Oldskool
Custom golf cart
Handy Don
1 hour ago, wallfish said:
Don't let @Handy Don ruin the inspiration with all of that fancy math and calculators he uses! :ychain:
Point taken!
A stronger hydro would make it a sure thing.
By way of comparison, the Eaton 700 can deliver more power that that tuff-turf. The 1100 is good to ~17hp.
wallfish
34 minutes ago, Handy Don said:
Point taken!
Just mess'n with ya again Don.
Taking the time to do that math in the beginning can definitely save some frustration in the end. 17hp would be enough
Oldskool
52 minutes ago, Handy Don said:
Point taken!
Any input on this?
19richie66
If you run a “drive shaft” yoke off the flywheel side of a kohler twin to the Eaton 1100 drive pulley(transmission turned sideways, drive pulley removed and replaced with said driveshaft yoke) the you could use the axles to drive a front and rear axle. I guess you would have to lock the differential somehow. Also no clutch needed as it’s a hydro drive.
Edited by 19richie66
ebinmaine
I haven't been into an Eaton yet but on a Sundstrand Hydro that's easy enough just by flipping alternate diff pins.
19richie66
I believe the diffs are similar if not the same.
Handy Don
14 hours ago, Oldskool said:
Any input on this?
Hydro-Gear is quite hard to research.
This unit predates their current model line and has the "old" label layout and coding. I couldn't find specs, only parts diagrams.
The model is 157003. The other code seems to read Year 6 (2006?), Day 213, Product C1, SN 072 (for the day)
Pretty sure it was used in Simplicity lawn tractor units with 16-18 hp.
Can you send me a picture of the complete unit?
Edited by Handy Don
Handy Don
The Eaton pump/motors are a simple bolt-on to the transaxle. Not sure about the the output shaft specs but on the WHs its a simple gear that meshes with a big gear in the transaxle. 1100's Output RPM is 0-1750 with torque 360 ft. lbs. continuous (540 intermittent) vs. 217 on the tuff-turf. The higher RPM at the motor output really helps with the torque.
It'd be helpful to know the final drive ratio on the buggy's proposed rear end and the diameter of the tires you'd likely use so we can figure what range of RPM we need going into it.
Edited by Handy Don
Oldskool
Not a good pic but how bout this?
Oldskool
If memory serves me correctly the rear ratio is 3.73:1
The tires are 27in tall.
cafoose
How do I know what gear ratio my rear axle is?
Count the number of teeth on the pinion gear and count the number of teeth on the ring gear. Divide the ring gear teeth number by the number of teeth on the pinion. The result is your gear ratio.
Handy Don
This perspective isn't much help in matching to illustrations but having an external filter and the extra hoses seems to indicate it had a separate charge pump and, possibly, had external hydraulics. This may be one of the larger units, some of which even had differential locks.
Probably this thing is embedded in something so good pics will be hard to come by, eh? :)
Handy Don
20+ mph x (hidden math including rear end ratio and other stuff like pi) = 930 RPM input to the rear end
Edited by Handy Don
Oldskool
@Handy Don that rear is in a large Craftsman. It does have 5 lug hubs though. It would be hard getting better pics at the moment.  I was told it could be tapped into for remote hydraulics
Oldskool
Luckily it still has the tag on the housing but I'm about 200miles from it at the moment
  • Sad 1
Handy Don
It may be possible to get the transaxle data via the Sears site if you can get the tractor's model number. The largest Sears tractors were quite strong machines.
I found this one on eBay which looks pretty close...
Handy Don
Boy are you lucky. Via the eBay listing I found some threads on another forum and there found links to the Tech and Service manuals (assuming this is what you have). This is listed as an "HD" (heavy duty) transaxle.
Definitely has option for external hydraulics (1.5 gpm @ 500 psi) -- not as strong as the Eaton 1100 but still handy--with an open center control and 500psi pressure relief.
Oldskool
Thanks for the research @Handy Don . As you can tell I'm trying to use mostly what I have on hand. Non of it really seems to be the best for this application. If it wasn't for the fact of trying to build it with an automatic style clutch/transmission for the wife I would just go with the original thoughts of using the Saginaw 3 speed trans I have.
ebinmaine
Time for some clutch lessons Mike?
Nothing ever going to be easier to learn on as an off-road rig except maybe a heavy diesel truck.
Oldskool
I'm thinking you maybe correct.
There is one plus to the whole thing. The engine is governed so she can't over rev it or damage anything by running WOT in a low gear.
ebinmaine
Are you going to have the capability of a set throttle position?
As you are well aware when you are driving a heavy diesel truck or a tractor you don't even touch the accelerator at all. Just slowly let out the clutch pedal..... And off you went.....
Handy Don
My sense of the Hydro-Gear is that it is borderline strong enough to do what you'd planned but that model had several different pump/motor builds with a range of torques and some are definitely underpowered. If you can find any other model numbers on it, we can be more certain.
Oldskool
Probably just a standard foot throttle.
Ya if shifting was that easy for her.
She doesn't even like shifting the Honda 4 wheeler. That's an auto clutch manual shift 5speed type trans.
Oldskool
Without tearing into the tractor I couldnt see any other numbers on it. Its really hard to get a good look at it.
  • Sad 1
Oldskool
Well enough idle time on this project.
I think it's time to blow the dust off things and get cracking.
I still haven't nailed down what I'm going to use for an engine or transmission.
What I have on hand for engines are several vert. shaft engines several hp ratings.
A OHV 16hp Kohler. Horizontal shaft
Transmissions: Saginaw 3 speed.
A 1930s Pontiac standard.
A Wheel Horse standard hi/lo.
  • Similar Content
    • c100rider
      By c100rider
      Hello fellas. I bought this 211-3 tractor. I have no clue how this mower deck comes off. I need to fix some areas on the deck, as well as replace a clutch cable. I can't seem to find pictures of a complete deck for this model as it should be. Need help.
    • Oldskool
      By Oldskool
      Let's see your view from your workplace "window". I know some are driving truck,or tractor, work in shops/offices or outdoors. What is it that surrounds you during your work day?
    • Oldskool
      By Oldskool
      Can anyone ID this?
    • Oldskool
      By Oldskool
      I started a thread a little while back "Something from Nothing". It has been upgraded to this thread because now I'm building something from something lol. I started with a new frame and strengthened the transaxle mount a bit.
    • Oldskool
      By Oldskool
      I've wanted to do this type of project for a while now. So here we go. The name was given by @wallfish. It will be called "The Yeti".  It will be painted and badged in a military theme. The front axle is in progress now.
