Lee1977 7,456 #851 Posted February 14, 2022 The way to go is electric pump I have pump connected to the R lug on the switch of my 520 it had nothing connected to it. The ground wire from the pump is connected to a toggle switch on the dash the other side is connected to ground. My 20 Onan floods real easy and I never knew if it was getting gas or if it was flooded, electric pump made it easy to start. The starting procedure is. turn on the switch let the pump hit 3 or 4 times turn to start come up with the choke and right back down and it's running. 1 Share this post Link to post Share on other sites
Horse Newbie 7,398 #852 Posted February 14, 2022 5 hours ago, SylvanLakeWH said: couple pumps and fires right up… Do you think a primer bulb would cause harm to a diagram in the pump ?… I was planning on maybe 2-3 squeezes at the most to prime . Share this post Link to post Share on other sites
Horse Newbie 7,398 #853 Posted February 14, 2022 5 hours ago, Jeff-C175 said: In fact, I believe that they have TWO. One at the inlet of the bulb, one at the outlet. Cut one of yours apart and let me know…🤣 1 Share this post Link to post Share on other sites
Horse Newbie 7,398 #854 Posted February 14, 2022 4 hours ago, kpinnc said: No sir. One or the other was my point. Point “now” taken…😂 1 Share this post Link to post Share on other sites
SylvanLakeWH 29,813 #855 Posted February 14, 2022 6 minutes ago, Horse Newbie said: Do you think a primer bulb would cause harm to a diagram in the pump ?… I was planning on maybe 2-3 squeezes at the most to prime . Been using it for several years now. No issues. Usually takes couple pumps and it’s charged… 1 1 Share this post Link to post Share on other sites
Horse Newbie 7,398 #856 Posted February 14, 2022 1 hour ago, Lee1977 said: I have pump connected to the R lug on the switch of my 520 it had nothing connected to it. The ground wire from the pump is connected to a toggle switch on the dash the other side is connected to ground. Could you not have just run the ground wire to ground ?… I would not want to drill a hole in my dash… wouldn’t the “R” position on the switch power the pump ? Share this post Link to post Share on other sites
Jeff-C175 7,207 #857 Posted February 14, 2022 (edited) 15 minutes ago, Horse Newbie said: maybe 2-3 squeezes You can actually feel when to stop. The bulb gets a bit stiffer when the float comes up and closes the needle valve. 13 minutes ago, Horse Newbie said: Cut one of yours apart and let me know…🤣 Well... I know yer jokin', but if you think about it, how else could it work? Check valve at inlet and outlet... when you squeeze bulb, inlet check closes and outlet is open. When you let go of bulb, outlet closes and inlet opens. Pretty much the same way yer heart works. Also, it's the same way the mechanical fuel pumps work. Just replace the bulb with the diaphragm. They also have two check valves in them... which makes me wonder why one would need another check valve? How is fuel draining back? Edited February 14, 2022 by Jeff-C175 Share this post Link to post Share on other sites
kpinnc 16,183 #858 Posted February 14, 2022 8 minutes ago, Horse Newbie said: Point “now” taken…😂 I didn't mean it like that... 1 Share this post Link to post Share on other sites
Horse Newbie 7,398 #859 Posted February 15, 2022 (edited) 2 hours ago, Jeff-C175 said: You can actually feel when to stop. The bulb gets a bit stiffer when the float comes up and closes the needle valve. 👍 2 hours ago, Jeff-C175 said: Also, it's the same way the mechanical fuel pumps work. Just replace the bulb with the diaphragm. They also have two check valves in them... which makes me wonder why one would need another check valve? How is fuel draining back? That make sense to me… and also I’ve heard talk on here about fuel running down the pulse line into the crankcase… but for that to happen wouldn’t the diaphram in the pulse pump have to be bad ? Edited February 15, 2022 by Horse Newbie Share this post Link to post Share on other sites
Horse Newbie 7,398 #860 Posted February 15, 2022 (edited) 2 hours ago, kpinnc said: didn't mean it like that I know… we’re cool. 😎 Edit: You were clarifying… and I was saying “ primer bulb, and check valve both ?” because at the time of the posts, Jeff-C175 had not informed me that he was pretty sure that the primer bulbs had built-in check valves. Edited February 15, 2022 by Horse Newbie Share this post Link to post Share on other sites
Jeff-C175 7,207 #861 Posted February 15, 2022 6 minutes ago, Horse Newbie said: wouldn’t the diaphram in the mechanical pump have to be bad Not sure about the vacuum operated pumps, but on the straight mechanical pumps, yes, a bad diaphragm can dump fuel into the crankcase. 1 Share this post Link to post Share on other sites
Lee1977 7,456 #862 Posted February 15, 2022 1 hour ago, Horse Newbie said: Could you not have just run the ground wire to ground ?… I would not want to drill a hole in my dash… wouldn’t the “R” position on the switch power the pump ? Yes. I can turn the pump off and run the carb dry. I don't have a Wheel Horse still like it came from the factory all mine have been modified. 1 2 Share this post Link to post Share on other sites
Lee1977 7,456 #863 Posted February 15, 2022 3 minutes ago, Jeff-C175 said: Not sure about the vacuum operated pumps, but on the straight mechanical pumps, yes, a bad diaphragm can dump fuel into the crankcase. A vacuum pump is just as bad about dumping fuel in to the crank case. 3 Share this post Link to post Share on other sites
Horse Newbie 7,398 #864 Posted February 15, 2022 (edited) 30 minutes ago, Lee1977 said: Yes. I can turn the pump off and run the carb dry. I don't have a Wheel Horse still like it came from the factory all mine have been modified. Yep… I see the point now in the toggle switch… to be able to run the carb dry. Did not pick up on that angle… 26 minutes ago, Lee1977 said: A vacuum pump is just as bad about dumping fuel in to the crank case. My bad… I should have said pulse pump instead of mechanical. But anyways I see what you say… a bad diaphragm in a pulse or mechanical pump would allow fuel to flow into crankcase… A lot of times I use the wrong terms, but usually you all can figure out what us newbies mean.😂 Thanks , @Lee1977 Edited February 15, 2022 by Horse Newbie 1 Share this post Link to post Share on other sites
Jeff-C175 7,207 #865 Posted February 15, 2022 17 minutes ago, Horse Newbie said: should have said pulse pump Knew what you meant when you said "pulse line" though, but I'm not sure that's the route the gasoline would take to get to the crankcase. If the pulse line filled with gasoline, wouldn't the pump stop pumping and engine shut down? 1 Share this post Link to post Share on other sites
Horse Newbie 7,398 #866 Posted February 15, 2022 5 minutes ago, Jeff-C175 said: If the pulse line filled with gasoline, wouldn't the pump stop pumping and engine shut down? Maybe, I guess… never had a pulse pump fail to where gas flows down the pulse line. But I sorta think if the engine was running, maybe until the failure gets worse, the pulse line pumping would not allow the gas to go “down” the pulse line… when the failure( hole in diaphragm) becomes too large, the pump would quit pumping and the engine quit. Or am I looking at things wrong ? 1 Share this post Link to post Share on other sites
Jeff-C175 7,207 #867 Posted February 15, 2022 1 minute ago, Horse Newbie said: Or am I looking at things wrong ? Dunno! It's been a very long time since I've looked at a pulse pump and why I'm conjecturing. Maybe Lee can explain better? 1 Share this post Link to post Share on other sites
Horse Newbie 7,398 #868 Posted February 15, 2022 Just now, Jeff-C175 said: conjecturing Define please… that’s a $2.00 word… 2 Share this post Link to post Share on other sites
Horse Newbie 7,398 #869 Posted February 15, 2022 You laugh… I am seriously gonna have to go to Websters… Share this post Link to post Share on other sites
Jeff-C175 7,207 #870 Posted February 15, 2022 2 minutes ago, Horse Newbie said: Define please… that’s a $2.00 word… Ask Mrs Google, I hear she's cheap and easy! 1 Share this post Link to post Share on other sites
Jeff-C175 7,207 #871 Posted February 15, 2022 1 minute ago, Horse Newbie said: You laugh… I am seriously gonna have to go to Websters… Quote form an opinion or supposition about (something) on the basis of incomplete information 1 Share this post Link to post Share on other sites
Horse Newbie 7,398 #872 Posted February 18, 2022 (edited) I got a package today from @wheelhorseman / Wheel Horse Parts and More… the rock shaft kit, spindle/ axle ends top dust covers, and throttle lever handle for the 1984 Work Horse GT-1600… Gonna be some progress on the Work Horse this weekend ! Edited February 18, 2022 by Horse Newbie 2 2 Share this post Link to post Share on other sites
Horse Newbie 7,398 #873 Posted February 18, 2022 (edited) Can someone give me a tip on putting the throttle handle on the throttle lever ? If I push it on, will it “snap” into place ? The reason I ask is because I had to cut the old one off. Edited February 18, 2022 by Horse Newbie Share this post Link to post Share on other sites
Horse Newbie 7,398 #874 Posted February 18, 2022 I am looking for opinions… would you paint the rock shaft Rustoleum Satin Black like the frame, transmission, etc, on the Work Horse, or would you leave it that beautiful WH red ? Share this post Link to post Share on other sites
SylvanLakeWH 29,813 #875 Posted February 18, 2022 I’d maybe heat up the knob with a hair dryer… I’d leave it red… 1 Share this post Link to post Share on other sites
