peter lena 8,971 #1 Posted November 17, 2021 if you want to easily improve your electrical grounding areas / accessibility , I regularly use this type of electrical lug , to carry on my power flow , https://www.grainger.com/product/BLACKBURN-Mechanical-Connector-3LN35?opr=IDPPLARECS&analytics=PLAPDP_undefined , you can easily find this type of lug at your local H/W store . only using the picture to give you an idea . but if you are setting up an electrical , anything , it would pay ,to have a few of these in your mounting areas . think about it , once bolted in place with dielectric grease and serrated washer , a flat screwdriver gives you easy access. they always come to mind in making things better , sorry if i offended anyone by daring to go off original set up , always experimenting , pete 3 Share this post Link to post Share on other sites
ri702bill 8,749 #2 Posted November 17, 2021 Also gives you a solid point(s) for the ground probe of a multimeter. Still grease, but not green !!! Bill 1 Share this post Link to post Share on other sites
ri702bill 8,749 #3 Posted November 17, 2021 1 hour ago, peter lena said: sorry if i offended anyone by daring to go off original set up , always experimenting , pete Pete: Let them get over it!! No different than chucking the ammeter for a voltmeter, upgrading to LED lights or adding a non factory fuse for safety (as the 702, 854, and C81 had NONE) Bill 4 1 Share this post Link to post Share on other sites
peter lena 8,971 #4 Posted November 17, 2021 @ri702bill just got back from a road , cul de sac drive , couple of miles , also just dropped my 42 " RD DECK , clean and clear no build up or rot , upside down now soaking in lubriplate chain and cable oil over winter . next swap to snow plow . everything working well , pete Share this post Link to post Share on other sites
ri702bill 8,749 #5 Posted November 17, 2021 Nice - Cecil & Elmer would be right proud how you take care or their Horses .... Yup, next up I need to get the 854 8 speed and the c81 out of their summer clothes and dressed for winter duty...... Bill 1 Share this post Link to post Share on other sites
peter lena 8,971 #6 Posted November 20, 2021 @ri702bill those electrical lugs are also an excellent upgrade in a cable mount snow blower chute area. unscrew the original cable to floppy chute mount . drill out pop rivet , use a 1/4" s/s bolt, washers and elastic lock nut , nut would go outside chute pull for clean operation , making a nice tight fit . lots of hours on this change over , on the blower , also added a teflon slide ring under the chute to blower housing base, swivels with ease . this is not in the book , but it sure does work easily . pete Share this post Link to post Share on other sites
ri702bill 8,749 #7 Posted November 20, 2021 Pete: Good idea on the teflon ring - where did you get the sheet stock for that?? Bill Share this post Link to post Share on other sites
