peter lena 8,971 #1 Posted December 3, 2021 replaced a steering wheel last year , used a flat face 1/4" drift pin , 3 lb hammer . had lubed up that drift pin on the old wheel years back , used my favorite , lucas xtra heavy duty chassis grease , as soon as it did the first hit , it just moved with no problem . when i replaced the wheel today after some dash work , I detailed the grease ,put some in the pin slot , also filled the steering wheel mount holes and existing hole in steering shaft . it went on so easily , firm solid drift pin hits , it was like a no problem job. just another lubrication experiment that worked , keep it greasy , pete 3 3 2 1 Share this post Link to post Share on other sites
roadapples 6,983 #2 Posted December 3, 2021 Keep it greasy,.......I like that. 1 1 4 Share this post Link to post Share on other sites
squonk 41,941 #3 Posted December 3, 2021 I use a bolt instead of the pin. No messy grease. 2 1 Share this post Link to post Share on other sites
Ed Kennell 39,737 #4 Posted December 3, 2021 1 hour ago, peter lena said: , keep it greasy I like that too Jay. @roadapples Good lubrication keeps all the old parts working. 4 Share this post Link to post Share on other sites
953 nut 56,755 #5 Posted December 3, 2021 2 hours ago, peter lena said: replaced a steering wheel last year , used a flat face 1/4" drift pin , 3 lb hammer . had lubed up that drift pin on the old wheel years back , used my favorite , lucas xtra heavy duty chassis grease , as soon as it did the first hit , it just moved with no problem . when i replaced the wheel today after some dash work , I detailed the grease ,put some in the pin slot , also filled the steering wheel mount holes and existing hole in steering shaft . it went on so easily , firm solid drift pin hits , it was like a no problem job. just another lubrication experiment that worked , keep it greasy , pete If the factory had done this we wouldn't have near as many threads posted on here. 3 1 Share this post Link to post Share on other sites
WHX?? 49,923 #6 Posted December 4, 2021 (edited) 1 hour ago, Ed Kennell said: I like that too Jay. @roadapples Good lubrication keeps all the old parts working. And who knows that better than our lube expert Pete. BTW Pete nice to see your name in RED Edited December 4, 2021 by WHX?? 3 1 Share this post Link to post Share on other sites
WHX?? 49,923 #7 Posted December 4, 2021 2 hours ago, squonk said: I use a bolt instead of the pin. No messy grease. I'll have to go the other way on this Mike... I take too many apart where they were bolted ... mostly on lower steering gear.... and holes are all wallowed out leading to slop. Bolts just don't seem to pin things proper. 'Course you know how PO fixes can be. 1/4 bolt in a 5/16 hole. Share this post Link to post Share on other sites
squonk 41,941 #8 Posted December 4, 2021 23 minutes ago, WHX?? said: I'll have to go the other way on this Mike... I take too many apart where they were bolted ... mostly on lower steering gear.... and holes are all wallowed out leading to slop. Bolts just don't seem to pin things proper. 'Course you know how PO fixes can be. 1/4 bolt in a 5/16 hole. True but I use the proper size fastener for the job. There has been a bolt on my C160 steering wheel for 10 years and the holes are still perfect. 2 Share this post Link to post Share on other sites
WHX?? 49,923 #9 Posted December 4, 2021 True Squonky ... the 1054 I picked up from @prondzy all the lower gear was messed up by bolts. Not at the wheel . I fixed and lubed the lower end per Pete and all is good. Drilled and reamed to the corect roll pin size & one over and now steers tighter than nun's bottom on Easter Sunday. I need to get on the other Mike's case why he did not do this but oh well....give us something to yak about ! 1 1 Share this post Link to post Share on other sites
prondzy 3,883 #10 Posted December 4, 2021 49 minutes ago, WHX?? said: True Squonky ... the 1054 I picked up from @prondzy all the lower gear was messed up by bolts. Not at the wheel . I fixed and lubed the lower end per Pete and all is good. Drilled and reamed to the corect roll pin size & one over and now steers tighter than nun's bottom on Easter Sunday. I need to get on the other Mike's case why he did not do this but oh well....give us something to yak about ! Settle down Jimmy, get yer faks right man! I sold ya a 1045 not a 1054. Geeze. Gettin on my case. time fer a cocktail or 4! 3 Share this post Link to post Share on other sites
Retired Wrencher 5,590 #11 Posted December 4, 2021 12 hours ago, 953 nut said: If the factory had done this we wouldn't have near as many threads posted on here. Agree on that. Also, hubs pulleys or any else that has a shaft. I believe never seize was around then or something like it. 2 Share this post Link to post Share on other sites
Tuneup 1,433 #12 Posted December 4, 2021 Not sure if we're putting the grease to the test or Pete or both but we lubed the old Mustang's throw-out slider with that grease over the weekend. Standard axle and marine grade just don't last 6 months. We shall see. Son is under the impression that a clutch should always be buttery smooth. Stubborn. With a nod to Jeff Foxworthy, this is the South but it's not a Mustang GT. 2001 V6. Share this post Link to post Share on other sites
WHX?? 49,923 #13 Posted December 4, 2021 10 hours ago, prondzy said: Settle down Jimmy, get yer faks right man! I sold ya a 1045 not a 1054 1 Share this post Link to post Share on other sites
peter lena 8,971 #14 Posted December 4, 2021 @Tuneup , in addition to lubing that throw out slider , look at every intended movement area , anything that is past its life , will hang up a smooth easy action , pete Share this post Link to post Share on other sites
Tuneup 1,433 #16 Posted December 4, 2021 (edited) 4 hours ago, peter lena said: @Tuneup , in addition to lubing that throw out slider , look at every intended movement area , anything that is past its life , will hang up a smooth easy action , pete That car was well taken care of but the T-5 was more or less shot. I can say that since I'm a Muncie or Saginaw kinda guy. Former owner had it recently replaced but they left the throw-out bearing. Who the heck would do that? Disintegrated. We fully rebuilt tranny as well as the clutch, flywheel, cable, pedals. Smooth as silk but that smoothness never lasts all that long, if my old Chevelle and Olds were any indication (but both were conversions I did). Just a minor, expected, bother. Another means of training the young 'uns on how to maintain and appreciate old iron. Edited December 4, 2021 by Tuneup 1 Share this post Link to post Share on other sites
peter lena 8,971 #17 Posted December 4, 2021 @Tuneup like you said , who the heck would leave a used throw out bearing in a trans swap ? on the other hand know I guy that did a ,new at the time , T10 gear box swap / upgrade , how about verifying oil in the new gear box? smoked it on a test drive , that really hurt , going to school the hard way , pete Share this post Link to post Share on other sites
Mustang67ford 234 #18 Posted December 4, 2021 Is grease better to use on the steering wheel and roll pin than anti sieze? Will be installing a new steering wheel, shaft, and pin shortly. Also, don't you need to use a special driver for roll pins so they don't get flared out? Share this post Link to post Share on other sites
