Oldskool
Custom golf cart
Oldskool
As luck would have it I was just gifted 18 metal newel posts. Approx 1-1/4 square by 30+ish inches long approx 16-14ga. material.
 I think those will come in quite handy.
Stormin
 Forgot all about this. got me wondering which will get finished soonest? Custom golf cart or Colossus?
  • Haha 4
squonk
I think we all know the answer to that! :techie-hourglass:  :teasing-blah::teasing-blah::teasing-blah::confusion-helpsos::coffee::techie-computer::confusion-waiting:
  • Haha 3
Oldskool
Well that's a good question. Good bit of work to be done on either one.
SylvanLakeWH
Maybe you Mainahs could get together and build a colossal golf cart... :confusion-confused:
  • Haha 5
  • Heart 1
ebinmaine
That boy gotts a interesting idea.
I can near to guarantee it'll be the golf cart.
Oldskool
I have finally managed to get some shop time in.
Chopping and welding some of those newel posts together. Maybe I'll have a semi finished product later this afternoon.
  • Like 5
Oldskool
Not as far as I was hoping for today.
One step closer
  • Like 7
Oldskool
So I had a chance to walk around this project a couple times today after work while getting and putting away the snowblower.
I'm thinking of stiffening up the pipe frame a bit.
My dilemma is.... would welding 2in x 1/4"angle iron on the top of the the pipe like a cap give me enough strength?
Or would I be better off trusting it with 1"x1" 1/8" tubing turned 45degree from the pipe with sections of flat stock welding inbetween periodically?
OR some other method?
ebinmaine
If the tubes you built are 2" square I kinda like the option A.
Aesthetically it would be consistent and 1/4 is pretty rugged angle iron.
Oldskool
The frame is 2in ID pipe approx. 3/16 wall
TractorEd
I agree with eb.  But if it were me, I’d take a few more walks around and glances at it before thinking on it a bit.
Handy Don
I’d like to hear @Pullstart chime in on this with his experience on larger vehicles.
That pipe is pretty sturdy but it may need some stiffening to limit flex and possibly twisting. Hard to say at a distance.
Pullstart
I’d like to see some pictures of the ideas… hold a piece up and snap a pic for us to chew on maybe?  I do know one thing.  Triangulation trumps thickness whenever possible.  I’ve gotten some massive strength in my buggy front end (I’ve been getting the buggy itch lately) by adding this all diameter and thinner wall tubing, but with structurally sound design.
  • Like 4
wallfish
:text-yeahthat:
"Beefing it up" with triangles gives support in all directions. Like Kevin's buggy is. Even the original frame is triangles everywhere
Oldskool
Here are some ideas from scrap laying around. I will buy new when a design is settled on.
My trouble spot is the 5ft straight run of frame.
This rig won't be used for extreme off road. Mostly to carry the wife's and my butts to camp along with some coolers and such.
The biggest issue is the massive amount of potholes and ruts along the way.
ebinmaine
You get yaseff into the coolers n such enough and the crookedessness won't matter.  😂
  • Haha 2
Pullstart
Well, that’s triangulation to a point… it would prevent twisting for sure.
8ntruck
An acquaint of mine used to campaign an Olds Starfire in a road race series.  His roll cage  was triangulate in 3 dimensions into a point that was on the centerline of the car about a foot off the car's floor, just behind thedriver's seat.
That car also had an interesting carb.  Class rules limited the carb to a more or less stock Rochester 2 barrel.  That one was the big bore 2 barrel used on trucks, but with a casting number for the smaller class spec. carb.
Oldskool
I'm looking for most strength with the least amount of weight. I know it's probably a give and take
Oldskool
Did get to do some welding today.
I'm thinking this part will be hardtop.
From there to the windshield post will probably be much like a canvas type Jeep bikini top.
  • Excellent 4
Oldskool
I think this maybe the gas tank I'll use.
It's a generator tank. Possibly 2 -2.5 gallons. It will probably be mounted under the bed floor at the rear with access thru a hatch cover of sorts.
Handy Don
You might be surprised. My “square pancake” fuel tank on a 9hp generator holds 6+ gallons. That one doesn’t look much different. Post the dimensions and I’ll do the math!
Oldskool
I think it's about 18"x22"x4"
Handy Don
If it had squared corners, it’d be about 6.8 gallons. Since it’s a bit beveled on the sides, figure 6.5.
Nice!
Remember that gas weighs about 6 lbs per gallon (plus the tank itself) so you’ll need strong supports!
  • Similar Content
    • Oldskool
      By Oldskool
      Hey guys I have been given a box of these flap wheels.
      5.25" x 1.5" with a 1" arbor hole.
      I instantly thought great I can put one on my bench grinder.
      Nope!    Not that simple.
      The arbor size is different, and it's to wide to fit inside the the guard.
      I thought of removing the guard but would like to have it there.
      I guess I could make an arbor adapter and a spacer for the guard,and a new tool rest,etc. More time involved then first thought.
      Does anyone use these, and if so what do you have it on?
    • c100rider
      By c100rider
      Hello fellas. I bought this 211-3 tractor. I have no clue how this mower deck comes off. I need to fix some areas on the deck, as well as replace a clutch cable. I can't seem to find pictures of a complete deck for this model as it should be. Need help.
    • Oldskool
      By Oldskool
      Let's see your view from your workplace "window". I know some are driving truck,or tractor, work in shops/offices or outdoors. What is it that surrounds you during your work day?
    • Oldskool
      By Oldskool
      Can anyone ID this?
    • Oldskool
      By Oldskool
      I started a thread a little while back "Something from Nothing". It has been upgraded to this thread because now I'm building something from something lol. I started with a new frame and strengthened the transaxle mount a bit.
