UK321
C125 fuel/gas tank question
UK321
Good afternoon from the UK
I'm a long time (30 years) WH fan and currently have two a 10hp raider and a 12hp c125 which I'm trying to bring back to life.  Unfortunately the PO 'lost' the fuel tank (He'd fitted a Honda engine (spit)).
Does anyone know the part number and whether the same tank was used on any other WH?
Thanks for all and any help
Martin
Gregor
:text-welcomeconfetti: back to  :rs: We like lots of pics.
Part # 106234  I believe all C series tractors probably used the same tank. If I am wrong, someone please correct me.
You don't say the year of your tractor. The following is for 1984.
Edited by Gregor
UK321
Gregor,
Thank you so much.  Very helpful indeed.
gwest_ca
If you post the model numbers and serial numbers of both tractors there is a way to get to a list of where part numbers were used. At least a list of the illustrated parts lists a part is listed in. The only problem is many parts lists are shared by similar models of tractors so it takes some research. I don't think that happens often with fuel tanks.
Lee1977
I check the C-125, C-175, 312-8 and 414-8 all had the same no. gas tank 105234. The only one I know is different is the 520's  They have a fuel gauge sending unit in the right rear corner.
It could be plugged the a gasket and a home made metal plate.
Do you still have the metal tank supports bolted to the fender bracket?
Edited by Lee1977
Gregor
2 hours ago, Lee1977 said:
gas tank 105234.
1628321066_Screenshot2021-10-06at17-13-31Trans8spd11099619901inaxle4pinioniplpdf-Tractor1985312-821-12K801TIPLpdf.png.0854e898aed69156605ae97f32ff0d6d.png
Lee1977
Yes, hit the wrong key.  If it is a under seat gas tank most of them seem to be the same.
