oldredrider
Ignition switch
oldredrider
Have a GT-14 with a magneto ignition. Want to switch over to battery ignition because of engine change.
Is there a 4 position ignition switch, like the original, I can use for a battery ignition?
squonk
# 101917 Paul
oldredrider
Awesome! Just what I needed. I owe you...some more!!! Thanks
oldredrider
@squonk it seems from some short searching, that # is for a magneto ignition. Correct me if I'm wrong....
squonk
I'm just going by that diagram. I would wire it with the 3 position 103990 if it was me.
oldredrider
Yup, probably end up doing that.
gwest_ca
Howard G
Can anyone help me with a no start problem?  I have a 1992 Toro Wheel Horse Classic, 312-8.  Model 3112K804 with Serial # 2000859.  One of the switch terminals burnt off and part of the switch harness where that terminal went into.  I need to know what is the PROPER ignition key switch, and if there is a replacement section of wiring harness that fits the PROPER ignition key switch.  Also if the switch is a magneto  or battery start switch.  The original switch had no terminal markings ANYWHERE on the key switch.
Any information you can give/send me, would be immensely appreciated as I wish to immediately purchase the parts so I can use the blade functions again, and do not wish to jumper any wiring.  Thanking you in advance.  Howard G.   unbiased1946@gmail.com
953 nut
:WRS:
The correct ignition switch for your 312-8 is Toro part # 116 338. :techie-ebay: can fix you up with sellers for that switch and also has vendors with the five terminal connectors.
gwest_ca
Sometimes the terminals themselves on the switch are stamped with an identifying letter. Sometimes they are not stamped correctly either.
Best to use the wiring diagram which shows the wire locations in the 5-terminal connector when looking at the back of the switch.
Howard G
On 11/28/2021 at 8:49 AM, 953 nut said:
:WRS:
The correct ignition switch for your 312-8 is Toro part # 116 338. :techie-ebay: can fix you up with sellers for that switch and also has vendors with the five terminal connectors.  I would appreciate that, as I wish to get it running before the snow flies.
