grinchsr
Vac Bagger Bearing
grinchsr
I have a model 79301 rear bagger with a noisy blower shaft bearing.  Has anyone sourced the bearings on that shaft from any where other than Toro who wants around $60.  Toro #251-288
Edited by grinchsr
peter lena
@grinchsr , visible # on that bearing ?  internet source that , if you get a chance to get a bearing with wide rubber side seals , you could easily convert it over to better hi temp grease , no noise or failures . done that to all my bearing replacements .  pete
grinchsr
Hi Pete    No visible number on that bearing at least not on the outside.  I will have to rip into it tomorrow.  I was trying to get the bearings here before I broke it down.  I too have saved some bearings with rubber seals with the grease needle thing.  These bearings are sealed,  Now I have some thing to do tomorrow besides cut my lawn.
cleat
Blower bearings 251-288
RA012RRB
YET204-012
AEL204-012
That should help.
grinchsr
Yes it helps a lot and thanks.  I removed the old bearings cleaned them up and could not find a number on them at all.
