TNT9848
Replacement For Throttle Cable Assembly # 95-7657
TNT9848
Hi Experts-
i need a replacement throttle cable assembly for a 314-8 GT Classic.  The exploded view diagram lists it as part # 95-7657.
Any help will be greatly appreciated.
Tim
peter lena
@TNT9848 this what i use , look at temp range , and rating , on my cables . do a vertical hang spray down to insure , lube end to end ,https://www.super-lube.com/multi-purpose-lubricant-with-syncolon-ptfe, this also comes in a small liquid tube .and as a paste. you also might consider adding a pull spring to that cable , like this , done this on 3 horses , easy simple spring assist that makes a cable work as it should , those perforated mount areas are easily added to any  screw / bolt mount area . h/w store metal section . pete
