WheelHorse314-8 58 #1 Posted November 26, 2021 I’m looking at a 1993 Wheel Horse 520-H. It’s a 73501 model and serial is 3900845. Is this a good model? I’ve heard that some of the earlier hydros had bad transmissions. Any input is greatly appreciated. Thanks. 1 Share this post Link to post Share on other sites
Pullstart 71,084 #2 Posted November 26, 2021 That model has the most modern hydro trans Wheel Horse used. As long as it was taken care of, you’ll be all set! The rear cylinder is known for getting too hot if not services and cleaned out. As long as grass clippings are non-existent around the engine, you’ll likely be good there too. 4 Share this post Link to post Share on other sites
ebinmaine 80,264 #3 Posted November 26, 2021 46 minutes ago, WheelHorse314-8 said: I’ve heard that some of the earlier hydros had bad transmissions I'd be curious to know where that info came from. The Eaton 1100 is the transmission that's been in the 520 and several other Wheelhorse models since the early to mid 80s (?). Given proper care they've always been a reliable and heavy duty piece. Perhaps the transmission you've heard about is the Eaton 700. Those were much lighter duty. Are you speaking of the 520H specifically or the whole brand? The "earlier hydros" you refer to as a Wheelhorse brand would have started appearing around 1965. 1 Share this post Link to post Share on other sites
peter lena 10,013 #4 Posted November 26, 2021 @WheelHorse314-8 I do not have a 520 or onan power , but here are some very good belt guard aeration holes to help keep that engine cooler , makes sense , pete 1 Share this post Link to post Share on other sites
Handy Don 17,306 #5 Posted November 26, 2021 37 minutes ago, Pullstart said: The rear cylinder is known for getting too hot if not services and cleaned out. Rear engine cylinder. You'll find lots of commentary on this but scant comprehensive analysis and a wide range of home-brew "solutions". I've seen only one carefully controlled test of head temperature measurements on the Onan P series twins and it concluded that standard cooling ventilation in the WH was adequate. It did caution to be sure the rubber gasket around the oil filter was in place (these are still readily available for about $5). Totally agree that if it hasn't been abused it will do well for you. 3 Share this post Link to post Share on other sites
WheelhorseBob 1,550 #6 Posted November 26, 2021 My 520 is a 93 and it is one of the best built classic horses IMO. It has gear reduction steering, HD spindles/bearings and the Eaton 1100. They are the most refined of the classic designed horses too. 2 3 Share this post Link to post Share on other sites
WheelHorse314-8 58 #7 Posted November 27, 2021 Thanks for the input. Glad to hear it’s a good one. Is $500 a good deal? 1 Share this post Link to post Share on other sites
Thor27 892 #8 Posted November 27, 2021 YES! If in decent condition 2 Share this post Link to post Share on other sites
ebinmaine 80,264 #9 Posted November 27, 2021 3 minutes ago, WheelHorse314-8 said: Thanks for the input. Glad to hear it’s a good one. Is $500 a good deal? Depends totally on condition. Can you get any pics or information? Here's a thread that shows a checklist of things to look at for different levels of tractor purchase, repairs and maintenance. Check out the first bit for things to look at before a purchase. 1 1 Share this post Link to post Share on other sites
Handy Don 17,306 #10 Posted November 27, 2021 (edited) 8 minutes ago, WheelHorse314-8 said: Thanks for the input. Glad to hear it’s a good one. Is $500 a good deal? All day long practically anywhere if in good shape. Yes. All the better if it includes a deck that in good condition (you want to look for rust thru holes anywhere and if at all possible, a look UNDER the deck). Good luck Edited November 27, 2021 by Handy Don 2 Share this post Link to post Share on other sites
WheelHorse314-8 58 #11 Posted November 27, 2021 Here’s the pictures 5 Share this post Link to post Share on other sites
ebinmaine 80,264 #12 Posted November 27, 2021 If that runs and drives you should already be RUNNING to go get it. 3 2 4 Share this post Link to post Share on other sites
sparkie333 265 #13 Posted November 27, 2021 3 minutes ago, ebinmaine said: If that runs and drives you should already be RUNNING to go get it. 3 minutes ago, ebinmaine said: If that runs and drives you should already be RUNNING to go get it. i agree 100 % 2 Share this post Link to post Share on other sites
SylvanLakeWH 32,118 #14 Posted November 27, 2021 27 minutes ago, WheelHorse314-8 said: Thanks for the input. Glad to hear it’s a good one. Is $500 a good deal? If it runs and moves… yes. 3 Share this post Link to post Share on other sites
WheelHorse314-8 58 #15 Posted November 27, 2021 Do the Plastic fans on the hydro trans suppose to have a guard on them? Cause this one does not 1 Share this post Link to post Share on other sites
lynnmor 9,007 #16 Posted November 27, 2021 1 minute ago, WheelHorse314-8 said: Do the Plastic fans on the hydro trans suppose to have a guard on them? Cause this one does not No, they are not protected. I have had little issue with the fan, one had some cracks beginning and one came loose and was slipping. 1 Share this post Link to post Share on other sites
WheelhorseBob 1,550 #17 Posted November 27, 2021 No that is a terribly over priced tractor, nothin but problems! Do not buy that!!! BTW where is it?😉 1 5 Share this post Link to post Share on other sites
kpinnc 18,884 #18 Posted November 27, 2021 46 minutes ago, WheelhorseBob said: No that is a terribly over priced tractor, nothin but problems! Do not buy that!!! BTW where is it?😉 2 2 Share this post Link to post Share on other sites
WheelHorse314-8 58 #19 Posted November 27, 2021 I forgot to mention. I noticed in the fuse box there is a soda can tab in one of the fuse locations (i guess to bypass the fuse). Owner told me it’s been that way since he owned it. Should i be concerned? 1 Share this post Link to post Share on other sites
ebinmaine 80,264 #20 Posted November 27, 2021 2 minutes ago, WheelHorse314-8 said: I forgot to mention. I noticed in the fuse box there is a soda can tab in one of the fuse locations (i guess to bypass the fuse). Owner told me it’s been that way since he owned it. Should i be concerned? Not if it's been there awhile. If you buy it you can address that. 2 Share this post Link to post Share on other sites
Jeff-C175 7,211 #21 Posted November 27, 2021 @WheelHorse314-8 While you have been asking questions several of the other members have been figuring out where it is and are on their way to buy it now! Quit wasting time and go get it! 1 2 1 Share this post Link to post Share on other sites
lynnmor 9,007 #22 Posted November 27, 2021 With the fuse holder being knackered and the air cleaner top turned 180 degrees, it would best be left for a professional to buy, me for example. 6 Share this post Link to post Share on other sites
WheelHorse314-8 58 #23 Posted November 27, 2021 (edited) I purchased it. Thanks for the input! Edited November 27, 2021 by WheelHorse314-8 7 Share this post Link to post Share on other sites
ebinmaine 80,264 #24 Posted November 27, 2021 23 minutes ago, WheelHorse314-8 said: I purchased it. Thanks for the input! AWESOME. Now of course we'll need more pics!!! 1 1 1 Share this post Link to post Share on other sites
