Hot Wire 0 #1 Posted October 31, 2021 I bought a 1057 today.It doesn’t seem to have a clutch pedal.How do they disengage the belt to transmission?Am I missing parts or linkages? Share this post Link to post Share on other sites
Maxwell-8 4,290 #2 Posted October 31, 2021 @Hot Wire On your left should be a clutch pedal.. If it's gone, is the rod still there? Share this post Link to post Share on other sites
Gregor 4,847 #3 Posted October 31, 2021 to Clutch/brake pedal # 54 in diagram. Rod # 48 This manual may help. Share this post Link to post Share on other sites
Retired Wrencher 5,507 #4 Posted October 31, 2021 Hot wire Enjoy the site. Share this post Link to post Share on other sites
wallfish 17,079 #5 Posted October 31, 2021 Post some pics of your tractor from all sides for best internet diagnosis. If it is indeed a 1057 then it should have a clutch pedal. Maybe it's been modified? Maybe it's a different model with a 1057 belt guard? Such as a 1077 would have a hydro trans without a clutch pedal Share this post Link to post Share on other sites
Racinbob 11,207 #6 Posted October 31, 2021 The 1057 had only one pedal. Left side, combination clutch and brake. Later models went to clutch on the left, brake on the right. Share this post Link to post Share on other sites
953 nut 55,763 #7 Posted October 31, 2021 The belt guard must be in place for the clutch to work properly. When you push down on the clutch the bottom of the belt guard will catch the slack in the belt stopping it from moving. Share this post Link to post Share on other sites
