Oldskool
Custom golf cart
Oldskool
8 minutes ago, Handy Don said:
Are you thinking about "reactivating" the rear drum brakes?
Yes I am. I'm also thinking of reactivating the parking brake as well.
Oldskool
@slim67 I just snagged a freebie Yamaha cart today.
It's electric though.
Do you know the range of one of these on a full charge?
ebinmaine
Usually until just about the time that the battery is dead...
:hide:
  • Haha 6
slim67
Good one Eric. I think they are supposed to last the equivalent of a couple rounds of golf but I only messed with gas. Performance wise ,you can do quite a bit with an electric. Be prepared to spend some money on batteries. That’s probably why it’s free but a gas conversion would be right up your alley. I don’t mind diagnosing electrical problems but some of the threads I read on the GC forums were nightmarish. Yamah makes the best golf cart IMO.
Snoopy11
I have an electric one as well, with 6 batteries. These things will outlast you.
I have worked all day, driving back into the woods, back and forth for 10+ hours... it still has juice.
Don
Snoopy11
I should add... it also depends on how hard you are working the motor, what speed you are running, etc...
I think... if you are running full speed for 3 hours, it would drain the batteries...
Don
Snoopy11
OH... and also depends on the amp/hours of the batteries... (they have ALL kinds...)
Don
slim67
Don
Trojans seem to be the brand of choice for a lot of the electric GC guys. I’ve seen some nicely done clone conversions on electric carts so I’d probably lean that way. Especially with all the clone performance stuff out there.
Snoopy11
Trojan and Dakota, main groups...
There are some other performance ones out there though!
Don
Oldskool
Don
10hrs is quite a while. The travel time I'm thinking would be 45min then stop a bit then 45min back. Quite possibly a 10min ride here and there in-between
Snoopy11
I 'tink you will be pretty happy with an E-cart in that case.
Just keep in mind... these things take a while to charge... and need to be charged in a well-ventilated area. :thumbs:
Don
Oldskool
Don
Is there any reason I couldn't swap the 6-6volt batteries for 3-12volt batteries?
I assume it may effect run time?
The thing is I picked it up with the thought of flipping it.
WELLLLLL the wife claimed it.
We all know what's happens when THAT happens. lol
  • Haha 2
Snoopy11
I... would not go that route if runtime is your concern. Your run time will indeed be effected. I realize that it would cut down on cost immensely... but if you compare the amp-hours of the 6-6 batteries to 3-12 volt deep cycle batteries, the 6-6 batteries will have QUITE a bit more amp-hours when added up together.
Good question though.... something to consider.
Don
Oldskool
I actually was lucky enought to get the charger with it
  • Excellent 3
Snoopy11
If you aren't aware, when you charge these batteries, you will have a very VERY strong smell of rotten eggs. This is normal. It is gas, so thus why it needs to be in a ventilated area. If you have gas detectors in the vicinity, they will go off.
The gas is a little flammable, and can cause breathing problems if you are enclosed with the gas. Just an important note. :thumbs:
Don
Snoopy11
Yep, that looks almost identical to the one I have. It has an internal fuse... so if that ever blows... it has to be opened up by professionals.
Not the cheapest thing ever... :rolleyes:
Don
Oldskool
Don
I know this is a stretch and I know nothing of what I'm asking but here it goes.
If 12v deep cycle batteries were available could 6 be used? 3 sets of 2 in tandem then the 3 sets wired in series?
Or is that a hydrogen bomb waiting to happen???
SylvanLakeWH
Yes you can. 36 v is 36 v whether 6x6 or 3x12…
Yes it could effect run time… Amp hours are the key…
No expert, but I think You would wire 3 in series, another 3 in series, then those two banks in parallel. That keeps it 36 volts. That is how my E 141 was originally wired. I bought it and continue to run it with three 12 v batteries in series (instead of 6) for cost reasons…
A lot of excellent tutorials online… I would check them out before I changed up anything…
Edited by SylvanLakeWH
Snoopy11
The good thing about me is... I also have solar power experience, so my understanding of batteries is pretty good.
Your charger will cook automotive or marine deep cycle batteries if used in 2-3 parallel paring sets.
If you wired 6-12 volt batteries positive to negative, you would have 72 volts. No, it wouldn't be a hydrogen bomb... yes it would blow your electronics and motor.
Using 6 volt batteries accomplishes the goal of getting 36 volts, and also achieving a amp-hour relationship that you will never achieve with parallel paring 12 volt.
Don
Snoopy11
You are correct. I do think the amp-hour relationships for the 12 v batteries would still be less than 6-6 volt batteries in parallel.
Don
Oldskool
I'm thinking when the wife sees the cost of 6 good 6volt batteries she is going to relinquish ownership and opt to flip it.
  • Haha 3
Snoopy11
My 6 volt batteries are 225 ah each... I have a couple GIANT deep cycle 12 volt marine deep cycle batteries that are around the same ah, but they literally eclipse the 6 volt batteries.
I have Trojan Motive brand.
Don
Edited by Snoopy11
Snoopy11
$1,200-$1,700....
Like I said, you could do the 3-12 volt battery idea... but runtime is going to be very limited... and your charger will fry them...
Don
Oldskool
5 minutes ago, Snoopy11 said:
$1,200-$1,700....
Don
If she could get four 1hr trips out of the 12v batteries before charging then it may be worth it. Then I guess I would have to unhook the batteries to charge them properly.
  • Similar Content
    • c100rider
      By c100rider
      Hello fellas. I bought this 211-3 tractor. I have no clue how this mower deck comes off. I need to fix some areas on the deck, as well as replace a clutch cable. I can't seem to find pictures of a complete deck for this model as it should be. Need help.
    • Oldskool
      By Oldskool
      Let's see your view from your workplace "window". I know some are driving truck,or tractor, work in shops/offices or outdoors. What is it that surrounds you during your work day?
    • Oldskool
      By Oldskool
      Can anyone ID this?
    • Oldskool
      By Oldskool
      I started a thread a little while back "Something from Nothing". It has been upgraded to this thread because now I'm building something from something lol. I started with a new frame and strengthened the transaxle mount a bit.
    • Oldskool
      By Oldskool
      I've wanted to do this type of project for a while now. So here we go. The name was given by @wallfish. It will be called "The Yeti".  It will be painted and badged in a military theme. The front axle is in progress now.
