Oldskool
Custom golf cart
ebinmaine
  On 9/30/2022 at 12:36 AM, wallfish said:
It's a cool idea and not 100% sure it's exactly what he's getting at.
I get the impression HE'S not 100% sure what he's getting at!
:hide:
  • Haha 1
Pullstart
I’ve wanted o do something similar for a LONG time!  Off road buggy style.  FWD transaxle turned sideways and used as a transfer case.  It would add a lot of gear reduction…
Edited by Pullstart
wallfish
Like lock the pinions to power front and rear axles?
Pullstart
yep.  Or leave ‘em open to make an “all wheel drive” modeled transfer case.
wallfish
  On 9/30/2022 at 12:58 AM, Pullstart said:
Or leave ‘em open
I'd lock'm for off road. If a front tire slips it won't be sending power to the rears. Correct?
Pullstart
kind of,  you’d need both fronts slipping to loose all power.
wallfish
I was picturing a diff used in the front and rear axles too
Pullstart
Yes.  I can’t imagine a situation where the entire front diff has no grip, or the entire rear.  So, the center power transmitter could potentially be “open” and not locked.  It would be easiest on the entire drivetrain if it were open in the center.
wallfish
This is what I was imagining. Say the whole thing is driven into deep slippery mud. Guessing about the possibility of only one tire getting power because of the diff slip.
Locking the transfer diff would put power to both front and rear but if it's open it has the potential to power only 1 tire.
Hope Oldskool doesn't mind us going off road on his thread
Oldskool
@wallfish you nailed it in your interpretation of my rambling
Oldskool
Somewhere I have seen a Wheel Horse with an 8speed turned 90degree as a transfer case to run 2 Jeep axles.
  • Heart 1
Pullstart
Yeah @wallfish I could see that.  I think through all the power transmission, that is easier said than done.  BUT there’s only one way to find out!
Oldskool
Not at all. Go for it guys.
Handy Don
  On 9/29/2022 at 9:39 PM, Oldskool said:
Tuff Torq K61-A hydro transmission
Just looked the specs on this here.
Specifications:
Transaxle Torque output .......................217 Ft. lbs.
Maximum Input Speed .......................... 3000 RPM
Reduction Ratio ................... 26.97:1
So at 3000 RPM input, the output speed is 3000 ÷ 26.97 = 111.23 rpm
I used this calculator to get the maximum output horsepower as 4.6 (regardless of input horsepower).
This means that this transmission can maximally apply 4.6 horsepower for motion, assuming no losses in the rest of the drive train.
I'd say this is borderline for driving a 1,000 lb vehicle at 20+ mph, depending a lot on the terrain and the surface being driven over.
cafoose
What about this idea :scared-eek:
  • Excellent 3
Oldskool
Thanks Don for the calculations. Plus I guess there is the gear ratio of the sprockets along with the rear diff ratio turning  the 25to27in tires.
Handy Don
In the end, with the engine at 3000, you get 4.6 hp to work with. It is helpful that with a hydro, you can always have the full input revs available but the starting torque coming out will be lower at starting speed. It's a compromise between being able to start from a stop and reaching max speed since available torque is related to the hydro's output rotation speed (i.e. you don't get full torque at low output speeds).
Gearing to get up to 6-10 mph (i.e. chain sprockets to the drive shaft, the rear end differential, plus tire circumference) would probably work pretty well unless it's really muddy or hilly.
Gearing to get to 20 means maybe having not enough "ooomph" at low, starting off speeds.
A heavier hydro might be the ticket or, failing that, I'd give some thought to a torque converter a la snowmobiles or go-karts run through a geared transmission. You get no-clutch operation, speed ranges, and reverse. Heck, the front end from a compact, stick shift, front-wheel drive car (Ford Fiesta?) would even get you steering!
Edited by Handy Don
wallfish
Woo Hoo Does this mean there's a new project coming soon?
I'm a little surprised those transmissions are that low of an output. 217 ft pounds I was thinking hydraulic stuff would have a little more torque
Did you do that cafoose? That kinda stuff is right up my alley
19richie66
I have seen a transmission turned sideways and used to drive a transmission by chain off the brake shaft.
  • Excellent 4
Oldskool
@19richie66 that's a cool video. Interesting use of a WH trans
Pullstart
 @19richie66 what a cool machine!  I just binge watched most of his videos about it!
19richie66
It’s very impressive. It gave me a similar idea but with a hydro and a three speed powerking transmission. If the measurements work out. 👍
Edited by 19richie66
wallfish
Don't let @Handy Don ruin the inspiration with all of that fancy math and calculators he uses! :ychain:
  • Haha 1
cafoose
No, it came up on my Facebook feed
19richie66
I have most of the parts…… just waiting to aquire the transplant subject. :handgestures-thumbupright:
  • Similar Content
    • Oldskool
      By Oldskool
      Hey guys I have been given a box of these flap wheels.
      5.25" x 1.5" with a 1" arbor hole.
      I instantly thought great I can put one on my bench grinder.
      Nope!    Not that simple.
      The arbor size is different, and it's to wide to fit inside the the guard.
      I thought of removing the guard but would like to have it there.
      I guess I could make an arbor adapter and a spacer for the guard,and a new tool rest,etc. More time involved then first thought.
      Does anyone use these, and if so what do you have it on?
    • c100rider
      By c100rider
      Hello fellas. I bought this 211-3 tractor. I have no clue how this mower deck comes off. I need to fix some areas on the deck, as well as replace a clutch cable. I can't seem to find pictures of a complete deck for this model as it should be. Need help.
    • Oldskool
      By Oldskool
      Let's see your view from your workplace "window". I know some are driving truck,or tractor, work in shops/offices or outdoors. What is it that surrounds you during your work day?
    • Oldskool
      By Oldskool
      Can anyone ID this?
    • Oldskool
      By Oldskool
      I started a thread a little while back "Something from Nothing". It has been upgraded to this thread because now I'm building something from something lol. I started with a new frame and strengthened the transaxle mount a bit.
