Oldskool
Custom golf cart
SylvanLakeWH
Or Michigan’s own dialect:
say ya to da UP eh? Go Get somna dem meat pahs eh…?
:handgestures-thumbupright:
  • Thanks 2
Oldskool
Had an afternoon for a parts procurement trip to a friend's junkyard.
This odd lil fella was just sitting there.
A 4way of sorts I presume .
ebinmaine
8 minutes ago, Oldskool said:
odd
Ain't it though.
Oldskool
Today's picked  part.
It's looking like 10" needs to be removed from each side to make it the correct usable width.
Oldskool
Getting ready to narrow things down a bit.
Revised measurements say the pinion is off center so recalculated is in order.
Also an unforeseen obstacle of there being a double step up/down in the axle tube.
Oldskool
The rear axle narrowing is going somewhat according to plan.
It won't be long and I'll have a rolling chassis.
7-1/2" removed from this side.
Oldskool
Halfway there.
I put the shaft in the lathe to spin test.
It spun out nicely.
Maybe the other half later today.
  • Like 4
8ntruck
Interesting process.  I have the rear axle out of a Monza Spider that is slated to go into a MGB with an Olds 215.  It will need to get narrowed.  Nice to see the process you are using.
How are you keeping all of the bearing centers in line?
How are you going to shorten the axles?
Oldskool
Sounds like a cool little project you have going.
As far as keeping the bearing centers in line welllllll.......
With this being a fairly modern housing I'm hoping the factory tolerances were close enough that the axle tubes were round,squared, and centered.
Because all I did was make sure what I did was squared and centered.
I did tack weld the axle end on then tacked my axle shaft together. Then I fit it back into the housing to make sure it slid together.
Lastly, clamped everything in place and alternated my welds.
You can see in the 3rd picture back that I overlapped the axle shaft halves the beveled all my edges. Again clamped in place and alternated my welds. Not letting it get to hot in the process.
For the amount of torque and horse power I will have it should be adequate.
I hope.
Oldskool
The other half is done.
It's resting in its forever home now.
Maybe some mounts later today along with some shock relocation brackets.
  • Like 4
  • Excellent 3
ebinmaine
Excellent work sir
slim67
You should do the same thing with a driven steer axle and make it 4 wd. It looks like you certainly have the skills.
  • Excellent 2
Oldskool
Thanks.
That's not a bad idea. I could always use a WH transaxle for the transmission/transfer case.
Maybe on an upgrade.
Oldskool
Time to start getting the rear tires ready.
 26x12x12 tires going on.
  • Excellent 2
slim67
I used to build golf carts and frequent a couple of the golf cart forums. Theres money to be made in buying and reselling them.
Oldskool
There is a local guy that buys and sell quite a few of them.
I have a buddy that just picked up 2 Harley Davidson trike carts.
slim67
They are a lot of fun to work on and modify but I can't justify having one anymore. I actually used mine to go off roading with. They were fun but had potential much more suited to dunes. If I ever did build another cart, it would be for Silver lake sand dunes and nothing else. Richie on here built one with a motorcycle engine awhile back.
Edited by slim67
Oldskool
They are quite a simple design which does make them easy to work on.
Unfortunately we don't have dunes around here. Wish we did.
19richie66
I tried 😂 it got kinda complicated with the engine/transmission setup I was using. Would have probably killed me if I ever got it together. 30 forward speeds, 6 reverse :laughing-rolling:  I’ll stick with tractors at this point.
  • Haha 1
slim67
I remember, you were off to a good start. I wish I could find the video of the EZGO that had a GXSR motor in it.
Maxwell-8
Great size: DSC_0699.JPG.aa86d0fcf8127617f8981c85a091bd4c.JPG
That rear axle will be more then strong enough! Great work!
Oldskool
Oh ya I won't have to worry about breaking anything on the rear. I hope.
Those must be new sneakers for a tractor?
Maxwell-8
My C141D, atv tires are softer then a AG, and are made to fit on 7" wide rims, even 12" wide.
Oldskool
I had just enough time after work to get them mounted.
I even have enough room to run duals if desired.
  • Excellent 3
Handy Don
Are you thinking about "reactivating" the rear drum brakes?
  • Similar Content
    • Oldskool
      By Oldskool
      Hey guys I have been given a box of these flap wheels.
      5.25" x 1.5" with a 1" arbor hole.
      I instantly thought great I can put one on my bench grinder.
      Nope!    Not that simple.
      The arbor size is different, and it's to wide to fit inside the the guard.
      I thought of removing the guard but would like to have it there.
      I guess I could make an arbor adapter and a spacer for the guard,and a new tool rest,etc. More time involved then first thought.
      Does anyone use these, and if so what do you have it on?
    • c100rider
      By c100rider
      Hello fellas. I bought this 211-3 tractor. I have no clue how this mower deck comes off. I need to fix some areas on the deck, as well as replace a clutch cable. I can't seem to find pictures of a complete deck for this model as it should be. Need help.
    • Oldskool
      By Oldskool
      Let's see your view from your workplace "window". I know some are driving truck,or tractor, work in shops/offices or outdoors. What is it that surrounds you during your work day?
    • Oldskool
      By Oldskool
      Can anyone ID this?
    • Oldskool
      By Oldskool
      I started a thread a little while back "Something from Nothing". It has been upgraded to this thread because now I'm building something from something lol. I started with a new frame and strengthened the transaxle mount a bit.
