jonw440
Wheel weight bolts
jonw440
I am picking up a pair of the Plastic WH weights on Saturday. They do not come with the 4 bolts. What size and length do I need?
Thank you.
Achto
They will be 1/2" carriage bolts. Not sure what the length is. Best to set them in the rim and measure for length.
squonk
Yup. Length depends on the dish of the wheel.
JCM
Okay, stupid question time. So are carriage bolts correct to use inserting them from behind the wheels through to the outside then a flat washer and nut leaving an exposed thread on the outside? Out of all the weights I have ever used I always had to supply my own hardware. Seems I may have been doing it wrong since 1989  by installing the flat washer on the outside with nut and lock washer on the inside with a regular bolt.  :confusion-confused: @squonk  &  @Achto    Length does vary a bit.
squonk
Stock WH  cast weights have the square  hole so the bolts on those go in from. . the out side. I believe the plastic ones have found holes so the bolts go in from the backside.
  • Thanks 1
Marv
True.
Marv
JohnD
The weights on my C-175 have 8.5" bolts.  I don't have carriage bolts (yet), so I do need to get a wrench/socket on both ends when tightening.  This is a good reminder that I should pick some up.
Pullstart
Make sure, that if you use the carriage bolts with the heads in the wheels, chop off the excess length once you get the nuts on the outside!  Your shins will thank you, ask me how I know!
ri702bill
As mentioned, length depends on rim width and dish.
I added 2 flats to the carriage bolt heads so I could reverse them from what is shown and still grab them with locking pliers from the outside, nylock nuts on the inside.
Gouged up the bottom of a few house shingles having them mounted as shown.
Bill
Edited by ri702bill
wallfish
I just use adjustable length bolts. LoL
Perfect fit every time for every weight or rim combo possible
All thread is cheap, available and has many uses
:twocents-02cents:
th.jpg.faa6227a319297588cb46de56dcd88e4.jpg.
  • Like 3
