18 Posted December 6, 2021 8 minutes ago, Jeff-C175 said: I think that may be 50 lbs. The small ones for the gas grills are 30 lb. Then there's the taller ones at 100 lb. As I recall the FL that I drove for a few years back in the late 1900s had 50 pounders. They would last for a few days of two shifts a day. That may be regional or state law differences. Here the smaller ones are referred to as 20 lbs and the bigger ones are referred to as 30. Of interest is the fact that I've known for years and 30 lb tank as we call them, weighs a heck of a lot more than that... also seem to get heavier as I get older. 😂 1 1 2 Share this post Link to post Share on other sites
kpinnc 12,087 #19 Posted December 6, 2021 1 hour ago, ebinmaine said: Of interest is the fact that I've known for years and 30 lb tank as we call them, weighs a heck of a lot more than that... also seem to get heavier as I get older. Can't remember who said it- but similar to the theory of relativity: as time passes gravity increases or something? What was I talking about? 1 4 Share this post Link to post Share on other sites
ebinmaine 67,596 #20 Posted December 6, 2021 31 minutes ago, kpinnc said: What was I talking about? Baked beans? 3 Share this post Link to post Share on other sites
SylvanLakeWH 25,600 #21 Posted December 7, 2021 6 hours ago, kpinnc said: Can't remember who said it- but similar to the theory of relativity: as time passes gravity increases or something? What was I talking about? 5 hours ago, ebinmaine said: Baked beans? Theory of too much Relative-ity: As more time passes with relatives, the need for baked beans increases, until they succumb to the fumes and leave. At which time you can resume talking about ‘s. 1 2 Share this post Link to post Share on other sites
ebinmaine 67,596 #22 Posted December 7, 2021 2 minutes ago, SylvanLakeWH said: Theory of too much Relative-ity: As more time passes with relatives, the need for baked beans increases, until they succumb to the fumes and leave. At which time you can resume talking about ‘s. For me that time is usually about 4 to 6 hours. Maybe less. 😂 1 Share this post Link to post Share on other sites
Ifixoldjunk 778 #23 Posted December 7, 2021 honestly a propane powered wheel horse would be pretty cool. I think a regular bbq sized propane bottle would do the trick. Forklifts seem to run quite some time on the little 30 gallon tanks they have, and they usually have much bigger engines too. Id imagine you'd at least get your grass cut before running out of juice Share this post Link to post Share on other sites
Handy Don 12,235 #24 Posted December 7, 2021 12 minutes ago, Ifixoldjunk said: honestly a propane powered wheel horse would be pretty cool. I think a regular bbq sized propane bottle would do the trick. Forklifts seem to run quite some time on the little 30 gallon tanks they have, and they usually have much bigger engines too. Id imagine you'd at least get your grass cut before running out of juice 9 hours ago, Jeff-C175 said: The small ones for the gas grills are 30 lb. My gas grill uses 20 pounders. The more oblong ones you often see paired on a trailer tongue are 30's. We use 30's for lighting, refrigeration, and cooking at my son and daughter's camp as those are the largest size we can easily transport to get refilled. Propane costs $3-4 per gallon for refills (less in bulk delivery) and compares favorably to gasoline in overall cost of operation when maintenance is factored in. Plus it can be used (mostly) safely indoors in large buildings, as @ebinmaine pointed out. 4 Share this post Link to post Share on other sites
kpinnc 12,087 #25 Posted December 7, 2021 1 hour ago, SylvanLakeWH said: As more time passes with relatives, the need for baked beans increases, until they succumb to the fumes and leave. At which time you can resume talking about ‘s. That's exactly what I was saying!!!! 1 1 1 Share this post Link to post Share on other sites
