Moonshine*Connoisseur 435 #1 Posted October 4, 2021 Brake pedal not returning to disengage position. Pedal moves freely. Is there a spring inside the frame or internal to the transmission? Share this post Link to post Share on other sites
Retired Wrencher 5,467 #2 Posted October 4, 2021 There should be a large spring on the out side that hooks up to brake lever and transmission. 1 1 Share this post Link to post Share on other sites
953 nut 55,325 #3 Posted October 4, 2021 The 1277 is a hydro (automatic) transmission and has no brakes other than the transmission. On page 9, item 176 is called a brake return spring and in conjunction with cam plate 178 will return the transmission to neutral which functions as a brake to stop the tractor. 2 Share this post Link to post Share on other sites
squonk 41,162 #4 Posted October 4, 2021 Spring is inside the tunnel on the hydro linkage. It is probably broken and a bear to get to with out removing all the linkage. You can rig up an external return spring on the outside of the tractor. 2 1 Share this post Link to post Share on other sites
peter lena 8,639 #5 Posted October 4, 2021 @Moonshine*Connoisseur, when you replace that spring , lubricate all related movement points , pete 1 Share this post Link to post Share on other sites
Moonshine*Connoisseur 435 #6 Posted October 4, 2021 Thanks everyone, I will be digging into it here shortly today. Share this post Link to post Share on other sites
Moonshine*Connoisseur 435 #7 Posted October 5, 2021 I found the #6135 spring broken. Due to rust and years of use. Share this post Link to post Share on other sites
Moonshine*Connoisseur 435 #8 Posted October 5, 2021 I also need but dont see it in the breakdown diagrams....the PTO pressure pin I guess one could call it, it's the pin that goes in the center of the cone, has a slot in it for the control rod and the cotter pin locks it in. Newer style wont work as there is no slot in it. Share this post Link to post Share on other sites
peter lena 8,639 #9 Posted October 5, 2021 @Moonshine*Connoisseur do you have a hardware store near by ? in the small drawer pull out section , bring in your old broken pin and match it up , i also lubricate anything related that will have to move at some point , pete Share this post Link to post Share on other sites
peter lena 8,639 #10 Posted October 5, 2021 @Moonshine*Connoisseur does this help ? https://www.google.com/search?q=wheel+horse+pto+latch+pin&sxsrf=AOaemvJy7-aBp3e8q_ue6SpmweEjEVfh7A%3A1633435788694&source=hp&ei=jEBcYY-PJ5Dl5NoP75-XkAg&iflsig=ALs-wAMAAAAAYVxOnApo65XTvEw1YCS3oBf-ehPewkI7&ved=0ahUKEwiPhci_nrPzAhWQMlkFHe_PBYIQ4dUDCAk&uact=5&oq=wheel+horse+pto+latch+pin&gs_lcp=Cgdnd3Mtd2l6EAMyBQghEKABMgUIIRCgATIFCCEQoAE6BAgjECc6CwgAEIAEELEDEIMBOg4ILhCABBCxAxDHARCjAjoICAAQsQMQgwE6CAgAEIAEELEDOg4ILhCABBCxAxDHARDRAzoECAAQAzoFCAAQgAQ6BQguEIAEOgsILhCABBDHARDRAzoICC4QgAQQsQM6CAgAEIAEEMkDOgoIABCABBCxAxAKOgsILhCABBDHARCvAToHCAAQgAQQCjoGCAAQFhAeOggIIRAWEB0QHjoECAAQDToGCAAQDRAeOggIABANEAUQHjoICAAQCBANEB5QsxFYh1xgwmRoAHAAeACAAZUBiAHqEpIBBDE3LjiYAQCgAQE&sclient=gws-wiz , pete Share this post Link to post Share on other sites
Moonshine*Connoisseur 435 #11 Posted October 5, 2021 It is the pin that goes into the bearing on the pto cone. It is held in place by a snap ring. This is a part that wont be found at any hardware store, I can guarantee that. 1 Share this post Link to post Share on other sites
pfrederi 17,741 #12 Posted October 5, 2021 Try Tractor supply for pins like this 1 Share this post Link to post Share on other sites
Moonshine*Connoisseur 435 #13 Posted October 5, 2021 That's not even close to what I'm describing sorry. Share this post Link to post Share on other sites
pfrederi 17,741 #14 Posted October 5, 2021 Or is you r PTO like this 2 Share this post Link to post Share on other sites
jtrosp1980 89 #15 Posted October 5, 2021 I run mine in a hinge pin Share this post Link to post Share on other sites
Moonshine*Connoisseur 435 #16 Posted October 5, 2021 1 Share this post Link to post Share on other sites
Moonshine*Connoisseur 435 #17 Posted October 5, 2021 I need this piece that has the slot in it. 1 Share this post Link to post Share on other sites
squonk 41,162 #18 Posted October 5, 2021 Try A-Z Tractor. https://a-ztractor.com/ 2 1 Share this post Link to post Share on other sites
rjg854 11,387 #19 Posted October 6, 2021 You'll get a faster response giving him a call 1-717-821-2642 3 1 Share this post Link to post Share on other sites
Moonshine*Connoisseur 435 #20 Posted October 6, 2021 I have one coming, thank you to everyone ! These fun projects I get myself into. This 1277 is a junkyard save. It made it into the yard, a phone call was made and I came to the rescue. 2 1 Share this post Link to post Share on other sites
kpinnc 12,111 #21 Posted October 6, 2021 6 hours ago, Moonshine*Connoisseur said: I have one coming, thank you to everyone ! These fun projects I get myself into. This 1277 is a junkyard save. It made it into the yard, a phone call was made and I came to the rescue. Nice save! I hope when you finish up getting it going, it runs another 40 years! 1 1 Share this post Link to post Share on other sites
