8ntruck 7,395 #51 Posted November 19, 2021 16 hours ago, ebinmaine said: Niiiiiiice. So this valve turns on and off as needed? Compressor builds 100% of the time and the valve releases when creating pressure isn't needed? What's the in/out pressure able to be set at? The unloader valve on my compressor opens some sort of bypass valve on the cylinders when the set pressure is reached. It sounds like the cylinders are 'breathing' in and out while the unloaded valve is open. 4 Share this post Link to post Share on other sites
R Scheer 505 #52 Posted November 19, 2021 On mine there are 2 valves at the top of each cylinder. One is a check valve so that if the cylinder pressure is higher than the air reservoir it opens and allows the piston to push the air into the reservoir. The second valve (unloader valve) is operated by the air pressure in the reservoir, once the air pressure exceeds a set value it opens and air will be allowed to go back to the intake, (think of a stuck open intake valve in a car engine), so the compressor freewheeling. Once the air pressure in the reservoir drops below a set pressure the unloader valve closes and the compressor starts compressing. Pressure values are 120 and 90. This also means that you need some kind of air reservoir, otherwise the unloader valve will be continuously opening and closing. That's my understanding of how my compressor works anyways. 2 Share this post Link to post Share on other sites
8ntruck 7,395 #53 Posted November 19, 2021 So that is how they work. I've never taken my compressor apart to find out. 1 Share this post Link to post Share on other sites
R Scheer 505 #54 Posted November 19, 2021 Mine's old, most of these parts are external, easier for me to understand when I can see it. 1 Share this post Link to post Share on other sites
Southern_Secret 464 #55 Posted November 22, 2021 On 11/18/2021 at 3:43 AM, ebinmaine said: Niiiiiiice. So this valve turns on and off as needed? Compressor builds 100% of the time and the valve releases when creating pressure isn't needed? What's the in/out pressure able to be set at? They come pre-set from 125psi to 175psi, the way it works is once the set psi is reached it has a blow by and it bypasses the air into the atmosphere. when the tank gets below that pressure the valve closes and puts the air back in the tank, so your compresser never stops running. 1 2 Share this post Link to post Share on other sites
ebinmaine 70,792 #56 Posted November 22, 2021 54 minutes ago, Southern_Secret said: They come pre-set from 125psi to 175psi, the way it works is once the set psi is reached it has a blow by and it bypasses the air into the atmosphere. when the tank gets below that pressure the valve closes and puts the air back in the tank, so your compresser never stops running. So one could conceivably run the compressor off the engine PTO until full, then kick out PTO unless more air is needed. The unloader valve would be the "safety switch" to prevent overfilling. 2 1 Share this post Link to post Share on other sites
Maxwell-8 4,366 #57 Posted November 22, 2021 I got me a tank. 52 gallons extra sturdy. A bit to big for the task, No? @ 110 pounds for the tank and 55 pounds for the compressor I am starting to worry about weight on that front-end. 3 Share this post Link to post Share on other sites
Snoopy11 5,717 #58 Posted November 22, 2021 (edited) 58 minutes ago, Maxwell-8 said: I am starting to worry about weight on that front-end. Counterweight!!! Start eating cookies immediately! Don Edited November 22, 2021 by Snoopy11 3 Share this post Link to post Share on other sites
Maxwell-8 4,366 #59 Posted November 22, 2021 12 minutes ago, Snoopy11 said: Counterweight!!! Start eating cookies immediately! Don Haha, I only weigh 140lbs @ 6 foot 1 Share this post Link to post Share on other sites
Snoopy11 5,717 #60 Posted November 22, 2021 1 minute ago, Maxwell-8 said: Haha, I only weigh 140lbs @ 6 foot Hmm... now that is a problem. Add 100 lbs, and 3-4 inches, and you would have me... Don 2 Share this post Link to post Share on other sites
ebinmaine 70,792 #61 Posted November 22, 2021 3 hours ago, Maxwell-8 said: Haha, I only weigh 140lbs @ 6 foot I'm only 6'-1"+ at 262 lbs. Headed downward... 4 hours ago, Maxwell-8 said: @ 110 pounds for the tank and 55 pounds for the compressor I am starting to worry about weight on that front-end At 165 lbs you're right in the range of what my Mackissic chipper is. I'm not sure what a 2 stage snowblower weighs in at. IMHO, you're just fine. 1 1 1 Share this post Link to post Share on other sites
Southern_Secret 464 #62 Posted November 23, 2021 On 11/22/2021 at 12:18 PM, ebinmaine said: So one could conceivably run the compressor off the engine PTO until full, then kick out PTO unless more air is needed. The unloader valve would be the "safety switch" to prevent overfilling. No sir, when your tank reaches the set pressure the valve opens on it's own. You never have to disengage the pto or anything like that. You can also run a cable from the valve to the throttle and it will drop you power unit down to an idle, but there is no need for that on his set up. 1 2 Share this post Link to post Share on other sites
Handy Don 13,340 #63 Posted November 23, 2021 (edited) On 11/22/2021 at 2:07 PM, Maxwell-8 said: @ 110 pounds for the tank and 55 pounds for the compressor I am starting to worry about weight on that front-end. You might consider a caster mount, similar to the front mount for a mowing deck. Edited November 23, 2021 by Handy Don 3 1 Share this post Link to post Share on other sites
ebinmaine 70,792 #64 Posted November 23, 2021 1 minute ago, Handy Don said: You might consider a caster mount, similar to the front mount for a mowing deck. That's not a bad idea for those that live on flat ground. 1 Share this post Link to post Share on other sites
Maxwell-8 4,366 #65 Posted November 23, 2021 (edited) 22 minutes ago, Handy Don said: You might consider a caster mount, similar to the front mount for a mowing deck. I have been considering that. I have some casters laying around. But I may be looking for a smaller tank. 52 gallons is way more then I will need. But we will see. Edited November 23, 2021 by Maxwell-8 1 Share this post Link to post Share on other sites
Bill D 2,095 #66 Posted November 26, 2021 Mount the pump on the front. Run a high temp hose from the pump to the back of the tractor. Make a trailer for the tank and tow the tank. Use a quick disconnect to connect two. Option two, buy a very small tank and mount it to the back of the tractor. I have seen people make air tanks out of old propane tanks. However, that could be dangerous. It would be safer to buy a proper air tank. 3 1 Share this post Link to post Share on other sites
Maxwell-8 4,366 #67 Posted January 5, 2022 (edited) On 11/26/2021 at 6:47 AM, Bill D said: Mount the pump on the front. Run a high temp hose from the pump to the back of the tractor. Make a trailer for the tank and tow the tank. Use a quick disconnect to connect two. Option two, buy a very small tank and mount it to the back of the tractor. I have seen people make air tanks out of old propane tanks. However, that could be dangerous. It would be safer to buy a proper air tank. Thanks for the tips! Maybe a small update, I got a smaller and lighter tank, which I will most likely will install in the front. I have had little time lately. Will get back in this project in the start of February. Edited January 5, 2022 by Maxwell-8 1 3 Share this post Link to post Share on other sites
sjoemie himself 3,076 #68 Posted January 6, 2022 Just scrolled through this topic. Very interesting concept, i'm curious how the endproduct will perform. I'll keep this in mind as one of many possible front attachments. I've been thinking of woodchipper, leafblower, generator.. all pretty interesting. One can dreams, right? 😁 2 Share this post Link to post Share on other sites
ebinmaine 70,792 #69 Posted January 6, 2022 25 minutes ago, sjoemie himself said: woodchipper....., generator. I have a Mckissick chipper shredder. Just. Get. One. It's a lovely attachment. I do also have a generator though I have yet to get a bracket made up. 3 Share this post Link to post Share on other sites
Maxwell-8 4,366 #70 Posted January 6, 2022 6 hours ago, ebinmaine said: I have a Mckissick chipper shredder. Just. Get. One. Searched the heck for one, brand was never brought to the EU. But have seen some possible Bolens contenders. 3 Share this post Link to post Share on other sites
sjoemie himself 3,076 #71 Posted January 6, 2022 @ebinmaine Yeah I think the chance of finding 'factory' attachments overhere in Europe is pretty slim. The only tractors that i've seen being offered complete with attachments like a tiller, chipper, mower and bagging attachments are the Case/Ingersoll tractors. Very beautiful and complete but also quite pricey (~$2500 - $3500) 😭 I was thinking more in the line of what @Maxwell-8 is doing and adapt and combine components to make them fit the attach-a-matic, so more of a custom job. 3 Share this post Link to post Share on other sites
ebinmaine 70,792 #72 Posted January 6, 2022 40 minutes ago, sjoemie himself said: adapt and combine components to make them fit the attach-a-matic, so more of a custom job. I enjoy watching those type of builds just as much if not more. The thought processes that go into creating implements or tractor modifications are very interesting. With careful selection and some thought one can come up with a solution that may be more fit to the needs 3 Share this post Link to post Share on other sites
kpinnc 13,761 #73 Posted January 7, 2022 Why not use the pressure switch to actuate an electric PTO? The bypass could then be the backup safety... 1 Share this post Link to post Share on other sites
Maxwell-8 4,366 #74 Posted May 2, 2022 Just found this in a WH brochure: Didn't knew you could get this as an option. Haven't seen one. Does anyone have one? would love to know how it works to fabricate mine. 5 Share this post Link to post Share on other sites
ebinmaine 70,792 #75 Posted May 2, 2022 @c-series don @WHX?? @Achto You boys seen one o these in person? 1 1 Share this post Link to post Share on other sites
