jtrosp1980 89 #1 Posted November 18, 2021 I was able to swing by the house last weekend with a load lets just say it wasn't a good weekend I attempted to put a head gasket on and broke a headbolt in the block tried to drill it out with no success which in return called a few shops they are telling me the block is junk now what would be my best option at this point Share this post Link to post Share on other sites
SylvanLakeWH 27,600 #2 Posted November 18, 2021 Have you tried an easyout bolt extractor? They work pretty well… Share this post Link to post Share on other sites
ebinmaine 70,810 #3 Posted November 18, 2021 4 minutes ago, SylvanLakeWH said: easyout With the right nice sharp center punch and the right drill for the right size easy out you'll likely fix it yourself. With lots of heat in some situations too. A lot of modern repair shops don't want to work on non modern engines anymore. Share this post Link to post Share on other sites
jtrosp1980 89 #4 Posted November 18, 2021 Yes tried that then I drilled hole size for 7/16 not 1/2 Share this post Link to post Share on other sites
jtrosp1980 89 #5 Posted November 18, 2021 Looking up parts for this tecumseh has been a nightmare wondering would a k241 go on without alot of modifications Share this post Link to post Share on other sites
bc.gold 3,403 #6 Posted November 18, 2021 Use a drill bushing to keep ya centered, now with the possibility your hole is off center it's still possible to remove the broken bolt but you'll need several bushings. Your first bushing needed will accept a small drill bit just large enough the catch the side of the hole already drilled, then work up to the next size. If you drilled into the threaded engine block once the bolt has been removed you can install a threaded insert, video below. 1 Share this post Link to post Share on other sites
jtrosp1980 89 #7 Posted November 18, 2021 I will look into it Share this post Link to post Share on other sites
oliver2-44 10,372 #8 Posted November 18, 2021 @bc.gold Are you suggesting to make a steel plate that could be clamped to the block, Then to hold Festus it to hold one drill bushing at a time to gradually get recentered to drill the bolt out Share this post Link to post Share on other sites
bc.gold 3,403 #9 Posted November 18, 2021 6 minutes ago, oliver2-44 said: @bc.gold Are you suggesting to make a steel plate that could be clamped to the block, Then to hold Festus it to hold one drill bushing at a time to gradually get recentered to drill the bolt out He already has a guide plate, reinstall the cylinder head then install the drill bushing. The shop told him the engine was junk, from previous smutt jobs they learned customers often abandoned their property when handed the bill for labor. 2 Share this post Link to post Share on other sites
Achto 28,806 #10 Posted November 18, 2021 1 hour ago, ebinmaine said: With the right nice sharp center punch and the right drill for the right size easy out you'll likely fix it yourself. With lots of heat in some situations too. Never combine heat and an "easy out", less you wish to buy a new "easy out". Tried this with a few different brands of "easy outs" (Snap On, Matco, DeWalt, Harbor Freight, square shape, spiral shape) wrecked every one of them. 1 Share this post Link to post Share on other sites
ebinmaine 70,810 #11 Posted November 18, 2021 7 minutes ago, Achto said: Never combine heat and an "easy out", less you wish to buy a new "easy out". Tried this with a few different brands of "easy outs" (Snap On, Matco, DeWalt, Harbor Freight, square shape, spiral shape) wrecked every one of them. Take the temper out of the metal does it? 1 Share this post Link to post Share on other sites
Snoopy11 5,717 #12 Posted November 18, 2021 I've got a bad word for those shops. Do you have access to a mig welding machine per chance? Don 1 Share this post Link to post Share on other sites
Snoopy11 5,717 #13 Posted November 18, 2021 I use this method... but I have a welding machine. I know that @TJ salyers had a similar issue, but as I recall, he does not have a mig... You take a wrench, preferably and old one that you don't like very much... and weld through the wrench, filling the interior of the round end. Then... you simply turn out the bolt... Don 1 Share this post Link to post Share on other sites
Snoopy11 5,717 #14 Posted November 18, 2021 BTW... if you use a chromly wrench... ordinarily... the welding rod will not bond to the wrench. Additionally, you really want to pull back on your welding gun... holding it approximately an 3/4 to an inch or more from the bolt... so the rod builds up inside the wrench opening... Don Share this post Link to post Share on other sites
Herder 2,354 #15 Posted November 18, 2021 I've used a wrench to hold a nut in place over the broken bolt and filled in the nut with the mig welder. Allow it to cool enough to strengthen and turn it out. Most times it works on the first attempt. Yes, I have had some that I needed to repeat more than once in order to get the broken bolt extracted. Cover the cylinder bore to avoid getting slag into it. 2 1 Share this post Link to post Share on other sites
Snoopy11 5,717 #16 Posted November 19, 2021 22 hours ago, Herder said: I've used a wrench to hold a nut in place over the broken bolt and filled in the nut with the mig welder. Allow it to cool enough to strengthen and turn it out. Most times it works on the first attempt. Yes, I have had some that I needed to repeat more than once in order to get the broken bolt extracted. Cover the cylinder bore to avoid getting slag into it. Don Share this post Link to post Share on other sites
jtrosp1980 89 #17 Posted December 21, 2021 Some progress got motor to run got some electrical done IMG_1056.3gp 2 Share this post Link to post Share on other sites
ebinmaine 70,810 #18 Posted December 21, 2021 Just looking at the pics. Thread title is 1970. That's a 68 or 69 by the hood. Is the engine a '70 or have you checked the tractor numbers? Good to see the progress. Share this post Link to post Share on other sites
Handy Don 13,340 #19 Posted December 22, 2021 On 11/18/2021 at 2:33 PM, Herder said: I've used a wrench to hold a nut in place over the broken bolt and filled in the nut with the mig welder. Allow it to cool enough to strengthen and turn it out. Most times it works on the first attempt. Yes, I have had some that I needed to repeat more than once in order to get the broken bolt extracted. Cover the cylinder bore to avoid getting slag into it. Neat trick. Course the intense heat/cool of the bolt may assist with the removal, too. Share this post Link to post Share on other sites
