Jeff-C175
More C-125 / K301 questions with photos...
Snoopy11
It's too fast for a balance gear or rod. Broke out my Razer Adaro headphones. Sounds like intake valve, before exhaust valve opens. Might want to check the lash again...
.001 too big and that thing is going to be noisy as hell.
Don
Snoopy11
One more question, do the sounds go away when load is applied?
Don
Snoopy11
Just for reference, tappet clearance cold should be .008" for intake and .017" for exhaust.
Don
Jeff-C175
1 hour ago, Snoopy11 said:
What's your valve lash set at?
Hain't checked it yet!
I was planning on pulling the carb and fuel pump this week and checking that, but I forgot to order the vc gasket!
Jeff-C175
Don
I actually couldn't tell very well from the seat, but I don't believe so.
Snoopy11
Definitely lash needs to be evaluated. Sounds like it is loose... :thumbs:
Don
kpinnc
The Charger's K321 made a bigger tick than yours, and that was after removing the grenade gears, adjusting the valves, and decarbon cleaning the head.
Jeff-C175
56 minutes ago, kpinnc said:
bigger tick
 You've not found the source yet?
  • Haha 1
kpinnc
Gotta be in the valves. Checked everything as much as possible without removing rhe valves, but they seem fine, as do the seats.
One thing we did notice today was that the tick gets weaker as the engine warms up, and comes back strong at a cold start.
Just don't make sense!
Jeff-C175
I'm gonna pay more attention to this tomorrow on a cold start and see.
There's nothing really at idle, and I can't really tell if ir's still there at high speed because of the other noises masking it.  It's most apparent when running the speed up as in the video.
But... the good news is that the rattly clutch mechanism is almost silent!
I had an idea to add another smaller, much weaker spring to that to quiet it even more.  When the belt is engaged, the handle is basically hanging free to rattle around.  A spring at the location shown in blue might stop that rattle altogether.  Have to look at that a bit more after I get the other stuff done.
Edited by Jeff-C175
Jeff-C175
On 12/3/2021 at 7:18 PM, Jeff-C175 said:
Still to do...
1. Shim steering shaft to get rid of excess free play. DONE, check.
There was 0.050 of shims installed.  Looked original, Cotter pin still had virgin red paint on it.  Ended up with a total of 0.175 of shims, so roughly 1/8" added.  Have about 0.015 clearance now.  MUCH better!
2. Replace front wheel bearings... or at least shim them up if they aren't bad.  There's about 3/16" of axial free play.  I hope the spindles are OK!
One side is done.  Will get to other side tomorrow.  Bearings were pretty bad.  Spindles are OK, about 0.010 wear.  Not terrible.  DONE, check.
Quote
3. Reinstall fender pan, seat, foot rests, side panels and console panels.  DONE, check.
4. Move rear axle plow mount from the 175 to the 125 and install plow.   DONE, check.
Not making this a priority until I get the 'big tick' project sorted out.  If there's an issue with the engine I don't think I want to be plowing with it just yet.
5. Looks like I need to add new tie rods to the list!  Quite a bit of play, and as is typical it seems, there's a pretty fair amount of toe out on this machine.  I can't help but wonder if that was intentional from the factory for some reason?
Edited by Jeff-C175
Jeff-C175
Those with very keen visual senses might notice an error that I made!  Need to fix that.  Works fine... if you're standing on your head!  This is a test!
Nobody wants to play?
It's not real obvious unless you've installed new ammeters, or have the wiring color code committed to memory.
I got the wires on bass ackwards!  RED s/b on the LEFT, and GREEN s/b on the RIGHT!
Says "DISCHARGE" when it's actually CHARGING!
I might just leave it like that... because I don't want to cut the tape and have to retape it again.
  • Haha 1
Snoopy11
No way I could have even guessed...  :snooty:
Don
Jeff-C175
Still trying to figure out this rattle.  I know, I know, bite the bullet and pull the motor and get shut of them balance gears... yeah, I get it... but I don't really want to open 'er up if I haain't gotta!
So, here's two more short videos.  Showing the noise getting louder when I engage the clutch, and with the clutch engaged, getting louder when I move the machine.
Do these still sound like a valve tick @Snoopy11 ?  I don't think so myself.  I know what tickin' valves sound like and I don't think this is that.
Link should take you to shared album of short videos:
https://photos.app.goo.gl/xbZKgaFH55ohbzKn9
Jeff-C175
By the way...  it is absolutely amazing to me how much difference moving the governor spring up one hole on the governor arm can make!
Previously, it was in the 3rd hole from the bottom and when I engaged the clutch it would bog down to about half the speed, needing to manually bump up the throttle.  When dis-engaging the drive belt it would of course speed WAY up.
Moved it up to the 4th hole from the bottom... PERFECT!  Same speed all the time.
Snoopy11
Very hard to tell in the videos... lot's of white noise from the engine itself.
The sound seems to change tune (get's a little more aggressive sounding) when load is applied... telling me that it may indeed be balance gears... again, just very hard to tell.
The sound that I am hearing now seems less fluttery. In other words, now it sounds more like an internal component... whereas before, it sounded like valve flutter...
Have you changed the oil lately... if so... any metal flakes noticeable?
Don
Jeff-C175
Do you even have to ask the first question?  :ychain:  :omg: of COURSE I did!  First thing!
Nothing out of the ordinary in the drain oil.  Let it settle for a good while and ran the magnet through it.  I won't say ZERO, but the next step up from zero, which is a few specks of ferrous dust.
Maybe should have filtered it though, looking for Al U. Minium ?
Edited by Jeff-C175
  • Haha 1
Snoopy11
Well, it might have been the second thing... or the third... :laughing-rolling:
Definitely does not sound like rod knock.
Does not really sound like valves anymore...
Only other thing it could be... (you know what, I won't say it out loud...)... :snooty:
Does it sound better/worse as it runs? :confusion-confused:
Don
Snoopy11
9 minutes ago, Jeff-C175 said:
Al U. Minium
:text-google:
:laughing-rolling:
Don
Snoopy11
It is so hard to tell... but I think it sounds similar to the engine in the second video here Jeff? Sounds a little similar to me... but again, very hard to tell in videos...
It seems like it is a common sound in these engines... not really detrimental... as it would appear... :confusion-confused:
Don
Jeff-C175
sounds similar
Listening now... I can tell you one thing, he's got the idle set way too low in the first video.  Not much oil gettin' slung around in it's belly at that speed!
After listening to the second... yeah, I agree, it does sound like that.
I'll retard the timing a bit tomorrow and see what affect that might have.  (Of course I'll baseline it first!)
Then, I'm gonna run it until it blows up.  And put my B&S 16 HP Twin in it's place.  I don't really need that pressure washer anymore!
kpinnc
Yes sir you are correct! Huge difference in govenor response!
This, and adding the spring between governor arm and throttle made a massive difference in the Charger's performance.
Plain and simple- these machines have wear in the linkages aside from internal wear. You can get a good runner, but sometimes they need a little extra to keep going!
Edited by kpinnc
Jeff-C175
I added a small spring from the throttle over to a small hole that was in the top of one of the tins.  I think I posted a pic of it in one of my threads, maybe this one?  (yes, page 2)
I think it achieves the same net effect, keeping the throttle from 'bouncing' around due to play in the linkage and the throttle shaft.
Edited by Jeff-C175
  • Excellent 2
Jeff-C175
Points were already at 0.018 .  Set them to 16 didn't seem right, kinda 'sluggish'... but noise was the same.
Set them to 20, noise the same.  At 0.020, the timing mark was exactly 'on'.
Advanced to 0.022 ... no difference.
Set them back to 0.020
Snoopy11
I was about to... post...
:banana-gotpics:
But you beat me to it Jeff... :laughing-rolling:
Don
  • Similar Content
    • BrianKoch
      By BrianKoch
      Gentlemen,
      I am in need of help. While doing yard work with my K301 powered ‘68 Charger 12 it suddenly came to a stop and won’t start again.
      My troubleshooting so far:
      Fuel:
      • stabil/87 and clean
      • good flow before and after pump
      • carb clean, recently rebuilt, float level correctly set
      Compression:
      •good? - blows finger off spark plug hole
      •good turnover but doesn’t fire off
      •piston and cylinders move freely
      •valve lash set .008 intake .018 exhaust
      •breather assembly correct and recently serviced with new gaskets and filter
      •head gasket not broken, head bolts tight, some carbon on head
      Spark:
      •no spark
      •all electrical/ignition components were replaced 1 year ago except voltage regulator
      •no loose connections, no grounding connections
      •inspected and applied graphite to starter shaft
      •changed plug
      •12v to coil good
      •cleaned points, points wire has continuity
      •condenser ground good
      •swapped battery, points and wire, plug and wire, coil, and condenser from running K301 (‘69 Charger 12)
      •points push rod does push out when turning engine over by hand, but unable to get points timed using multimeter method and timing mark on flywheel
      What else should I check/do?
    • Tuneup
      By Tuneup
      Hi all,
      Summary: Solid mounts a year ago were very nice. Removed balance gears last December. Unacceptable. Installed eBay originals in good condition. I can ride it again at full throttle AND keep my fillings.
      Long story (I have the day off):
      A thread inspired me last December to look and see if my balance gears were doing well and the rear one was a wobbler. Removed them. She was burning too much oil - original rebuild was just a stone hone and power was not as it should be - it took months to get it bored .020. Hard to find in GA. Installed everything and started her up. Solid mounts USED to be great! That old off-idle vibration that shook the hood was gone thanks to those mounts. A little more vibration was OK. After the removal of the balance gears - NOT! The thing makes my butt numb and I can't mow at higher than about 2500 RPM. The hood vibrates just too much.
      Decided to shop Flea Bay for some used, but OK, mounts. Toro prices are . . . the usual Toro prices. Mine were shot and tossed in the bin. Easily installed, right?
      I thought in my ignorance that I could just remove a solid mount one at a time and pop-in the originals. Heck, the mount rubber has to be pressed in! Who knew? My old ones weren't like this at the restoration years ago.
      Delayed while I figured how to pull the engine on my own. I used to just throw it up on the bench but I've grown more cautious. No buds around in the AM for assistance. Tied some 10 gauge wire around a 2x3. Put one end on the table saw and lifting was easy. Still have to lift the weight but no bending and it was going on the floor. Dead lift at knee level. Pulled the 2x3 across the table to extend the engine to the side of the tractor and let her down slowly.
      Engine bay still pretty clean and the engine oil was due for its 1 hour drop after the rebuild anyway. Looked fine.
      How to get those mounts in? Tried a C clamp and a socket as a spacer - too clumsy. Greased them up nicely and got longer bolts - tightening them a bit at a time and nudging the mounts into the hole with a blunt object. Turned out not to be a bother!
      I've learned not to throw things away. It always seems that you need something the day after it's in the garbage truck. I still had the grounding lead and the large mount washers.
      The wife assisted in the re-installation. Kinda' freaked her out. Back in place, and I got to clean the lower engine area from that minor oil leak around the fuel pump. Attracted grass clippings like a magnet.
      A few bulb squeezes to start her up and, glorious! No more teeth chattering and I can take her up to 3600 if I like - sounds wonderful and she tore through the deep, deep crab grass. Don't discount those mounts. Sure, that off idle vibration is back and stronger than before. Nothing like a fresh bore for power. Something to spend time on tomorrow.
      Now, what to do with these?
    • Jeff-C175
    • HorsePower58
      By HorsePower58
    • HorsePower58
      By HorsePower58
