Horse_rebuilder
Transmission compatibility?
Horse_rebuilder
I saw a 416-8 and it looked to be an 87ish with the magnum engine it had a missing transmission however, I have an 87’ 310-8 with the magnum 10 and was wondering if I could use the transmission from the 310-8 for the 416-8?
TJ5208
Yes you can these tractors are interchangeable
stevasaurus
Yes you can...it should bolt right in.  There is a difference though...the 310-8 transmission has 1" axles with a 4 pinion differential...the 416-8 transmission has 1 1/8" axles with an 8 pinion differential.  :orcs-cheers:
  • Like 4
kpinnc
You would basically be creating a 316-8...
The 1 inch, 4 pinion transmission is the lighter duty of the two mentioned- but still tougher than anything sold new today. I've been using one for 20+ years as my worker tractor, and it's still a solid bulletproof machine!
