Walleye Guy 22 #1 Posted November 9, 2021 My dad is rebuilding a 753 Wheel Horse that my grandfather bought new in 1963. There is a plastic bushing/collar that fits into the top of the two-piece fuel tank in which the steering shaft passes through. Ours appears worn so my dad would like to replace it but it isn't listed in the exploded parts diagram. At least we couldn't find it and I looked a few times. Does anyone have a P/N for that part? If I'm correct about it not being listed, does anyone have another P/N from a different model that would be a good substitute? Thanks in advance for any help. Share this post Link to post Share on other sites
ri702bill 8,969 #2 Posted November 9, 2021 Check McMaster Carr. 1 Share this post Link to post Share on other sites
953 nut 57,904 #3 Posted November 9, 2021 I don't know of a part number for the bushing and doubt that anyone could obtain one for a nearly six decade old by the numbers. You might need to take a look in the plumbing section or hardware section of your local hardware/plumbing supply store for a plastic bushing that will work. 2 Share this post Link to post Share on other sites
peter lena 9,088 #4 Posted November 9, 2021 @Walleye Guy that bushing is probably in your local h/w store small pull out drawer section , get it in bronze , and use a chassis grease on it. also a good opportunity to go after all related steering linkage , use an aerosol spray lube to make the rust un out , then chassis grease . take advantage of what works , verify its function , then refresh it , wiring or mechanical , eliminate , chafing or wear areas . just my own experience , good luck , pete 2 Share this post Link to post Share on other sites
RandyLittrell 3,894 #5 Posted November 9, 2021 12 minutes ago, peter lena said: that bushing is probably in your local h/w store small pull out drawer section It is amazing the things they have in those drawers and one reason I try to buy from my LHS all I can!! Randy 3 Share this post Link to post Share on other sites
Walleye Guy 22 #6 Posted November 9, 2021 Yes, the local hardware store and McMaster Carr are both great ideas. I can also have one made if it's an oddball size. However, are we all in agreement that a part number isn't listed in the factory parts list/diagram? 2 Share this post Link to post Share on other sites
Gregor 4,847 #7 Posted November 9, 2021 Item 15 is an "Ass'y Fuel Tank" That bushing must be part of the assembly. Share this post Link to post Share on other sites
Walleye Guy 22 #8 Posted November 9, 2021 Gregor, good catch...I didn't notice that on the parts diagram descriptions. Share this post Link to post Share on other sites
ri702bill 8,969 #9 Posted November 9, 2021 49 minutes ago, Gregor said: Item 15 is an "Ass'y Fuel Tank" That bushing must be part of the assembly. ... and probably NLA, like most of the Round Hood specific parts. Bill Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,243 #10 Posted November 9, 2021 This is what is used on the 1985-1992 300, 400 and 500 series https://www.partstree.com/parts/toro-109189/ Share this post Link to post Share on other sites
Kenneth R Cluley 582 #11 Posted November 9, 2021 Just bought one for my 653 project, 3/4" ID don't recall OD and length. Found it @ Ace hardware. Nylon shoulder bushing. Also available at Mcmaster Carr. Share this post Link to post Share on other sites
Kenneth R Cluley 582 #12 Posted November 9, 2021 3/4" id X 7/8" od X 1" LONG. Share this post Link to post Share on other sites
wallfish 17,494 #13 Posted November 10, 2021 Oilite bronze flange bushing Share this post Link to post Share on other sites
J854D 137 #14 Posted November 10, 2021 @Walleye Guy Wheel Horse Parts and More is a vendor on this site. (look in the Classifieds section under vendors) Lowell has a listing for a #1539 sterring bushing in the sterring catagory on his website. It appears to be nylon. I found a listing with that part number in the illustrated parts list for a 1963 Wheel Horse Ranger model 33E & 33R. The fuel tank on that year Ranger looks very similar to the fuel tanks on a 753 and 854 Wheel Horse. I’ll bet that will work for your 753. -JD- Share this post Link to post Share on other sites
Walleye Guy 22 #15 Posted November 10, 2021 Ken, thanks for that info. I'll have my dad verify those dimensions on the original bushing. J854D, thanks for the tip on the #1539 bushing. We'll look into that. Share this post Link to post Share on other sites
