HarleyFX
Charger 10 Transmission
HarleyFX
I had to replace an axle in a Charger 10 and now i have a gap of about 1/2" of the cases coming together.  I have had it apart many times and can't see what is holding them apart.   Any ideas and help would be greatly appreciated.  Thanks Randy
rmaynard
Did you remove anything other than the differential? If so it would seem to me that one of the shafts did not seat into the bearing.
pfrederi
There re 2 short aligning pins that can be tricky to get in there respective holes without snagging the gasket
More important did you put the differential in the correct direction.  long side of differential and nuts  go up into the wide section of the tranny housing.
  • Like 4
Maxwell-8
Made that mistake once, still would shut, put the tranny back under the horse, filled it up with fluid.  Then I went to bed, but I couldn't sleep! hahah
First thing in the morning was going trough the trouble to turn the diff around around. And good I did because it was slightly hitting.
Edited by Maxwell-8
stevasaurus
1st thing is you need the shallow side down.  It sounds like one of the shafts is not going into the bearing on the other side.  You need to just drink a beer or two and wiggle the case a little and get lucky.  Seriously!!  Actually, some pictures of what you have there might point out to us what is wrong...if something stands out.
  • Haha 1
  • Heart 1
HarleyFX
No I didn't even remove the differential from one half, I just replaced the bad axle,  I can line up all the shafts to theirs bearings but there is something still interfering.   Thanks
HarleyFX
Both the axles are the same size and the aligning pins still have an air gap between them.   Thanks
Maxwell-8
That is pretty hard to do. do you have a picture? just to be sure.
pfrederi
In a Charger 10 one axle is longer than the other they are not the same....
HarleyFX
I replaced the bad axle with the same size that was damaged.   In my parts manual for a Charger 10 there is one one part number for both axles Part #5961 and it calls for 2.    Both axles are the same.  The Charger 12 and Bronco 14 each had 2 different axles.
pfrederi
What year or model number Charger 10 do you have my 1969 1-7041 parts shows 2 different axles (#12 and #13) Maybe WH changed at some point??
