Jeff-C175
More C-125 / K301 questions with photos...
Snoopy11
Most people... myself including... find it easier to crumble the webbing on the balance gear... but... it is all a matter of preference... :thumbs:
Don
Snoopy11
7 minutes ago, Jeff-C175 said:
On a 301 apparently it will clear.
I certainly hope so buddy. BUT, I will say, I have seen some cases where they don't. It isn't a big deal, and it is certainly something that you can overcome. :thumbs:
Don
kpinnc
10 minutes ago, Snoopy11 said:
As well, the machining on the crankshaft that I spoke of above may indeed allow you to remove the top gear without too much trouble.
However, you may not know until you open it up. Then, you must have a second plan of action.
I will admit that driving out the pin requires further disassembly in the fact that the PTO pulley may have to be removed, and that can be easy or can be an absolute nightmare if it has red welded over time.
The thin side of the balance gear should snap pretty easy. My previous comment about cast iron pieces was speculative, because I haven't done it that way myself.
Getting that top snap ring out is harder than any of the other options mentioned here!
Edited by kpinnc
Snoopy11
One little whack with a chisel and hammer! :lol:
Don
Handy Don
Dumb question time.
Are balance gears unique to the K301, 321 and 341 or were they in the smaller engines as well (e.g. 191, 181)?
Edited by Handy Don
kpinnc
2 hours ago, Handy Don said:
Dumb question time.
Not a dumb question. I don't think anything 10hp or less had them. I rebuilt my Mag10 about 20 years back, and it didn't have them.
Edited by kpinnc
stevasaurus
@Snoopy11 , I think it would be better for you to not be so antagonistic with some of your comments.  :eusa-think:
Jeff-C175
Don
Yeah... Now I don't know.  The link Squonk posted says they can be gotten out of the 301 without breaking by rotating the crank to the right position.
The link you posted seemed to indicate that it is not possible, he says he had to break his.
Oh well, whatever... no clear answer on this one.  I'm just gonna do whatever is necessary and stop posting about it.
I might post my results though.
Jeff-C175
I need to double check myself before I order an oil pan gasket.  I think I need the first one.  Can someone please confirm?  Thanks!
Snoopy11
Sir yes sir. :bow-blue:
Don
Snoopy11
Depends on if you have a wide or narrow base block:
Don
Edited by Snoopy11
Jeff-C175
Important Information About the IH Cub Cadet Garden Tractor Oil Pan
Don
Oh, dats EZ to check!  Thank you sir!  may I have another?
Definitely NARROW BASE.
Edited by Jeff-C175
Snoopy11
In... dat case, to clarify, the appropriate gasket would be:
Narrow Base Oil Pan Gasket Kohler K241, K301, K321, K341 and Magnum Series
Don
Snoopy11
4 hours ago, Jeff-C175 said:
post my results
With...eh...
:banana-gotpics: :banana-gotpics::banana-gotpics::banana-gotpics:
Don
Jeff-C175
2 hours ago, Snoopy11 said:
With...eh...
Don
Why yes!  Of course!  But it may not be for a while yet, starting to get chilly in the shop.
MIGHT wait until spring.
I did order the gaskets though!
So, knowing me, I'll rip into it as soon as the gaskets get here.
  • Haha 1
Snoopy11
Uh... yeah... well... you know you won't sleep until you do... :laughing-rolling:
You need some heated gloves...
Buy ColdWork M-Pact Heated Gloves | Mechanix US
And heated jacket...
DeWALT - X-Large Black 20-Volt/12-Volt MAX Heated Work Jacket Kit [179923]  [DCHJ060C1XL] - $258.88 : Toolsource.com, Your professional tool authority!
And... heated pants...
Mens Heated Pants
They make heated underwear too... :lol:
Don
  • Haha 1
Gregor
Wonderful gadgets these things.
697852308_Screenshot2021-12-22at18-23-47ModineHD45AS0121HotDawgHD45000BTUUnitHeaterLP80ThermalEfficiencyPowerVented.png.d3f3f8bcdaacab1c196dc5286d1ecdb6.png
Jeff-C175
I've got one of these (but it's older and doesn't have the 'nanny state' parrot cage around it.  I can put a teapot on top.
But Kero ain't cheap anymore, and at best it takes the chill off but I have to run it for at least three hours before I think of working in there.
My shop / garage is not built in such a way that's it's conducive to heating, and RETAINING, that heat.
It's more like an open campfire outdoors.  VERY NOT airtight!
OH... did I mention that we don't have natural gas available?
Edited by Jeff-C175
  • Sad 1
pfrederi
Got that... I am in the middle of Marcellus shale gas  i can see a few pads from my front yard and there are 11 wells on the next property... I burn coal  no gas it is all piped out...
  • Sad 2
Handy Don
I visited the northwest part of PA (Warren and Bradford) a while ago and was amazed at the number of oil and gas pumping platforms.
I'm pretty sure that some of that gas is heating my house.
Jeff-C175
Why not sink your own well Paul?  FREE GAS!  and sell what you don't use.
Have you ever been able to ignite the water coming out of your faucet?  (maybe you're not on a private well though...)
Seen some videos of that, pretty freaky.
pfrederi
Don't think any of the WHs can operate a drill rig that can go down 5,500 feet...:P
  • Haha 2
squonk
I don't know about PA, but NY gas from the same Marcellus shale is a mixture of many gases that need to be separated for safety and efficiency. There are a few wells about a mile from me where the landowners were able to get a limited amount. They had issues with the equipment that burned the gas like sooting, premature rusting ect. This was like 20 years ago. don't know if they are still trying to use the gas for them selves or not.
pfrederi
Eastern marcellus gas is pretty dry (just methane) Western has other elements ethane etc (aka Wet gas why Shell is building a muti-Billion dollar cracker out there)  20 years ago gas was shallow not marcellus  which is 5-6000 ft down
squonk
We're right on the edge of the Marcellus area or at least that's what I was told by a farmer who has a couple of wells on his property.
  • Similar Content
    • BrianKoch
      By BrianKoch
      Gentlemen,
      I am in need of help. While doing yard work with my K301 powered ‘68 Charger 12 it suddenly came to a stop and won’t start again.
      My troubleshooting so far:
      Fuel:
      • stabil/87 and clean
      • good flow before and after pump
      • carb clean, recently rebuilt, float level correctly set
      Compression:
      •good? - blows finger off spark plug hole
      •good turnover but doesn’t fire off
      •piston and cylinders move freely
      •valve lash set .008 intake .018 exhaust
      •breather assembly correct and recently serviced with new gaskets and filter
      •head gasket not broken, head bolts tight, some carbon on head
      Spark:
      •no spark
      •all electrical/ignition components were replaced 1 year ago except voltage regulator
      •no loose connections, no grounding connections
      •inspected and applied graphite to starter shaft
      •changed plug
      •12v to coil good
      •cleaned points, points wire has continuity
      •condenser ground good
      •swapped battery, points and wire, plug and wire, coil, and condenser from running K301 (‘69 Charger 12)
      •points push rod does push out when turning engine over by hand, but unable to get points timed using multimeter method and timing mark on flywheel
      What else should I check/do?
    • Tuneup
      By Tuneup
      Hi all,
      Summary: Solid mounts a year ago were very nice. Removed balance gears last December. Unacceptable. Installed eBay originals in good condition. I can ride it again at full throttle AND keep my fillings.
      Long story (I have the day off):
      A thread inspired me last December to look and see if my balance gears were doing well and the rear one was a wobbler. Removed them. She was burning too much oil - original rebuild was just a stone hone and power was not as it should be - it took months to get it bored .020. Hard to find in GA. Installed everything and started her up. Solid mounts USED to be great! That old off-idle vibration that shook the hood was gone thanks to those mounts. A little more vibration was OK. After the removal of the balance gears - NOT! The thing makes my butt numb and I can't mow at higher than about 2500 RPM. The hood vibrates just too much.
      Decided to shop Flea Bay for some used, but OK, mounts. Toro prices are . . . the usual Toro prices. Mine were shot and tossed in the bin. Easily installed, right?
      I thought in my ignorance that I could just remove a solid mount one at a time and pop-in the originals. Heck, the mount rubber has to be pressed in! Who knew? My old ones weren't like this at the restoration years ago.
      Delayed while I figured how to pull the engine on my own. I used to just throw it up on the bench but I've grown more cautious. No buds around in the AM for assistance. Tied some 10 gauge wire around a 2x3. Put one end on the table saw and lifting was easy. Still have to lift the weight but no bending and it was going on the floor. Dead lift at knee level. Pulled the 2x3 across the table to extend the engine to the side of the tractor and let her down slowly.
      Engine bay still pretty clean and the engine oil was due for its 1 hour drop after the rebuild anyway. Looked fine.
      How to get those mounts in? Tried a C clamp and a socket as a spacer - too clumsy. Greased them up nicely and got longer bolts - tightening them a bit at a time and nudging the mounts into the hole with a blunt object. Turned out not to be a bother!
      I've learned not to throw things away. It always seems that you need something the day after it's in the garbage truck. I still had the grounding lead and the large mount washers.
      The wife assisted in the re-installation. Kinda' freaked her out. Back in place, and I got to clean the lower engine area from that minor oil leak around the fuel pump. Attracted grass clippings like a magnet.
      A few bulb squeezes to start her up and, glorious! No more teeth chattering and I can take her up to 3600 if I like - sounds wonderful and she tore through the deep, deep crab grass. Don't discount those mounts. Sure, that off idle vibration is back and stronger than before. Nothing like a fresh bore for power. Something to spend time on tomorrow.
      Now, what to do with these?
    • Jeff-C175
    • HorsePower58
      By HorsePower58
    • HorsePower58
      By HorsePower58
