Oldskool
Custom golf cart
Pullstart
Maybe try a Venturi style pipe expansion?  If the pipe on the snow machine is 1.5”, run a 1.75” tube over the end for a few inches.  Allow a gap, but plan on the movement of air to suck more fresh air through?  I don’t know, but that would be how I start.  At the end of the day, I doubt you’re using all the power the engine has to offer, so it shouldn’t matter too much.
Oldskool
You are probably correct with that assumption.
I've heard stories of "don't mess with snowmobile exhaust" I just don't want to melt a piston because I altered the exhaust
wallfish
  On 3/24/2023 at 9:43 AM, Oldskool said:
 @Pullstart any thoughts on if it is possible to add pipe to a snowmobile exhaust beyond the muffler/expansion chamber without any ill effects.
I would like to extend it to the back of the buggy
Don't go too small which would create any additional back pressure and you should be fine. Basically just directing the flow to the rear with a bigger pipe.
Kevin's idea may allow for using a smaller pipe by allowing air to suck in at that connection
Oldskool
My thought was going another 1/3 bigger on the dia. due to having some bends in it
  • Similar Content
    • Oldskool
      By Oldskool
      Hey guys I have been given a box of these flap wheels.
      5.25" x 1.5" with a 1" arbor hole.
      I instantly thought great I can put one on my bench grinder.
      Nope!    Not that simple.
      The arbor size is different, and it's to wide to fit inside the the guard.
      I thought of removing the guard but would like to have it there.
      I guess I could make an arbor adapter and a spacer for the guard,and a new tool rest,etc. More time involved then first thought.
      Does anyone use these, and if so what do you have it on?
    • c100rider
      By c100rider
      Hello fellas. I bought this 211-3 tractor. I have no clue how this mower deck comes off. I need to fix some areas on the deck, as well as replace a clutch cable. I can't seem to find pictures of a complete deck for this model as it should be. Need help.
    • Oldskool
      By Oldskool
      Let's see your view from your workplace "window". I know some are driving truck,or tractor, work in shops/offices or outdoors. What is it that surrounds you during your work day?
    • Oldskool
      By Oldskool
      Can anyone ID this?
    • Oldskool
      By Oldskool
      I started a thread a little while back "Something from Nothing". It has been upgraded to this thread because now I'm building something from something lol. I started with a new frame and strengthened the transaxle mount a bit.
