Brian1045 28 #1 Posted June 21, 2009 The original discontinued part number is 4988. I have a 5 pronged switch with the prongs being labeled as L-S-M-B-G I thought about using...but I hate to have to change the terminal ends to switch over to the 5 pronged one I have as a spare. My original wiring is in such good shape! Does anyone know if the original style 3 prongs with threaded terminals can be bought anywhere? :thumbs2: Share this post Link to post Share on other sites
oldandred 15 #2 Posted June 21, 2009 Brian check with the MF tractors I think there the same as the three we use Share this post Link to post Share on other sites
Brian1045 28 #3 Posted June 21, 2009 Thanks..I'll check with the MF guys. I got bigger problems now. For some reason when the switch went it took something else with it. I'm not getting any spark at the points, so I gotta track that down now. :thumbs2: Share this post Link to post Share on other sites
clintonnut 126 #4 Posted June 21, 2009 There was a thread on this a while ago for this switch. You have an external coil igniton right? Charlie Share this post Link to post Share on other sites
Brian1045 28 #5 Posted June 21, 2009 Here is my setup. typical pre 70's Attached Image (Click thumbnail to expand) Share this post Link to post Share on other sites
Sarge 3,464 #6 Posted June 22, 2009 That looks to be the same Cole-Hersee switch I sourced recently from Vic's DC in Stuart, FLorida (772)220-8952 . Cole-Hersee part numbers are as follows- Battery ignition- #95521-B (4988) Magneto ignition- #95520-B These two switches are dead identical to the original equipment units used in most of the 60's WH tractors with the offset leg Hencol style key . Just fyi- he also has nos generator lamps for those tractors- part #PL-20-RC . Don't hold your breath, there weren't too many left when I ordered all of mine.... Sarge Share this post Link to post Share on other sites
wingrider 21 #7 Posted June 22, 2009 Sarge I just bought 3 of these switches form my local NAPA store, they are from Stens the part number is 430520. They are exact matches to the orginal switch on my 854 right down to the patten numbers. Good Luck wingrider Share this post Link to post Share on other sites
Brian1045 28 #8 Posted June 22, 2009 Thanks all....I'll check into it. I have a Napa about a mile away. :thumbs2: Share this post Link to post Share on other sites
WH1055 0 #9 Posted June 22, 2009 I just got off of the phone with NAPA, and they do not even recognise that PN, (could also be that they don't have everything, I had a very knowledgeable one by me that just got bought out, I miss having them as a resource). He found one that might work, but for $46.00. That seems a bit much for a key switch, and being on a college budget I would rather get one cheaper.... Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,243 #10 Posted June 22, 2009 The 4988 WH switch for battery ignition was replaced by 7263 and still available from Toro. The 430-520 Stens switch mentioned above is for magneto ignition. Garry Share this post Link to post Share on other sites
hounddoghundzsa 7 #11 Posted July 11, 2010 Just wondering if anyone else had tried the 7263 switch?? I tryed looking it up and there is no pic to compare it to. Want to make sure it's right because it's not retunable. :thumbs: Share this post Link to post Share on other sites
buckrancher 2,694 #12 Posted July 11, 2010 That looks to be the same Cole-Hersee switch I sourced recently from Vic's DC in Stuart, FLorida (772)220-8952 . Cole-Hersee part numbers are as follows- Battery ignition- #95521-B (4988) Magneto ignition- #95520-B These two switches are dead identical to the original equipment units used in most of the 60's WH tractors with the offset leg Hencol style key . Just fyi- he also has nos generator lamps for those tractors- part #PL-20-RC . Don't hold your breath, there weren't too many left when I ordered all of mine.... Sarge Vic's is out of switch's But you can still buy them new from cole-hersee #95521-B (4988) :thumbs: Share this post Link to post Share on other sites
hounddoghundzsa 7 #13 Posted July 11, 2010 Thanks! Do you know where to get the push button starter too?? Share this post Link to post Share on other sites
oldandred 15 #14 Posted July 12, 2010 Thanks! Do you know where to get the push button starter too?? hummmmmmm look here http://www.elecdirect.com/catalog/4135b2f9...d9fc3aa4b1.aspx Share this post Link to post Share on other sites
buckrancher 2,694 #15 Posted July 12, 2010 Thanks! Do you know where to get the push button starter too?? I believe the new switchs are 1" in dia. so you will need to open your hole size up Share this post Link to post Share on other sites
hounddoghundzsa 7 #16 Posted January 31, 2011 I just got on Cole Hersee's site to order the Ignition switch and starter button. Being that I am more or less retarded when it comes to electrical crap I'm a little confused as to which starter button will work. I'm also confused about Cole Hersee's purchasing process - WTH is a RFQ?? I got a confirmation email - but what do I got to do to buy the darn thing??? Share this post Link to post Share on other sites
Lane Ranger 11,125 #17 Posted January 31, 2011 I buy the Cole Hersee switches through this outfit: http://www.elecdirect.com/catalog/4135b2f9...d9fc3aa4b1.aspx :banghead: Share this post Link to post Share on other sites
wheelhorse656 20 #18 Posted February 2, 2011 I just got off of the phone with NAPA, and they do not even recognise that PN, (could also be that they don't have everything, I had a very knowledgeable one by me that just got bought out, I miss having them as a resource). He found one that might work, but for $46.00. That seems a bit much for a key switch, and being on a college budget I would rather get one cheaper.... i have one from a 856 i have that i would sell let me check and see if it is the right one :banghead: Share this post Link to post Share on other sites
horse junkie 18 #19 Posted February 12, 2011 Thanks all....I'll check into it. I have a Napa about a mile away. I know it's a little late but I bought a switch like that for my 1276 at my local wheel horse dealer Share this post Link to post Share on other sites
mike avad 44 #20 Posted July 4, 2022 I have a 1965 875 wheel horse my old igniton switch has 3 plugs and one in the center where could I find on like that Share this post Link to post Share on other sites
lynnmor 7,566 #21 Posted July 4, 2022 58 minutes ago, mike avad said: I have a 1965 875 wheel horse my old igniton switch has 3 plugs and one in the center where could I find on like that You should post this under Wheel Horse Electrical in the main menu. Share this post Link to post Share on other sites
wallfish 17,495 #22 Posted July 4, 2022 1 hour ago, mike avad said: I have a 1965 875 wheel horse my old igniton switch has 3 plugs and one in the center where could I find on like that Click on the link above in the post by Lane Ranger Share this post Link to post Share on other sites
