help . i need with a hauler. made by Kimball J96
By
Timothye, in non tractor related discussion
Similar Content
By CasualObserver
@bmsgaffer Brandon's not getting much response in his Sure-Trac Trailer topic, so I thought I'd separate out the tie down system part of the discussion.... Since proabably at least 75% us have and use trailers pretty regularly, what are you using to tie down? I had a particular interest, as I'm like Brandon and have just gotten a new trailer and am looking at what sort of tie down system (if any) to add to it.
Just looking for some discussion points like:
Who's using E-track, an alternate system or just tie down to whatever you can? How do you like your system? Would you change it if you could? If using E-track, what do you do in regards to keeping debris out of the track, or is it even a problem?
Previously I've only used regular hook straps, left to right, diagonal and front to back. Just tried like hell to make sure the load made it from point A to point B, hooking straps into any solid tie down point I could find on the frame that wouldn't shift in travel.
By bmsgaffer
Finally broke down and bought a trailer. I've been renting those ugly green ones and well... they're green (and I'm tired of trying to make sure I get it unloaded and back on time).
I have been pretty impressed with Sure-Trac, as I remember @shallowwatersailor going through his process and then picking it. There are a few nit-picky things about them that I thought they should have done better, but all in all for the price I felt like I got a good deal. (Middle of the road price point)
Its a 6x10, all box frame rails, spring assisted fold-flat gate, LED lighting, set-back jack, 3500lb axle, ez grease hubs (WAY nice) etc., etc. (And it lives at my KY address so no registration required). And I got as spare tossed in for pennies.
Already took it on a trip up to the Portland Swap, and its hauled a hefty load of top soil! It tracks nicely when loaded but can be a bit "sprung" when running unloaded. Tosses me around a little bit on the rougher roads.
I need some more attachment points, what do you guys use? I was looking at putting in some e-track or is there a better option? I like having lots of options when tying a load down.
By CasualObserver
I don't think I've shared this as I've been pretty scarce on forums since it happened.... but I pulled the trigger on a new trailer.
I had the Wheel Horse two-place snowmobile trailer for several years, and while I loved it and had many fun conversations at shows while showing it off, I needed a better trailer to be able to haul to shows and for general use around the home. After long consideration regarding the need of a substantial trailer and the desire not to let this collectible un-restored metal trailer sit outside and degrade in another Minnesota winter I decided it was time. I'd have loved to be able to justify keeping both, but it wasn't a good fit for me.
I never officially advertised it for sale publicly, but had told a couple people I was considering letting it go. There was one collector whom I knew was legitimately interested in making an offer if I was ever ready to let it go. We agreed on a price and one of my prize pieces headed for a new home. If he ever decides to speak up on it, I'll leave that up to him, but know that it is in good hands and will be meticulously restored, I have no doubt.
This picture really highlights just how small even the two place snowmobile trailer is.
With that part of the deal done, I began seriously looking for it's replacement. I wasn't in a hurry as show season was over and I didn't have any immediate hauling needs. It was likely going to just sit in the driveway over winter anyway.
I had some bad experiences with a couple dealers along the way, but eventually landed with this 14 foot PJ Trailer built how I wanted. They had trailers in production, and I was able to get a change order done specifically I was able to get the bi-fold gate, removable stake pocket spare tire carrier and color I wanted. Sides are completely removable so if I need to run just the flat deck, I can. I like that because the trailer's stability isn't dependent on the sides keeping it from being wobbly like a lot of them you see. Pretty happy with this, it pulls nice and smooth. Looking forward to some nice trips to shows with it!
