Barracuda 7 #1 Posted November 23, 2021 Broken axel on a Sunstrand Hydro trans 1972-73 wheelhorse 10 hp need any help as to acquiring new axel and rebuild instructions. Share this post Link to post Share on other sites
ebinmaine 69,711 #2 Posted November 23, 2021 Have you gotten into disassembling the transmission to see what broke the axle? Also, what other parts are broken or worn out? Lowell at Wheel Horse Parts and More will be able to supply you with any needed bearings, seals, case gasket. Those axles are not known for breaking so it would be good to figure out exactly why it happened and what's broken around it.. 2 Share this post Link to post Share on other sites
Pullstart 63,542 #3 Posted November 23, 2021 Hello, what model is this? I have a couple auto machines I’m planning on parting out. 3 Share this post Link to post Share on other sites
Maxwell-8 4,366 #4 Posted November 23, 2021 20 minutes ago, Barracuda said: Broken axel on a Sunstrand Hydro trans 1972-73 wheelhorse 10 hp need any help as to acquiring new axel and rebuild instructions. Do you have a serial number for us to track down the model tractor an hydro you have. 1 Share this post Link to post Share on other sites
pfrederi 18,181 #5 Posted November 23, 2021 Model number would be important. If it is a 10 hp 1973 no name it may have a Hydro gear or piston to piston. Looks like they each used 2 5961 axles (1" 4 pinion) 1 Share this post Link to post Share on other sites
pfrederi 18,181 #6 Posted November 23, 2021 Looks like WH went cheap with the 10hp in 1972...The Charger 10 then also uses the 1" axle 5961... Earlier Charger 10s had 1-1/8 and 10 pinion... 2 Share this post Link to post Share on other sites
953 nut 56,755 #7 Posted November 23, 2021 After draining the fluid you will need to remove the pump/motor assembly as a unit. There are six bolts, two top ones go all the way through the transaxle case. Once this is done you can lift it up a bit and secure it to the steering wheel. Next you can disconnect linkage and the four bolts that hold the transaxle to the frame. A few more bolts and you will be inside. Lowell at https://wheelhorsepartsandmore.com can fix you up with the gaskets and seals. 3 1 Share this post Link to post Share on other sites
pfrederi 18,181 #8 Posted November 23, 2021 If it is the 5961 axle you are somewhat in luck. it was used in 300 series 8 speeds with 1" axles... 1 Share this post Link to post Share on other sites
pfrederi 18,181 #9 Posted November 23, 2021 (edited) Download this manual (click on the pic) Edited November 23, 2021 by pfrederi 1 Share this post Link to post Share on other sites
daveoman1966 3,768 #10 Posted November 23, 2021 I have detailed overhaul manuals for the Sundstrand automatic tractors. One manual covers the 90-2046 Hydrogear and the other manual is for the Sundstrand Piston-to-Piston models such as 90-1136, 90-1140 etc. Here are both manuals that I prepared in .pdf format MODERATOR: Make these available for download to ALL MEMBERS.. SUNDSTRAND Piston-Piston PUMP & MOTOR Refurb.pdfSUNDSTRAND HYDROGEAR refurb.pdf 1 1 Share this post Link to post Share on other sites
wallfish 17,194 #11 Posted November 23, 2021 The guys are all over this one already! I've been around here for a while now and it's still impressive how fast info flies! I'm curious how it broke. Dually wheels? Or just wollowed out key ways? 24 minutes ago, daveoman1966 said: I have detailed overhaul manuals for the Sundstrand automatic tractors. One manual covers the 90-2046 Hydrogear and the other manual is for the Sundstrand Piston-to-Piston models such as 90-1136, 90-1140 etc. Here are both manuals that I prepared in .pdf format MODERATOR: Make these available for download to ALL MEMBERS.. SUNDSTRAND Piston-Piston PUMP & MOTOR Refurb.pdf 2.6 MB · 0 downloads SUNDSTRAND HYDROGEAR refurb.pdf 3.27 MB · 0 downloads Dave, you can submit files. Top left, under the WH logo there's a "Browse". Hover on that for the drop down and click manuals. On the right you should see a list of the categories so click on "Automatic / Hydro" under Transmission, then "Submit a File" Think that should do it. You made them so take the credit for the work done and live forever on RS as it typically shows who presented them on here. (If I do it for you it will display -- by wallfish) 1 2 Share this post Link to post Share on other sites
Pullstart 63,542 #12 Posted November 23, 2021 3 hours ago, pfrederi said: Looks like WH went cheap with the 10hp in 1972...The Charger 10 then also uses the 1" axle 5961... Earlier Charger 10s had 1-1/8 and 10 pinion... Does an earlier Sunstrand with 1-1/8” axles direct swap? 1 Share this post Link to post Share on other sites
pfrederi 18,181 #13 Posted November 23, 2021 8 minutes ago, Pullstart said: Does an earlier Sunstrand with 1-1/8” axles direct swap? not if it is the 5961 axle... Share this post Link to post Share on other sites
pfrederi 18,181 #14 Posted November 23, 2021 34 minutes ago, wallfish said: The guys are all over this one already! I've been around here for a while now and it's still impressive how fast info flies! I'm curious how it broke. Dually wheels? Or just wollowed out key ways? Of course the original poster hasn't been back.... 1 Share this post Link to post Share on other sites
Pullstart 63,542 #15 Posted November 23, 2021 4 minutes ago, pfrederi said: not if it is the 5961 axle... the entire transaxle? 3 Share this post Link to post Share on other sites
wallfish 17,194 #16 Posted November 24, 2021 7 minutes ago, pfrederi said: Of course the original poster hasn't been back.... He's used to everywhere else and will check back in a few days 3 Share this post Link to post Share on other sites
Snoopy11 5,717 #17 Posted November 24, 2021 48 minutes ago, wallfish said: in a few days or... weeks... Don Share this post Link to post Share on other sites
Snoopy11 5,717 #18 Posted November 24, 2021 I'm interested in learning... how it broke? If it broke at all... for whatever reason, what's to stop it from breaking again in the future? Not at all trying to be rude, here me there, but just a sincere question... Don Share this post Link to post Share on other sites
ebinmaine 69,711 #19 Posted November 24, 2021 11 minutes ago, Snoopy11 said: I'm interested in learning... how it broke? If it broke at all... for whatever reason, what's to stop it from breaking again in the future? Not at all trying to be rude, here me there, but just a sincere question... Don Yepp me too. See my post. These axles are some kinda rugged... One would want to find the root cause for sure. 1 1 Share this post Link to post Share on other sites
Maxwell-8 4,366 #20 Posted November 24, 2021 12 hours ago, Barracuda said: Broken axel on a Sunstrand Hydro trans 1972-73 wheelhorse 10 hp need any help as to acquiring new axel and rebuild instructions. It's hard to believe they broke. This maybe the strongest part on a almost bulletproof tractor. those axles can support up to 50hp with ease 1 1 Share this post Link to post Share on other sites
JoeM 7,886 #21 Posted November 24, 2021 10 hours ago, pfrederi said: Of course the original poster hasn't been back... Happens a lot. My favorite are the ones that get it fixed and don't tell you what they found. 5 Share this post Link to post Share on other sites
Barracuda 7 #22 Posted November 25, 2021 On 11/23/2021 at 2:52 PM, Barracuda said: Broken axel on a Sunstrand Hydro trans 1972-73 wheelhorse 10 hp need any help as to acquiring new axel and rebuild instructions. Axel broke because some one drilled a hole through the hub and axel and used a roll pin to secure the hub, t he axel key way was damaged . Thanks for all of the replies that I received will probably E mail some of you for info Thanks Barracuda. 2 Share this post Link to post Share on other sites
Barracuda 7 #23 Posted November 25, 2021 Axel broke because some one drilled a hole through the axel and hub and used a roll pin to secure the hub have not pulled it apart as yet so I may just need an axel and some seals. I want to thank all for the replies that I received it's awesome. May E mail some of you for more help. Thanks Barracuda 4 1 Share this post Link to post Share on other sites
kpinnc 13,106 #24 Posted November 26, 2021 On 11/23/2021 at 6:41 PM, Pullstart said: Does an earlier Sunstrand with 1-1/8” axles direct swap? If you're asking about swapping the whole tranny, then yes. 2 Share this post Link to post Share on other sites
