JPWH 6,158 #76 Posted January 1, 2022 @WHX?? Not my first and most likely not my last. This is easy compared to the 854 I did a few years ago. I have 3 more on the list after this one. 1 2 Share this post Link to post Share on other sites
WHX?? 49,869 #77 Posted January 1, 2022 I hear ya Jay.. I got two in now and next is going to be two 953s that I hope to get one out of. 4 3 Share this post Link to post Share on other sites
slim67 2,744 #78 Posted January 2, 2022 15 hours ago, WHX?? said: I hear ya Jay.. I got two in now and next is going to be two 953s that I hope to get one out of. Looks like it’s going to be the year of the 953/1054. 3 Share this post Link to post Share on other sites
WHX?? 49,869 #79 Posted January 2, 2022 1 minute ago, slim67 said: Looks like it’s going to be the year of the 953/1054. Betcha 953 nut will like that. They are a favorite of mine. Almost more than a nice roundy. Just something about the tall seat and the drive ability, stock HY and a stout worker. 3 1 Share this post Link to post Share on other sites
EB-80/8inPA 1,750 #80 Posted January 2, 2022 (edited) On 11/29/2021 at 4:41 AM, JPWH said: Edited January 2, 2022 by EB-80/8inPA 1 Share this post Link to post Share on other sites
slim67 2,744 #81 Posted January 2, 2022 1 hour ago, WHX?? said: Betcha 953 nut will like that. They are a favorite of mine. Almost more than a nice roundy. Just something about the tall seat and the drive ability, stock HY and a stout worker. It’s the trend now. They’ll all get turn sooner or later. I’ve got to get mine ready for April 30 plow day. 4 Share this post Link to post Share on other sites
JPWH 6,158 #82 Posted January 2, 2022 When I said three more after this one I didn't mean 953's. My custom 12, one lawn ranger, and one 854. @WHX?? You should get two out of two, why just one out of two? 3 1 Share this post Link to post Share on other sites
rjg854 11,702 #83 Posted January 2, 2022 Jim probably thinks Dan is to busy to work on more than one 1 7 Share this post Link to post Share on other sites
19richie66 17,542 #84 Posted January 2, 2022 40 minutes ago, rjg854 said: Jim probably thinks Dan is to busy to work on more than one I was going to say Dan’s probably booked up and Jim only reserved one slot in the garage. 5 Share this post Link to post Share on other sites
Pullstart 63,497 #85 Posted January 2, 2022 There’s a few in my stable that need some wrenches and lovin’ too. Let’s hope that happens this year! 4 1 Share this post Link to post Share on other sites
JPWH 6,158 #86 Posted January 5, 2022 I talked to RAM - PAC today and got some interesting information.The man said the hydraulic lift was probably built for a customer some 30 years ago because of the model number and not their typical installation. He said I could send it to them and they would check it out if I wanted. I finished sanding the gen belt guard and installed it. Hydraulic lift pump. 3 1 Share this post Link to post Share on other sites
953 nut 56,693 #87 Posted January 5, 2022 5 minutes ago, JPWH said: He said I could send it to them and they would check it out if I wanted. Lowell can fix you up with all the parts you'll need. https://wheelhorsepartsandmore.com/product-category/hydraulics/page/3/ Your pump and cylinder should be the same as the HY-2. 2 Share this post Link to post Share on other sites
JPWH 6,158 #88 Posted January 5, 2022 Dick, @953 nutI talked with Lowell as well. He said he makes his springs so he may be able to make one for me if I had enough of the broken one to go by, but he was not familiar with Ram Pac. The man I talked to with Ram Pac did not know if there should be a spring or not. I'm going to have to take it off the tractor and take it apart or send it to Lowell to pursue this any further. 2 Share this post Link to post Share on other sites
19richie66 17,542 #89 Posted January 5, 2022 If Karen’s had come with a pump, I would send it to you but it was absent from the parts mix. 1 1 Share this post Link to post Share on other sites
JPWH 6,158 #90 Posted January 5, 2022 (edited) 26 minutes ago, 19richie66 said: If Karen’s had come with a pump, I would send it to you but it was absent from the parts mix. @19richie66There is nothing wrong with the pump Richie. It works great! It's just the question if it's supposed to spring back to neutral. Ram Pac says they don't think so but I'm curious. Jay Edited January 5, 2022 by JPWH 1 Share this post Link to post Share on other sites
WHX?? 49,869 #91 Posted January 5, 2022 On 1/2/2022 at 10:03 AM, JPWH said: You should get two out of two, why just one out of two? I probably could but lots of missing stuff and lots of reversing PO damage. I figured by the time I was done I would have way more in two than worth. I'll use the best parts out of both and give what's left to 953 nut. One of the gas tanks already went to get a nice 953 Lowell has custody of running. I'm sure there will be a good transmission and other parts to help out something more savable. Both have good original pumps but one was already used on my plow mule to replace a HY2 pump that Lowell has now gone thru and got fixed. I will put that one back on the plow mule so I may have a correct one for someone down the road here. Figure that kind of business is better than having two 953s. 3 Share this post Link to post Share on other sites
Achto 28,156 #92 Posted January 5, 2022 @WHX?? I forget, does either one of those have a Ross box on it? Share this post Link to post Share on other sites
WHX?? 49,869 #93 Posted January 5, 2022 2 hours ago, JPWH said: supposed to spring back to neutral. Ram Pac says they don't think so but I'm curious. If not Hank can you install opposing springs somehow on the lever to bring it back to neutral? Just thinkin out loud here. 3 1 Share this post Link to post Share on other sites
WHX?? 49,869 #94 Posted January 5, 2022 5 minutes ago, Achto said: @WHX?? I forget, does either one of those have a Ross box on it? Yes ... both do....one is quite warbly but most likely can be saved with Cub box parts. Jay's work has got me jonesin to get the 701 & RE-67 done & out the shop and some 953s in! 2 1 Share this post Link to post Share on other sites
JPWH 6,158 #95 Posted January 5, 2022 17 minutes ago, WHX?? said: If not Hank can you install opposing springs somehow on the lever to bring it back to neutral? Just thinkin out loud here. @WHX?? I don't think this pump works that way. I'll have to get it all put back together to know for sure. That is an option though. I have the lift cable installed now so I'll hang something on it and check it out. 2 Share this post Link to post Share on other sites
JPWH 6,158 #96 Posted January 5, 2022 I'm anxious to get this one finished like I want it and start using it. I received the u bolts for the grille today, now I'm waiting on one more part for the Ross steering box, it's supposed to be an upgrade bearing. We'll see. Should get it tomorrow. Jay 1 Share this post Link to post Share on other sites
WHX?? 49,869 #97 Posted January 5, 2022 What was your source on the box parts Hank? 1 Share this post Link to post Share on other sites
JPWH 6,158 #98 Posted January 5, 2022 (edited) 52 minutes ago, WHX?? said: What was your source on the box parts Hank? Flea bay. Hamiltonbobscubs for the bearings and iplumb for the gaskets. The gaskets are not an exact match but will work Now I know what the material is I will make my own in the future. I still have a set of bearings and a gasket. I did not need the bearings. I had ordered 2 gaskets. For the top bearing I used a wheel needle bearing. Edited January 5, 2022 by JPWH 1 1 1 Share this post Link to post Share on other sites
JPWH 6,158 #99 Posted January 8, 2022 I finally got the bearing, also got an original key switch from A-Z. 3 Share this post Link to post Share on other sites
WHX?? 49,869 #100 Posted January 8, 2022 Sawweet Hank ..... those keys with the big fob are hens teeth and I believe they may have been original at one time on different years. Have one on a 857. 2 Share this post Link to post Share on other sites
