kpinnc 16,174 #776 Posted February 1, 2022 15 minutes ago, ebinmaine said: It's a refreshtoration.....? I'm going to use that. Eveything I have is refreshormoditorized.... 1 3 Share this post Link to post Share on other sites
Horse Newbie 7,398 #777 Posted February 2, 2022 Finally got a call back from my powder coating dude… price had jumped from $250 to $325 for two 9 inch(front), and two 13 inch(rear) wheels for the Work Horse. I called another shop… he said $225… Dropped the wheels off this afternoon after work. Asked him again about the price and he could not remember what price he had quoted me. I said “Well you tell me again, and I’ll tell you what you quoted me this morning “. He said “$225”…. I thought Dang ! Then he said “Well, that was a little high.” So then he said $150, and we agreed on that. Not bad going from $325 to $150 ! 3 6 Share this post Link to post Share on other sites
kpinnc 16,174 #778 Posted February 2, 2022 1 hour ago, Horse Newbie said: Not bad going from $325 to $150 ! Heck no! Good deal! 3 Share this post Link to post Share on other sites
Southern_Secret 464 #779 Posted February 2, 2022 13 hours ago, ebinmaine said: refreshtoration @ebinmaine GOOD GOLLY MS. MOLLY you my friend have out-done you're self this time! 2 Share this post Link to post Share on other sites
Horse Newbie 7,398 #780 Posted February 6, 2022 Okay fellows… I may be jumping the gun here, but I call it pre-planning… I am planning on putting ags on the rear of the Work Horse. My concern is whether or not they will clear the rear fender/ seat pan, and the mower deck gauge wheels. They will most likely be 23x10.50-12, as I have not seen any sized 23 x 9.50-12(original, or at least what came off) on the net. Do any of you that may have more experience with this know if I am likely to have clearance problems with the fenders, or deck wheels ? Share this post Link to post Share on other sites
Lee1977 7,454 #781 Posted February 6, 2022 (edited) 4 hours ago, Horse Newbie said: Okay fellows… I may be jumping the gun here, but I call it pre-planning… I am planning on putting ags on the rear of the Work Horse. My concern is whether or not they will clear the rear fender/ seat pan, and the mower deck gauge wheels. They will most likely be 23x10.50-12, as I have not seen any sized 23 x 9.50-12(original, or at least what came off) on the net. Do any of you that may have more experience with this know if I am likely to have clearance problems with the fenders, or deck wheels ? Should not be a problem. I put 24 x 9.50 x 12 Carlisle Turf Masters on the 520 they are just a little taller. and 18 x 6.50 x 8 Turf Masters on the front. It tighten up under ther just a little. Have giggle the deck a little to drag it under. Full height 25 x 900 x 12 All Trails II get pretty tight. I raised the fender gas tank and fender bracket 1 3/4" on this one. Edited February 6, 2022 by Lee1977 1 2 1 Share this post Link to post Share on other sites
Thor27 846 #782 Posted February 6, 2022 5 hours ago, Horse Newbie said: Okay fellows… I may be jumping the gun here, but I call it pre-planning… I am planning on putting ags on the rear of the Work Horse. My concern is whether or not they will clear the rear fender/ seat pan, and the mower deck gauge wheels. They will most likely be 23x10.50-12, as I have not seen any sized 23 x 9.50-12(original, or at least what came off) on the net. Do any of you that may have more experience with this know if I am likely to have clearance problems with the fenders, or deck wheels ? 42 or 48" deck? Share this post Link to post Share on other sites
Horse Newbie 7,398 #783 Posted February 6, 2022 (edited) 9 minutes ago, Thor27 said: 5 hours ago, Horse Newbie said: wheels ? 42 or 48" deck? Don’t really know… when I brought the Work Horse home I just slid the deck out and to the side. (I’ll have to measure it) That is why I said I may be jumping the gun, because I KNEW you guys would be asking, and I figured it would make a difference between a 42” and a 48” deck. And I’m thinking what you most likely are too… that a 42” deck would be less likely to interfere. Edited February 6, 2022 by Horse Newbie Share this post Link to post Share on other sites
Lee1977 7,454 #784 Posted February 6, 2022 (edited) 42 has the height adjustment on right side..The 48" is on the left side closed end. Don't take much to interfere with a 42". Edited February 6, 2022 by Lee1977 1 Share this post Link to post Share on other sites
Horse Newbie 7,398 #785 Posted February 6, 2022 (edited) Thanks @Lee1977… I need to get out in the shop tomorrow after work and take a quick peak at it. I appreciate the time you took to share your knowledge. If I get 23x10.50-12 ags and they interfere with the deck I will be ill ! Edited February 6, 2022 by Horse Newbie Share this post Link to post Share on other sites
Sparky-(Admin) 23,980 #786 Posted February 6, 2022 1 hour ago, Horse Newbie said: If I get 23x10.50-12 ags Do you have wide rims? Generally the 10.5 tires need to be on the wider rear rims. I think standard width rims are 7” or 7.5” and work well for 8.5 and 9.5 rubber. Wide rims are 8” or 8.5” and are better suited for 10.5 rubber. 3 Share this post Link to post Share on other sites
Horse Newbie 7,398 #787 Posted February 6, 2022 (edited) Thanks for the feedback @Sparky… I guess I will wait until I get the rims back from the powder coating shop and measure the width from bead surface to bead surface. Then I will know for sure the width. Others here, I believe, have said the 23x10.50-12 tires should be fine on the Work Horse. They may have said that considering both fender clearance and deck clearance, but I’m not sure they thought of both. If it weren’t for ordering on the net and then having the hassle of trying to send them back, I would say I’m overthinking it . If I were going with turf tires I don’t think it would be an issue (may not anyway), but the “lugs” on the ags have me thinking… Edited February 6, 2022 by Horse Newbie 1 Share this post Link to post Share on other sites
SylvanLakeWH 29,789 #788 Posted February 6, 2022 (edited) 13 minutes ago, Horse Newbie said: Can’t speak to the ags directly, but this is what I ran into with tire sizes, where the same manufacturer and tire type but different country of origin. May be of use as you evaluate… Edited February 6, 2022 by SylvanLakeWH 1 1 Share this post Link to post Share on other sites
Thor27 846 #789 Posted February 7, 2022 4 hours ago, Horse Newbie said: And I’m thinking what you most likely are too… that a 42” deck would be less likely to interfere. Other way around, wheels, and the adjuster are closer together. A 48" deck is more forgiving. 1 Share this post Link to post Share on other sites
Horse Newbie 7,398 #790 Posted February 7, 2022 1 hour ago, Thor27 said: Other way around, wheels, and the adjuster are closer together. A 48" deck is more forgiving. Well there ya go… I was assuming with the 42”, the deck wheels would be too “far in” to interfere, but I guess I was looking at it wrong… should have did a test fit before I said that. Thank you sir… I’ll check it out ! Share this post Link to post Share on other sites
kpinnc 16,174 #791 Posted February 7, 2022 19 hours ago, Sparky said: Do you have wide rims? Mike's post is especially true for ag tires. The wide bars are less flexible, so all of the "curve" is typically forced to the sidewall. This makes for some difficult mounting, and the fit is poor if you do by chance get them to lock the bead. Typically turf tires will allow more equal flex across the tread, so they will mount far better. Long story short- 10.50 ags really need 8.5 inch wide wheels as a minimum. The only exception I can think of is that many new tires are not actually as wide as the size claims, so some may work out ok. 2 Share this post Link to post Share on other sites
Horse Newbie 7,398 #792 Posted February 9, 2022 So today I called the powder coating shop to check on my wheels for the Work Horse… The guy said I never dropped them off ! So it turned out I mistakenly called the guy that was wanting to charge $325… I apologized and called my guy that is doing them for $150… I should have them by Friday… will post pics… Just ordered 2 Hi-Run 23x10.50-12 ags for rear, and 2 Hi-Run 16x6.50-8 straight ribs for the front… I will post pics when I get them mounted. Hopefully she’ll be rolling shortly ! 1 2 2 Share this post Link to post Share on other sites
ebinmaine 75,694 #793 Posted February 9, 2022 5 hours ago, Horse Newbie said: I apologized and called my guy that is doing them for $150 I'll bet it was much easier for the second fella to find them! Ahh well.... 5 hours ago, Horse Newbie said: she’ll be rolling shortly NIIIIICE 3 Share this post Link to post Share on other sites
Horse Newbie 7,398 #794 Posted February 12, 2022 Picked up my powder coated wheels today after work… then picked up my ags and straight ribs… More work will be done on the Work Horse this weekend ! 3 6 Share this post Link to post Share on other sites
kpinnc 16,174 #795 Posted February 12, 2022 32 minutes ago, Horse Newbie said: More work will be done on the Work Horse this weekend ! Looking like a fun weekend! 1 Share this post Link to post Share on other sites
Jeff-C175 7,207 #796 Posted February 12, 2022 Those look awesome! Now the trick is gonna be to get the tires mounted without chipping the powder coat. GOOD LUCK !!!!!!!!! 1 Share this post Link to post Share on other sites
Horse Newbie 7,398 #797 Posted February 12, 2022 2 minutes ago, kpinnc said: Looking like a fun weekend! If I can drop the tires and wheels at the Lawn Care Center, I will come back home, paint the gas tank, seat pan / seat bracket cross member, get the transmission topped off with gear oil, and do some other bits here and there… Then hopefully go back and pick up the wheels… 2 Share this post Link to post Share on other sites
Horse Newbie 7,398 #798 Posted February 12, 2022 5 minutes ago, Jeff-C175 said: Those look awesome! Now the trick is gonna be to get the tires mounted without chipping the powder coat. GOOD LUCK !!!!!!!!! On my 520H the place I am having it done did not scratch those powder coated wheels… but those were turf tires, not Ags. Are you saying the Ags may be a tougher sale, and cause their tire machine to damage the powder coating ? Share this post Link to post Share on other sites
Jeff-C175 7,207 #799 Posted February 12, 2022 14 minutes ago, Horse Newbie said: Are you saying the Ags may be a tougher sale, and cause their tire machine to damage the powder coating ? Well, they are a bit tougher to mount, but it really all depends on the skill and care of the guy that's doing the work. 3 Share this post Link to post Share on other sites
kpinnc 16,174 #800 Posted February 12, 2022 15 minutes ago, Horse Newbie said: Are you saying the Ags may be a tougher sale, and cause their tire machine to damage the powder coating ? If they use a tire machine? Not likely. 1 Share this post Link to post Share on other sites
