pencilpusher8@aol.com 0 #1 Posted September 26, 2021 My daughters 252H has a broken spring in the shift linkage. Looked on the toro site only to find they are no longer available. Does anyone have the specs on the two springs that are mounted to a common location so I can source new ones? Any info would be appreciated. Share this post Link to post Share on other sites
Jeff-C175 7,203 #2 Posted September 26, 2021 Do you have the part numbers? There's a manual section here that you can download the manual. It may not have the spring specs though. Do you have the broken spring? Tractor Supply usually has a pretty good selection of springs, you could match it up. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,094 #3 Posted September 26, 2021 Welcome to Red Square. Only 2 model numbers for the 252-H 1988 model 22-13KE01 1989 model 22-13KE02 Here is a parts list for the 1988 and both years are likely identical. They have about a dozen springs on this model. https://www.partstree.com/models/22-13ke01-252-h-toro-yard-tractor-1988/ 1 Share this post Link to post Share on other sites
