peter lena 8,639 #1 Posted November 7, 2021 referring to a regular issue of often corroded engine tin / cooling tins . try this out , battery ground rail , 4 ga cable main line , add to battery ground bolt point. cable down to lower corner of engine to frame bolt , serrated washers and dielectric grease, cable up to rectifier , mounting point , then up to headlight mounting point , unscrew every " tin " mounting bolt , reinstall with dialectic grease . this simple upgrade has eliminated my electrical problems . obviously if you have frayed or corroded connections , that s another upgrade . but this grounding enhancement , has made a problem go away , pete 4 1 Share this post Link to post Share on other sites
ebinmaine 67,672 #2 Posted November 7, 2021 Good info Pete. I'm prone to grounding individual components. I run the main battery ground to engine block. Separate grounds to VR, all gauges, solenoid etc. 3 Share this post Link to post Share on other sites
Handy Don 12,237 #3 Posted November 7, 2021 9 minutes ago, ebinmaine said: I'm prone to grounding individual components. It always seemed odd to me to trust unpainted metal to make lasting electrical connections on outdoor equipment, especially across several components. Tail lights attached to a fender bolted to brackets bolted to the transmission bolted to the frame is a good example. Dielectric grease on a direct-wired ground connection is my favored route. 5 Share this post Link to post Share on other sites
peter lena 8,639 #4 Posted November 7, 2021 @Handy Don , @ebinmaine , use the electrical mechanical lug type connectors , once mounted , always a simple place to go to , https://www.homedepot.com/p/Southwire-14-SOL-STR-2-STR-Dual-Rated-Mechanical-Lug-with-Single-1-4-in-Hole-Mount-2-Pack-65180440/312651943?source=shoppingads&locale=en-US&&mtc=Shopping-VF-F_D27E-G-D27E-027_011_TOOLS_ACC-NA-NA-Feed-SMART-2181312-WF-New_Engen+PL3&cm_mmc=Shopping-VF-F_D27E-G-D27E-027_011_TOOLS_ACC-NA-NA-Feed-SMART-2181312-WF-New_Engen+PL3-71700000082410808-58700006989412257-92700062912530339&gclid=Cj0KCQjw8p2MBhCiARIsADDUFVFzTzZ1LhmYsUTCdNTm6Dq-v_tblqWNFQpCtVG3QvcYFCOEhMWt5EYaAtt3EALw_wcB&gclsrc=aw.ds , this type of cable / wire connection , makes grounding or related connections easy . they also do not fail , pete 2 1 Share this post Link to post Share on other sites
Jeff-C175 7,202 #5 Posted November 7, 2021 Wonder why that pasted link is so long when this one does exactly the same thing? https://www.homedepot.com/p/Southwire-14-SOL-STR-2-STR-Dual-Rated-Mechanical-Lug-with-Single-1-4-in-Hole-Mount-2-Pack-65180440/312651943 What is all that gobbledygook in that link? Share this post Link to post Share on other sites
ebinmaine 67,672 #6 Posted November 7, 2021 3 minutes ago, Jeff-C175 said: What is all that gobbledygook in that link? Could be a coding issue from whatever device is being used. My phone offers a very different experience from the PC. 1 Share this post Link to post Share on other sites
pfrederi 17,741 #7 Posted November 7, 2021 Unless it is a Kohler Magnum, with the regulator in the air shroud I can't see any reason the engine tins need to be grounded 2 Share this post Link to post Share on other sites
squonk 41,161 #8 Posted November 7, 2021 (edited) A good clean block connection point and a good clean terminal with good cables lasts for years. We ain't flying the shuttle loaded with electronics here. On my engine test stand I was having a generator issue. I checked my ground resistance and it was in the mega-ohm range. Just cleaning one rusty lug on the generator frame brought the entire circuit under 2 ohms. Edited November 7, 2021 by squonk 3 Share this post Link to post Share on other sites
peter lena 8,639 #9 Posted November 7, 2021 @Jeff-C175 might have been attached to a previous search , , btw , those lugs are a very good alternative on a snow blower chute pull swivel area . the original 2 screw set up on the cable , is minimal at best , drill out the rivet mount and use a 1/4 bolt with washers and elastic lock nut , just another experimental trouble spot , that is long gone , pete 1 Share this post Link to post Share on other sites
Handy Don 12,237 #10 Posted November 7, 2021 3 hours ago, Jeff-C175 said: Wonder why that pasted link is so long when this one does exactly the same thing? https://www.homedepot.com/p/Southwire-14-SOL-STR-2-STR-Dual-Rated-Mechanical-Lug-with-Single-1-4-in-Hole-Mount-2-Pack-65180440/312651943 What is all that gobbledygook in that link? THAT my fellow members, is how Home Depot and Google track where you found the link to their product. Within that long string of letters are a bunch of &<label>=<text> segments. Each one can contain information about cookies that were found on your machine, what webpage you got the link from, what ISP you use for internet access, information about your computer, and more. Usually the "text" is encoded so you cannot easily see what they are taking from you. https://www.homedepot.com/p/Southwire-14-SOL-STR-2-STR-Dual-Rated-Mechanical-Lug-with-Single-1-4-in-Hole-Mount-2-Pack-65180440/312651943 ?source=shoppingads (what marketing channel reached you?) &locale=en-US (where are you and what language are you using in your browser?) &mtc=Shopping-VF-F_D27E-G-D27E-027_011_TOOLS_ACC-NA-NA-Feed-SMART-2181312-WF-New_Engen+PL3 (which specific product are you looking at?) &cm_mmc=Shopping-VF-F_D27E-G-D27E-027_011_TOOLS_ACC-NA-NA-Feed-SMART-2181312-WF-New_Engen+PL3-71700000082410808-58700006989412257-92700062912530339 (which product in which store location of Home Depot?) &gclid=Cj0KCQjw8p2MBhCiARIsADDUFVFzTzZ1LhmYsUTCdNTm6Dq-v_tblqWNFQpCtVG3QvcYFCOEhMWt5EYaAtt3EALw_wcB (Google ad tracking ID from a cookie on your computer) &gclsrc=aw.ds (how was the ad tracking ID placed on your computer, also known as the marketing "campaign"?) 1 2 Share this post Link to post Share on other sites
roadapples 6,983 #11 Posted November 7, 2021 Agree with above. You need a clean connection for the wire and dielectric grease will protect it indefinitely. Silicone grease is hard to get rid of.... 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,050 #12 Posted November 8, 2021 One place that is often overlooked is the starter. When one is disassembled the ends of the field housing, the commutator end plate and the drive end plates should be wire brushed to restore the ground path they provide. 3 2 Share this post Link to post Share on other sites
