kpinnc 12,045 #1 Posted October 21, 2021 (edited) 101845 Ball safety switch Later 105877 replaced by 38-0430 I see them online, just wondering if someone had a trusted source? Prices vary, but $40 seems steep. Edited October 21, 2021 by kpinnc 1 Share this post Link to post Share on other sites
ebinmaine 67,497 #2 Posted October 21, 2021 My tractors don't have any so I'm half guessing... You might get good used ones from Lincoln at A to Z Tractor in PA. @953 nut @Achto You fellas have a good source? Share this post Link to post Share on other sites
peter lena 8,627 #4 Posted October 21, 2021 @kpinnc looks like a good source on this page , with that antique stop switch , when ever i need to track something , find it pretty easy to just google search , or your favorite search spot, that also shows' related items that help out , pete 1 Share this post Link to post Share on other sites
Handy Don 12,227 #5 Posted October 21, 2021 9 hours ago, kpinnc said: 101845 Ball safety switch Later 105877 replaced by 38-0430 I see them online, just wondering if someone had a trusted source? Prices vary, but $40 seems steep. Ok, I'll bite.... How does this switch work, please? 1 Share this post Link to post Share on other sites
pfrederi 17,739 #6 Posted October 21, 2021 Ball on the tip of the bottom is spring loaded. 2 Share this post Link to post Share on other sites
kpinnc 12,045 #7 Posted October 21, 2021 Goes by the centering/ brake pedal on early 70s hydros. Early starter interlock. 2 Share this post Link to post Share on other sites
ebinmaine 67,497 #8 Posted October 21, 2021 25 minutes ago, Handy Don said: Ok, I'll bite.... How does this switch work, please? This is used as the clutch safety switch among other things. Sliding the clutch arm against the ball pushes the ball in and creates contact. There are also other versions that do the reverse of that. 5 1 Share this post Link to post Share on other sites
BOB ELLISON 2,981 #9 Posted October 21, 2021 I just got 2 from rockauto for $15.00 each Sorry there out of stock for the cheaper ones but the others are $20.79 Just Google any of these numbers below. Backup switch for a 1976 jeep cj5 Interlock Ball Switch Replaces Original (OE) Part #:105877, DR429 5350061, J5350061, J0947917, J5353441, J0948345, 88923255 1 2 1 Share this post Link to post Share on other sites
edgro 677 #10 Posted October 21, 2021 (edited) Very similar to a backup light switch for a fuller transmission. If you google that you will find ball switch with various types of electrical connections. The one with 2 small screws may be useful Edited October 21, 2021 by edgro Spelling 1 Share this post Link to post Share on other sites
peter lena 8,627 #11 Posted October 21, 2021 @kpinnc opportunity while in the wiring / relay trouble zone , look over related wiring for chafing or corrosive areas , usually find anything else related to a problem , with a detail search , pete 1 Share this post Link to post Share on other sites
Pullstart 62,877 #12 Posted October 21, 2021 Rylee’s “Screamin’ Jimmy” the Commando 800 has one of these on the clutch pedal. It is a perfect interlock to make sure all her safety requirements are in place (butt in seat) before starting. 2 Share this post Link to post Share on other sites
kpinnc 12,045 #13 Posted October 21, 2021 4 hours ago, BOB ELLISON said: I just got 2 from rockauto for $15.00 each Sorry there out of stock for the cheaper ones but the others are $20.79 Just Google any of these numbers below. Backup switch for a 1976 jeep cj5 Interlock Ball Switch Replaces Original (OE) Part #:105877, DR429 5350061, J5350061, J0947917, J5353441, J0948345, 88923255 Thanks Bob! 2 Share this post Link to post Share on other sites
lynnmor 7,306 #14 Posted October 21, 2021 2 hours ago, Pullstart said: Rylee’s “Screamin’ Jimmy” the Commando 800 has one of these on the clutch pedal. It is a perfect interlock to make sure all her safety requirements are in place (butt in seat) before starting. After which she stands up on the seat. Share this post Link to post Share on other sites
Pullstart 62,877 #15 Posted October 22, 2021 3 hours ago, lynnmor said: After which she stands up on the seat. Different machine, but same kid Share this post Link to post Share on other sites
