The Gman
654 engine take chance on rebuild?
The Gman
Bought a 654 a few years ago, tranny is locked up but I got the engine to run. It smokes and has low compression. Figured would be a good project this winter. Rebuild both the engine and tranny.
This what I found. The bore is in spec. so a light hone and valve job with new rings should do the trick. Con rod is toast but I can get a new one on the bay. Problem is I can't get a crank shaft.....
Haven't mic'd up the journal yet but if it's good think I can get away with a good polish or am I wasting my time?
Thoughts???
The rest of the horse in fair shape
ebinmaine
6 horse Tecumseh?
Can you post two or three pics of the crankshaft you have?
ri702bill
Since you are going to get a new connecting rod anyway, is the journal diameter original or has it been turned down already?? IF it is original AND the scored area is minimal, it may be able to be cut undersize. Time to consult a decent engine machine shop for that one ... if that is what you want to do.
Bill
Snoopy11
24 minutes ago, The Gman said:
problem is I can't get a crank shaft.....
Soak in muriatic acid, then polish. That crankshaft will clean right up. I have cleaned crankshafts that were... a lot worse than that... :thumbs:
You can use a fingernail file on it as well... after soaking...
Don
Snoopy11
Oh, and don't forget, when you soak it in muriatic acid, it must be neutralized with baking soda. Once all the aluminum is off of the crankshaft,
Soak in mixture of  ½ cup of baking soda to a quart of water. Pull the crankshaft out of this solution, coat in baking soda, then dip back into baking soda/water solution.
Completely dry the crankshaft, and oil it all over with engine oil or molly lube.
The journal, in my opinion, should go back to the same size as stock. Wouldn't hurt to check, but in my experience, it will be perfectly fine. :thumbs:
Don
The Gman
45 minutes ago, ebinmaine said:
6 horse Tecumseh?
Yes it's the h60 model 75063b
Here is the crank
The Gman
Bill
I can get the crank ground but can only find standard con rods. :mellow:
ebinmaine
I have a crankshaft that I couldn't use.
Lemme look at it when I get home.
Something to do with a step in the shaft my existing one didn't have.
Snoopy11
WAIT A MINUTE!
Eric, you reminded me of something... I think that I still have the crankshaft from the techy that was on HellHorse... :D
I might be willing to give it to you, @The Gman... if you pay for shipping...?
Don
Snoopy11
I am going to go out to the shop and check to see if I still have it... I might have gotten rid of it... :rolleyes:
Don
Snoopy11
Yes sir, I still have it.
:banana-gotpics: anyone?
It is really in excellent shape... journal is SOOOOO smooth...
Thing has been sitting around in a box with some other crankshafts, wrapped in newspaper... :D
I offer it to you, @The Gman...
Don
Snoopy11
By the way, I don't have the Techy engine anymore... and don't want/need the crankshaft... so if you want it, you won't be robbing anything from me... :P
Don
Snoopy11
Looks like used cranks for the H60 sell for around 50 bucks on fleabay... :rolleyes:
Don
The Gman
Don
Hi, I'll take another look and pm my info to you
  • Excellent 2
The Gman
Don
Fantastic. Thank you, thank you, Thank you.
I'll pm you
Snoopy11
Cool, yeah, this one isn't going anywhere... so take your time... :laughing-rolling:
Don
Snoopy11
Hey @The Gman... I did put the crank on the die grinder... to get it cleaned up...
I have it boxed up and ready to ship. Be aware, it is pretty greasy, nice and oily, so don't let it slip out of your hand when you take it out of the box... (latex gloves wouldn't be a bad idea)... :laughing-rolling:
Don
Edited by Snoopy11
oliver2-44
I have this box of various NOS Tecumseh Parts if any part numbers match what you need, its yours for the cost of shipping.
Tecumseh NOS PARTS.ods
  • Excellent 2
Snoopy11
Hell yeah!
You've got parts getting thrown at you from all sides there, @The Gman...! :banana-rock:
Don
The Gman
16 hours ago, Snoopy11 said:
Hell yeah!
Don
Fantastic Don,
I'll cross-reference my engine to the parts list you sent.
Gotta say again. The best forum, the best people anywhere are right here on redsquare.
Woo hoo. :bow-blue::greetings-clappingyellow::eusa-clap:
  • Excellent 2
Snoopy11
47 minutes ago, The Gman said:
Fantastic Don,
Yes sir, I learned the same thing when I came to Redsquare. :banana-rock:
I have gleaned so much information... I really can't express my appreciation to guys here.
The only thing I can do is pass on helpful information (particularly about engines), and help when I can.  :D
Don
Snoopy11
Techy H60 Crankshaft boxed up, label taped on, ready to ship. Will be dropped in the mail later today! :)
Don
Snoopy11
Your crankshaft is in the mail, @The Gman...! I dropped it off at the Fedex in my local office depot... :thumbs:
Don
