Mustang67ford 234 #1 Posted November 14, 2021 (edited) Changing tranny fluid in a 414-8. Manual says to use 90w. Is 80w90 ok? Woul be a little thinner in cold temps. Edited November 14, 2021 by Mustang67ford 1 Share this post Link to post Share on other sites
ebinmaine 67,593 #2 Posted November 14, 2021 That's fine. We use whatever is the least expensive gear oil. These transmissions are not at all fussy. 4 Share this post Link to post Share on other sites
Achto 27,601 #3 Posted November 14, 2021 80-90w will be just fine. 5 Share this post Link to post Share on other sites
Mustang67ford 234 #4 Posted November 14, 2021 Thanks Share this post Link to post Share on other sites
peter lena 8,634 #5 Posted November 14, 2021 @Mustang67ford in addition to changing it , keep a regular check on it , is your shift boot ok ? that's your water entry point, always have a spare in my horse parts inventory . i use a razor blade to remove it and dielectric grease on the shifter shaft to install it , slides on very easily . pete 2 Share this post Link to post Share on other sites
ebinmaine 67,593 #6 Posted November 14, 2021 @Mustang67ford Also just occurred to me... When you drain the transmission be sure to raise the front of the tractor as much as safely possible to get the fluid over the internal center hump. 4 Share this post Link to post Share on other sites
Mustang67ford 234 #7 Posted November 14, 2021 1 hour ago, peter lena said: @Mustang67ford in addition to changing it , keep a regular check on it , is your shift boot ok ? that's your water entry point, always have a spare in my horse parts inventory . i use a razor blade to remove it and dielectric grease on the shifter shaft to install it , slides on very easily . pete Thanks. I have one on the parts list. It does need replaced. 1 Share this post Link to post Share on other sites
Mustang67ford 234 #8 Posted November 14, 2021 (edited) 35 minutes ago, ebinmaine said: @Mustang67ford Also just occurred to me... When you drain the transmission be sure to raise the front of the tractor as much as safely possible to get the fluid over the internal center hump. Thanks. I had read about the hump. How high must I raise it? I might also flush it, not sure yet. Edited November 14, 2021 by Mustang67ford Share this post Link to post Share on other sites
ebinmaine 67,593 #9 Posted November 14, 2021 4 minutes ago, Mustang67ford said: Thanks. I had read about the hump. How high must I raise it? I might also flush it, not sure yet. I try to get the front a good strong 25+ inches up. Use great caution when doing the lift unless you have a very secure lift mechanism. >>>>> I have a hoist. <<<<< On the flush, if you are considering it, just do it. It likely needs it anyway and it most certainly won't hurt anything. Drain the old fluid. Install plug and fill will 2, 2.5 qts diesel or kerosene. Drive it around in a few figure 8s and be sure to use every gear including hi and low range. Empty the sacrificial fluid. If the fluid looks milky or dirty don't hesitate to repeat the flush part. 2 Share this post Link to post Share on other sites
Mustang67ford 234 #10 Posted November 14, 2021 7 minutes ago, ebinmaine said: I try to get the front a good strong 25+ inches up. Use great caution when doing the lift unless you have a very secure lift mechanism. >>>>> I have a hoist. <<<<< On the flush, if you are considering it, just do it. It likely needs it anyway and it most certainly won't hurt anything. Drain the old fluid. Install plug and fill will 2, 2.5 qts diesel or kerosene. Drive it around in a few figure 8s and be sure to use every gear including hi and low range. Empty the sacrificial fluid. If the fluid looks milky or dirty don't hesitate to repeat the flush part. Thanks, very helpful. 1 1 Share this post Link to post Share on other sites
Handy Don 12,235 #11 Posted November 14, 2021 44 minutes ago, Mustang67ford said: Thanks, very helpful. And , if flushing, please dispose of the sacrificial fluid responsibly. In NYS, automotive service stations are required to accept used motor and gear oils but can refuse any contaminated with gasoline or diesel fuel. I've been paying a recycling center to take it. Share this post Link to post Share on other sites
ebinmaine 67,593 #12 Posted November 14, 2021 20 minutes ago, Handy Don said: And , if flushing, please dispose of the sacrificial fluid responsibly. In NYS, automotive service stations are required to accept used motor and gear oils but can refuse any contaminated with gasoline or diesel fuel. I've been paying a recycling center to take it. We burn 🔥🔥 it. 4 Share this post Link to post Share on other sites
Maxwell-8 4,277 #13 Posted November 15, 2021 I even use 85w140, wouldn't recommend it, but haven't had a single problem. Share this post Link to post Share on other sites
Mustang67ford 234 #14 Posted March 22, 2022 (edited) On 11/14/2021 at 12:45 PM, ebinmaine said: I try to get the front a good strong 25+ inches up. Use great caution when doing the lift unless you have a very secure lift mechanism. >>>>> I have a hoist. <<<<< On the flush, if you are considering it, just do it. It likely needs it anyway and it most certainly won't hurt anything. Drain the old fluid. Install plug and fill will 2, 2.5 qts diesel or kerosene. Drive it around in a few figure 8s and be sure to use every gear including hi and low range. Empty the sacrificial fluid. If the fluid looks milky or dirty don't hesitate to repeat the flush part. @ebinmaine I 'm going to have the tranny disconnected from the tractor here shortly when changing out my frame. Since the front needs raised steeply to get over the hump, I'm thinking this is a good time to do the flush. But tracgor is not running yet. Maybe just fill with the kero and push it around by hand some once it is disconnected and rock it back and forth would do it? Also, is there a recommended magetic drain plug to use and I assume it is a square head as opposed to a factory recessed allen type plug? Edited March 22, 2022 by Mustang67ford Share this post Link to post Share on other sites
ebinmaine 67,593 #15 Posted March 22, 2022 1 hour ago, Mustang67ford said: @ebinmaine I 'm going to have the tranny disconnected from the tractor here shortly when changing out my frame. Since the front needs raised steeply to get over the hump, I'm thinking this is a good time to do the flush. But tracgor is not running yet. Maybe just fill with the 1. kero and push it around by hand some once it is disconnected and rock it back and forth would do it? 2. Also, is there a recommended magetic drain plug to use and I assume it is a square head as opposed to a factory recessed allen type plug? 1. If not running that's a perfectly reasonable thing to do. IIFF YOU HAVE WORKING BRAKES on a rolling chassis you could have another person tow the roller with an operator on it. K1 or diesel is fine. Off-road diesel is less expensive if that's available to you. 2. I bought square head standard magnetic plugs. The thing to remember there is that the male type square head sticks out of the transmission housing and has potential to catch on rough terrain. When we make our forest trails we're conscious of not going over larger roots and rocks. 2 Share this post Link to post Share on other sites
stevasaurus 22,764 #16 Posted March 22, 2022 I clamp the transmission on the work bench and use an old plug in furnace motor (also clamped) with a 4" pulley and fan belt. You can run diesel in it which ends up being about regular speed. I also use this setup to test the transmissions that I rebuild before I put them back on the tractors. Here is another way that works... 1 Share this post Link to post Share on other sites
Mustang67ford 234 #17 Posted March 25, 2022 On 3/22/2022 at 11:36 AM, stevasaurus said: I clamp the transmission on the work bench and use an old plug in furnace motor (also clamped) with a 4" pulley and fan belt. You can run diesel in it which ends up being about regular speed. I also use this setup to test the transmissions that I rebuild before I put them back on the tractors. Here is another way that works... Good idea Share this post Link to post Share on other sites
